Question about Yamaha RX-V363 Receiver
Connecting my laptop with my yamaha rx-v363
I connect my laptop with my HD ready Sony TV, but the audio and the sound then plays through the TV. I would like the audio to br played through my amp. What kind of connection can I use between my laptop and amp or TV and amp to give me the optimal sound?
avenger77
SOURCE: Playstation 3 audio connection into Yamaha HTR-6040 AV Receiver
Solved problem with Yamaha HTR-6040 AV Receiver. My daughter had inadvertently changed the program to "Direct Stereo" mode which allows sources to bypass the decoders and DSP processors so you can listen to 2-Channel PCM and Analog sources. Nothing to decode digital audio in this setting!
Posted on Aug 10, 2008
SOURCE: I have a Yamaha Rx-v363
this sounds strange, but is true. you need to run your digital audio optical cable from your tv to your receiver (after, of course, connecting tv/receiver via hdmi). so, hdmi from blue ray to rec - hdmi from rec to tv - then optical from tv back to rec. it's round about, but that is how yamaha says (and the only way it works) to do it.
Posted on Jan 04, 2009
dunnbiker
  • 8546 Answers
SOURCE: Unable to play DTS-HD & True-HD
What do you hear? Do all other modes work ok?
If Audio Select (Page 44 and 98) is set to HDMI you will hear silence if no HDMI signal is present. I think AUTO is the best choice here.
On Page 98 of the manual it says a bunch of things concerning automatic signal detection and input selection.
Initial configuration D) INIT. CONFIG
Use this feature to select the settings of the audio input jack select, active decoders and extended surround when you tum on this unit.
Audio select AUDIO SELECT
Use this feature to designate the default audio input jack select setting (see page 44) for the input sources connected to the DIGITAL INPUT jacks when you tum on the power of this unit.
HDMI set E)HDMI SET
Use this feature to select the component to play back HDMI audio signals.
Support audio S. Audio
Use this feature to select whether to play back HDMI audio signals on this unit or on another HDMI component connected to the HDMI OUT jack on the rear panel of this unit.
CHOICE = RX-V663
FUNCTION
Plays back HDMI audio signals on this unit. The HDMI audio signals input at the HDMI input jacks of this unit are not output to the HDMI component connected to the HDMI OUT jack on the rear panel of this unit.
CHOICE = OTHER
HDMI component connected to the HDMI OUT jack.
NOTES
This unit transmits audio and video signals input at the HDMI input jacks to the HDMI out jack only when this unit is turned on even if "S.AUDIO" is set to "OTHER".
I'd look in these areas for specific guidance.
Posted on Apr 27, 2009
SOURCE: Yamaha RX-V3800 receiver zone two audio problems
To get audio with this set up also hooked up analog audio RCA cables for the audio for each piece of equipment for 2 channel out put. Zone 2 will not out put a digital signal and this receiver will not down convert a audio signals to analog if using digital audio hook-ups.
Posted on May 08, 2009
smarthome2
  • 1114 Answers
SOURCE: Can't find Yamaha RX-V363 code for a Time Warner
http://www.yamaha.com/yamahavgn/Documents/YEC/AV_Receivers/Manual/RX-V363_U.pdf
Here's your manual. Hope this helps
Posted on Aug 14, 2009
HELLO MY NAME IS ROBERT. I HAVE A QUESTION. I HAVE A YAMAHA RX-V363. I ALSO HAVE A PANASONIC ST30 PLASMA 3D. AS WELL AS A PANASONIC BLU-RAY. AND DIRECTV HD BOX. HOW WOULD I EVEN START TO CONNECT THE HDMI...
The TV may have HDMI ports, but the V363 may only have RCA outputs.
Video Audio HDMI Male to 3 RCA AV Cable Adapter Audio Video Component DV Convert HDMI to 3-RCA TV Adaptor Line For HDTV 1080P AU https://www.aliexpress.com
Try here.
Feb 17, 2018 | Yamaha RX-V363 Receiver
How to correctly set up a media center computer. I have set scene 1 there is a digital line from computer to receiver I get sound from Win media center when playing music and analogue television but...
At the rear of the Yamaha, on the left side, you will see 3 connectors for Digital input - the 2 one is specifically set for an HD tv / DTV. Buy a optical cable like
http://www.amazon.com/AmazonBasics-Toslink-Digital-Optical-Meters/dp/B001TH7GSW/ref=sr_1_2?s=electronics&ie=UTF8&qid=1297066417&sr=1-2
and connect it between the tv output and the receiver then select it as a source from the menu . Now you will have sound.
Feb 07, 2011 | Yamaha RX-V363 Receiver
I have my xbox 360 connected via hdmi to my yamaha rx-v363 receiver, and the receiver connected to my sony bravia lcd tv via hdmi as well. The xbox picture comes through to the tv fine, but the sound will...
Connect Xbox via HDMI to DTV/IN, Connect HDMI from out to Sony Bavia's HDMI/IN. Connect TV's Optical out to amps DTV/Optical in.
2X HDMI cables and one Optical are required.
Enjoy great sound :)
OH: choose the DTV input then stereo and then dolby 5.1 etc .. cheers
Sep 04, 2009 | Yamaha RX-V363 Receiver
Poor dialog sound of Yamaha RX-V363
I'm working on one right now. It seams that you are not selecting to correct program for the dialog. I would not use music enhancement on dialog content.
Jul 15, 2009 | Yamaha RX-V363 Receiver
Ipod connection to a Yamaha RX v363 receiver
Fortunately you are wrong :)
On yamaha site you can see that RX-V363 has a DOCK connector, which supports both iPod docking station YDS-11 and Bluetooth Wireless Audio Receiver YBA-10.
Jan 25, 2009 | Yamaha RX-V1800
Wii to RX-V363?
Hi..
If youre talking about the set of 3 A/V plugs in the front then you need to connect to the Video Out (yellow) plug in the back that says something like "Front Video" or "video 3" out. Connect that to the display.
Jan 14, 2009 | Yamaha RX-V363 Receiver
I have a Yamaha Rx-v363 receiver using HDMI jacks but I am not getting any sound through my surround sound only my tv speakers. I have a digital audio optical cable running from the receiver to the blue...
Jan 02, 2009 | Yamaha RX-V363 Receiver
Yamaha reciever rx-v363
Thats because if you look in the owner's manual, it declares the fact that it will only broadcast sound from hdmi to monitor not speakers. For sound out of speakers need to connect additional audio cable.
Apr 21, 2008 | Yamaha RXV-350 Receiver
Yamaha RX-V363 Receiver Logo
192 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
CHP6PH1
Level 1 Expert
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
