Question about Procom ML060HPA Heater
Mn100tba flame is brite orange instead of blue.what should i do to fix problem?
    President:
  • 2,976 Answers
It most likely needs to have the fresh air adjustment opened up a little bit.
Posted on Jan 15, 2009
The flames from the front left burner is 1/3 orange and 2/3 blue; whereas the flames from the other burners are all blue. There is a strong odour from the front left burner when we turn it on and also the...
The flames should be all blue - except when you first turn it on, where the flame begins, & only when you turn it on. Orange flames mean incomplete combustion is happening. Carbon monoxide is being released. Orange flames can also mean your getting low on gas. Clean it & try moving the disk around. An uneven disc means some flames will be higher & burn your pots. The flames are wrapping around your pots if they're burning on the sides. Keep flames under the pot. Regardless of the being clean, the odor means you need to check your gas level. Once filled back, the odor should be gone if that's the only problem. That is placed in the gas as a safety feature. Don't try to fix this problem yourself if the "easy" solutions don't work. It could be very dangerous. Invest in a carbon monoxide detector especially when you have anything gas.
Sep 15, 2011 | GE Profile JGS968 Gas Kitchen Range
I have an orange flame on the burner instead of blue
The difference between an orange flame and blue flame is the amount of air in the combustion process. SO if the flame is orange it is being starved of oxygen. The gas burns dirty and soot is generated.
Sometimes with an older heater the exhaust venturie becomes plugged and carbon monoxide is released into your home- in this case your heater would make a woof or poping sound when starting up or shutting off. This is a dangerous unsafe situation and professional help is needed.
What you can do is try to make adjustment yourself, if your confident the other situation does not exist. Your water heater should have a little deflector shield on the gas line between valve and burner (typically immediatly after the orfice). Sometimes these will have to be slide front or backwards or twisted. The adjustment of deflector shield must be opened more to make the blue hotter flame to mak eyour heater operate at peak efficiency.
Good Luck
Jan 03, 2011 | Whirlpool Water Heaters
I want to see the cheats of guitar hero2
Secret Guitars
  • Snaketapus Guitar: Complete Hard Mode.
  • The Log" Guitar: You must achieve 5-Star every song on Expert.
  • Battle Axe Guitar: Complete Expert Mode.
  • Casket Guitar: Complete Medium Mode.
  • Eyeball Guitar: You must achieve 5-Star every song on Hard.
  • Fish Guitar: Complete Easy Mode.
  • USA Guitar: You must achieve 5-Star every song on Easy.
  • Viking Guitar: You must achieve 5-Star every song on Medium.
Unverified. On the main menu, directly depress the colored key without any other input.
Performance Mode ... YELLOW, YELLOW, BLUE, YELLOW, YELLOW, ORANGE, YELLOW, YELLOW
Hyper Speed ... ORANGE, BLUE, ORANGE, YELLOW, ORANGE, BLUE, ORANGE, YELLOW
Air Guitar ... YELLOW, YELLOW, BLUE, ORANGE, YELLOW, BLUE
Eyeball Heads ... BLUE, ORANGE, YELLOW, ORANGE, YELLOW, ORANGE, BLUE
Moneky Heads ... ORANGE, BLUE, YELLOW, YELLOW, ORANGE, BLUE, YELLOW, YELLOW
Flaming head ... ORANGE, YELLOW, ORANGE, ORANGE, YELLOW, ORANGE, YELLOW, YELLOW
Horse head ... BLUE, ORANGE, ORANGE, BLUE, ORANGE, ORANGE, BLUE, ORANGE, ORANGE, BLUE
Air guitar ... BLUE, YELLOW, ORANGE, BLUE, YELLOW, YELLOW
Eyeball Heads ... YELLOW, ORANGE, BLUE, ORANGE, BLUE, ORANGE, YELLOW
Hyper Speed ... YELLOW, ORANGE, BLUE, ORANGE, YELLOW, ORANGE, BLUE, ORANGE
Monkey Heads ... YELLOW, YELLOW, BLUE, ORANGE, YELLOW, YELLOW, BLUE, ORANGE
Flaming Head ... YELLOW, YELLOW, ORANGE, YELLOW, ORANGE, ORANGE, YELLOW, ORANGE
No HUD performance mode ... YELLOW, YELLOW, ORANGE, YELLOW, YELLOW, BLUE, YELLOW, YELLOW
Horse Head ... BLUE, ORANGE, ORANGE, BLUE, ORANGE, ORANGE, BLUE, ORANGE, ORANGE, BLUE, ORANGE, ORANGE, BLUE, ORANGE, ORANGE, BLUE, ORANGE
To unlock everything in the game, insert the following code on your guitar at the title screen: Blue, Yellow, Orange, Red, Orange, Yellow, Red, Yellow, Red, Yellow, Red, Yellow.
Jun 05, 2009 | Video Game Consoles & Games
Burner flame orange instead of blue, problem just started today
The only thing that i can think of is that it is not hot enough. try turning up the heat. Orange fire just means that it is not as hot as the blue fire.
May 21, 2009 | Maytag MGR6775BD Gas Kitchen Range
Side burner on propane gas grill burns with orange flame ratheer than blue
here is a link to a page that shows what the colors of the flame should look like and what causes the orange instead of the blue flame. http://www.appliance411.com/faq/gas_range_flames.shtml
I would begin by checking to be sure you do not have a spider or a cob web in the burner partially blocking the gas or the air intake.
May 12, 2009 | Weber Gas Go-Anywhere Grill
Orange flame on cooktop instead of blue flame
it can be a mixture problem or low pressure from the regulator
gas repairs /adjustments in not in the DIY domain as it is extremely dangerous
call a gas fitter to properly diagnose the problem and have it done safely
Jul 21, 2017 | Kitchen Ranges
Please send me cheats in guitar hero II
To unlock everything in the game, due the following code on your guitar at the title screen: Blue, Yellow, Orange, Red, Orange, Yellow, Red, Yellow, Red, Yellow, Red, Yellow.
Jan 06, 2009 | RedOctane Guitar Hero 2 Game For...
Procom ML060HPA Heater Logo
77 people viewed this question
Top Procom Heating & Cooling Experts
Paul Carew
Ronny Bennett Sr.
Ronny Bennett Sr.
john h
Are you a Procom Heating and Cooling Expert? Answer questions, earn points and help others
