No more picture
From 31" picture to 1"vertical picture for 5 sec then no more picture
  • May 11, 2010
    Make and model of set? Is the screen completely black or showing a thin white horizontal line after the picture went away? Also, is the sound still normal?
  • 4,234 Answers
Usually this is a problem in teh vertical circuit and generally results in a thin horizontal line through the center of the screen. If that is the case, look for a small flat IC that may be marked LA7837 or someting similar with about 11 pins. This should be the vertical IC. Try resoldering the pins on the IC first. If that fails to resolve the problem, replace the IC. Please note that defective capacitors in the vertical circuit can cause this as well. The more probable defect is the IC. Update this with your results. Also be aware that there are potentially dangerous high voltages inside the set even when unplugged.
Dan
Posted on Dec 17, 2008
GE 31GT659 31 Picture on right is vertically drooping
Check the degaussing posistor. Replace it. It can be located at the main power regulator section. Will look like this.
Jul 29, 2012 | GE 31GT659 31" TV
No audio on sanyo ds31520 after replacing vertical IC.
Replacing vertical output IC won't poise this type of problem. Check the voltages at the audio output section.
Jun 22, 2012 | Sanyo DS31520 31" TV
Kv-25x5u picture goes off but sound still there, red light at front flashes 4 times every 5 secs, picture comes back on after 15 mins
if you are a tech the set is having problem in the vertical and horizontal circcuit...check IC 1509 and Q1505.good luck.
Sep 13, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
The picture is moving up and down in every 3 sec
Vertical hold needs adjustment. Check for vertical hold preset and adjust. If no preset present in the P C B of the TV, try through service mode adjustment. Service mode adjustment possible only by the authorized service provider.
Jul 10, 2010 | Haier HTF20 20" TV
My sanyo ds31590 31 has a black picture with a thin white line in
check the voltage at vertical ic must get 24volt dc then replace the IC that all
Jun 30, 2009 | Sanyo DS31590 31" TV
Sanyo 31'' Standard Def CRT TV
This is a vertical problem that can be as simple as poor connections at the vertical IC or a defective IC. If you can solder, you should be able to fix this yourself. Realize that there are potentially dangerous high voltages present inside hte set even when unplugged. If you wish to attempt this repair, please update this and confirm your model number as DS31590 and I'll supply additional details and instructions.
Dan
Feb 24, 2009 | Sanyo DS31590 31" TV
Vs-50609
Good Day, checho3435;
Look for fluid on the PCB's or check these items:
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input/device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source). Good Luck, big IRISH>
Jul 30, 2008 | Mitsubishi WS-55807 TV
Sanyo DS31520 31 Picture problem
hi there, it is worth for fixing it, cheaper than replacing it. you have a vertical section problem. look for a quilified service personnel for it to fix. ty
Nov 12, 2007 | Sanyo DS31520 31" TV
Tv not working
this symptom, sometimes called the tube light effect, it is characterised by a bright thin horizontal line across the middle of the screen. this symptom is caused by a breakdown in the vertical deflection circuit. hence maybe the trouble maybe in the vertical oscillator, amplifier or output circuits. but if all i have said is not clear to you, better bring it to a qualified tv technician. good luck!
Mar 08, 2007 | Sanyo DS31590 31" TV
Televison & Video Logo
60 people viewed this question
Top Televison & Video Experts
