SOURCE: I have a 1997 FORD E250 VAN 4.2 V6 RUNS GOOD ON
If your exhaust smells like sulpher and the exhaust coming out of the tail pipedoes not stop immediately after engine is turned off. Your catalyctic converter is restricted. Have chk'd by muffler shop
SOURCE: 1997 Ford Explorer
Ok you need to correct the mechanical issue and then deal with the codes, they are a result of the engine problem, not the cause of it.
SOURCE: Takes time to start up a 1999 Ford Pick Up Ranger
Check the MAP sensor and the fuel pressure at the shredder valve. Before you try to start the engine, cycle the ignition 3 times to the run position for 10 seconds apart and then try starting the car. You may be lossing the fuel pressure prime. Good luck and keep me posted, be glad to hlep.
SOURCE: Rough starting
check plugs on injectors, check for spark from all plugs,check distributer cap
