Fix
Invalid Sim message occurs because of network lock.You have to unlock your Blackberry Torch from network lock using the unlock code.Visit the site Onlinegsmunlock.com/blackberry/rs7wp8/
get the Unlock code and unlock it easily..
SOURCE: have a blackberry pearl and want to transfer the
you can insert the memory card in blackberry torch, then go to file explorer in application and copy all the stuff in memory card to internal drive and paste it, or i suggest you leave the card in phone itself.
memory card is always a safer storage device than internal.
SOURCE: I have blackberry torch with verizon sim card and
Hey, Call your service provider to ask your Blackberry Network Unlock Code. when you change your current network provider you must need to unlock your Blackberry first. after unlocking you can use your Blackberry to any network.but network provider take time to give your Imei Unlock Code.second option is, you can buy your Blackberry Torch Imei Unlock Code from third party . this is safe way to Unlock your Blackberry . they will charge little amount but they give your Blackberry Imei unlock code immediately. i hope this information is help you.
1 - Switch ON your Blackberry 9800 Torch with your current network/service provider's SIM card.
2 - Using the menu go to Settings Menu -> SIM card and press select.
3 - While holding the SHIFT key, type mepd.(NOTE: You may not see any text appear on the screen while typing mepd)
4 - You should now see the five locking categories listed.
5 - While holding the SHIFT KEY, type mep2.(NOTE: You may not see any text appear on the screen while typing mep2).
6 - Release the shift key.
7 - You will now be prompted to enter the Network MEP code. (it will also state how many attempts left)
8 - Enter the Unlock Code.
9 - Enter Return/Enter.
10 - The Blackberry 9800 Torch should then be unlocked.
