Question about NetGear : RP614 4-Port Cable/DSL Router with 10/100Mbps Switch (NENERO05)
Net Gear Router
I can not setup my router. Does not allow me to connect to internet.
    President:
  • 2,961 Answers
You should be able to get into your routers settings by typing in it's IP address in your internet browser, eg 192.168.2.1 or something similair. assuming you are connecting via an RJ45 Lan vable as you don't mention wireless, when in the routers settings look for the DHCP settings, this should be automatic so as to assign your pc an IP addresss automatically. When you connected your modem to the router, this should have been set up automatically as is usual with cable, so if still no connection go to your network cards properties in Control Panel>Network Connections, right click>properties>TCP/IP line>properties and ensure obtain IP address automaticcaly is ticked and click OK. Go to your Internet browser>internet options, then click the connections tab and make sur that 'Never Dial a Connection' is ticked. Restart your pc and try to connect to the internet.
Posted on Mar 26, 2007
I want to connect my Xbox 1 to the Internet so it can work but don't know how!? My only source of Internet is my sprint router net gear air card! Does anyone know how to connect an Xbox 1 to a sprint...
Yes, it should be easy to connect your Xbox One to the internet.
Assuming your Netgear router is wi-fi capable, go to Network settings on the Xbox One. This will display Network status - wireless settings - etc. Follow the setup procedure here:
Network settings on Xbox One
Feb 26, 2014 | Computers & Internet
Can't find my wep key or admin password
If you have forgotten both you will need to restore your router to factory settings and re-add your internet details ***NOTE*** you will most likely have to contact your ISP for your account details so you can add your net details.
To restore there is a small pin hole on the back of the router with reset below it push and hold for 30secs this will revert your router back to original settings and change your login details to username: admin & password: admin. You will now need to run the setup wizard to setup your router and internet details which will allow you to input a new wep key.
Once done you will need to re-connect each device on your network with new details.
Hope it helps.
Thanks.
Nov 27, 2010 | SMC Barricade g SMC2804WBR Wireless Router
When I connect my router i lose internet connection, even though my modem still shows connectivity. I have followed the instructions to connect the router to my computer and the modem to the router. Any...
firstly, connect your modem to the router and your pc to the router. Next, reboot your PC. try to access the net. If you now can, great. If not, you may need to switch on DHCP and NAT in your modem. DHCP means Dynamic Host Control Protocol and NAT means Network Address Translation. Both of these services are required to allow your PC to access the net through your router. I am assuming that you have a modem and a separate network switch. If you have a modem and the router is another modem with a network switch built in, then you cannot use them both at the same time. If the router has a modem built in, remove your old modem and set up the router according to its manual. Entering your ISP login details either through the routers setup software or through the routers own browser page. The manual for the router will tell you how to do this. If the router is a netwrok switch, then you will need to log into your modems browser page and turn on DHCP and NAT. Then save and reboot the modem and reboot your PC. Once everything has rebooted, go into your control panel, Network connections and check that a valid connection has been made. If yes, then access the net using your browser. If no, try the Network Setup Wizard to repair or replace the existing setup with an updated one. Just run through the wizard choosing the correct or most appropriate options from the menu's..
Oct 31, 2009 | Linksys WRT54G2 Wireless Router
Lose internet connection (hughes net) when hooking up router
I would contact your hughes net, that is a satelite provider. That is a total different system, than dsl or cable. Hughes net should be able to walk you through the setup.
Oct 26, 2009 | Linksys WRT160N Wireless Router
Toshiba NB 205 connects to router but not internet
The wireless configuration is set differently on routers, eg the SSID, and encryption. You need to configure the wireless LAN card in the laptop to connect/communicate with the different routers.
Some wireless LAN card allow you to setup different profiles/settings for different wireless routers. Eg one setting for the office and one for home, which allows easy connection to the Internet by selecting the appropriate profile/setting.
Aug 17, 2009 | Toshiba Computers & Internet
I went from a ATT dsl modem to a net gear modem and i cannot get the net ger mode and linksys mode to talk to the computer
Most DSL providers use PPPoE (Point-to-Point Protocol over Ethernet) to establish Internet connections for end-users. To set up a Linksys router, you need to enable PPPoE on the router’s web-based setup page.
To setup a Linksys router with a DSL connection you need to perform four steps:
  1. Verifying Internet Connection
  2. Connecting the Devices Together
  3. Checking the LEDs
  4. Setting-up a DSL ISP on a Linksys Router
Connect the Broadband modem to the computer using an Ethernet cable without the router installed and make sure that the Internet connection is active. If not, contact your Internet Service Provider.
Aug 01, 2009 | Linksys Wireless-G Broadband Router
Wndr 3300 net gear router wont work with hn 9000 hughes net modem
I went to the Hughes web site to check out the modem. They say it is also a router. I think you will have to disable the router abilities of your WNDR 3300 Net Gear Router.
Get into the Netgear setup by loging on to it.In its WAN setup select Static IP Address and set the Static IP Address to the same as the hughes modem, except for the last number which should be about 50 greater. IE: Hughes 192.168.12.1 and Netgear 192.168.12.55.
In the DHCP setup, disable the DHCP Server
In the Wireless setup, Give your network a name is SSID. You should also set up security to keep others off you internet connection with a WEP key.
I hope this helps.
May 30, 2009 | NetGear WNDR3300 - RangeMax Dual Band...
Modem and d link
Hello there,
Your internet connection should be setup properly in order for the router to give connectivity to both your computer.
You must contact your ISP and ask them for the IP's and put it in the router.
Apr 05, 2009 | D-Link DI-604 4-Port Cable/DSL Router...
Internet speed is very slow with NET GEAR WGR614 router
MTU Adjustment
1. Access the web-based utility of the router.
a. Please open any web browser like Internet Explorer or Netscape Navigator.
b. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key.
c. A window will prompt for a user name and password. The default username is "admin" and the default password is "password".
Note: If it does not take password as the password, you might have changed it when you have run the NETGEAR Setup CD so please try other passwords. If you cannot remember the password, you need to reset the router and run the Setup CD to reconfigure it.
2. Adjust the MTU setting.
a. Click on the WAN Setup under Advanced tab.
b. Lower down the MTU size to 1492, 1400, 1358 or 1300.
c. Click on the Apply button.
Note: You may verify from your ISP the recommended MTU size you can use.
Apr 02, 2009 | NetGear WGR614 Wireless Router
Bought a router to connect home line with new notebook
Umm, maybe you didn't plug it in right. Try putting in the CD rom of your router, then download it, and it will probably have setup/ help on there.
Dec 28, 2008 | Computers & Internet
Open Questions:
How to select best payroll software in India, Dubai, UAE, Qatar, Oman Using a Payroll Software in Dubai or a Payroll Management Software in UAE will definitely save you time and money. This will allow you to focus on your business. You don't have to be a Payroll Processing expert to use the software. You will need to buy an end-to-end system incorporating your company requirements. Following are the eight components that are going to help you discover how you can choose the best payroll solution. Offline or Online Payroll: You can choose from two types of payroll software - offline or online software. Choosing one solely depends on your business type, your working mode, and preference. Offline payroll is installed locally on your computer. You won't need an internet connection to access your payroll data. With offline payroll, you will have a flat purchase price, and only pay for future upgrades. If your PC/laptop is destroyed, you will not be able to access your Payroll Processing, Payroll Hold, Pay slip, Trail Payroll, Payroll Reports data. Online payroll, also called as cloud-based payroll software, help you to access it anywhere and anytime. You just need an internet connection and your login credentials. This type if HRMS Software in Dubai, UAE, and/or Abudhabi is advantageous if you are always travelling. With cloud-based payroll software, you get to retrieve your data from many devices. You can log in on a computer or on your mobile/tablet. Initial/Recurring Costs: How much do payroll software cost in Dubai, UAE, and/or Abudhabi? As a business proprietor or company's management, you most probably are not looking to spend money to buy whatever is promoted to you. You are looking for affordable services which get the tasks completed. When determining on the HRMS Software in Dubai, UAE, and/or Abudhabi, the cost is one of the main factors. The Business Software Provider in Dubai, UAE, and/or Abudhabi should not charge you hidden costs/fees. You might have overlooked them during the initial HR Payroll Software cost examination. You don't want to quickly select a Payroll Solutions provider and later notice extra costs you didn't know of. There are different pricing models. Always read the contract and understand the full extent of what is included. Add-ons or Modules: Cost is an important factor, but you want the Payroll Management Software to perform to your requirements. Every business is different. The Best Payroll System for Dubai, UAE, and/or Abudhabi should be able to incorporate your business requirements. The Best HRMS Software in UAE should not be different from the Best Payroll Software for Dubai. Service and Support: When using a payroll system, you have got to have control over it. You need to feel comfortable when you get questions. A payroll system should have effective support to help its users. Most payroll solutions have customer support consultants. Most payroll software vendors help in setting up your system. Support is the second most important item in your checklist, compare support provide by different vendors. Your Payroll Management Software vendor should provide phone and/or online support. Learning Curve: Choosing a payroll solution that is easy to understand and use is the third most important thing while selecting a payroll system. Many payroll solutions need some level of prior working knowledge to use them. Take a trial so that you are able learn to use the payroll solution before buying it. Purchasing the Best HRMS Software involves a low learning curve; this results in money and time savings. Trial Period: Most payroll solutions in Dubai, UAE, and/or Abudhabi have trial periods to let the user get a feel of the software. A trial period allows you to gauge precisely what you are buying. Check the payroll solution you are contemplating to see if it has a trial period or not. This lets you determine whether the Payroll Management Software is the right one for you. Security: Security is the third major factor when selecting a HR Payroll Software in Dubai, UAE, and/or Abudhabi. You do not want someone to gain unauthorized access to your employees' personal data? It is a nightmare for management and workers. Always ask how the Payroll vendor secures the data. Any payroll solution you choose should have high-grade encryption, as is bank software. Contract: Ascertain if the Payroll Solution has a contract or not. Payroll solutions don't necessarily have one. Before selecting a HR Payroll Solution, check if there is one. Before entering into one, make sure the HRMS Software fits all your requirements. Sometimes there might be an early termination cost. You should choose payroll software that has no contract. You will be able to cancel the vendor and select another one when needed. You need to make sure that the Payroll Software has Payroll Processing, Payroll Hold, Payslip, Trail Payroll, Payroll Reports function in it. Select the best Business Software Provider in Dubai, UAE, and/or Abudhabi, and that they provide Employee Attendance and Leave Tracking as a built-in function. You should also make sure that Payroll Solutions Portal works in Dubai, UAE, and/or Abudhabi. The above points are the positives and negatives when choosing a Payroll Management Software in Dubai, UAE, and/or Abudhabi. Always make sure it fits your requirements.
Jan 16, 2019 | Major Computers & Internet
See all NetGear : RP614 4-Port Cable/DSL Router with Questions
Computers & Internet Logo
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Mike
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
