Hi im shah my 1997 mercedes c180 heats upto 95 deg i have checked the fan clutch its fine the electric fans are working fine the guages are perfect also changed thermostat valve but still temperature rises and if i stop the engine for 4-5 minutes and start it the temperature is above 100 deg which then comes down what should be the problem and what is the best temperature for c180
Actually it sounds pretty normal to me. In general a clean combusting petrol
engine would run @ 93 deg C to a tad lower than 100 deg (97d) to run efficiently
and to be able the 02 sensors to work properly. Your engine is a multi pressurized
close cooling system can happily endure 110 deg from time to time. But if your
Temp suddenly rose near the redline that should be a concern. But if you feel
that this is unusual from what it was before. Check your 2 auxiliary fans
(motor & relays); if it starting to tighten up and doesn't spin freely, its
about time to replace. Check for coolant and pressure leaks (esp the caps); it
should always be pressurized to maintain a boiling point to not boil over.
SOURCE: I have a 1997 Mercedes E320 and the instrument cluster guages
hello,good day,maybe your cluster nearly damage,send to your dealer,they have a testing procedure(simulation all the gauges), to determine if your cluster is defective,ty
SOURCE: hi i have mercedes c180
You will need to bring the car to a garage that has the equipment to reset the airbag light. It can't be done manually.
SOURCE: Mercedes C180 '96 Heater Fault
Check the fan itself, could be worn brushes hence the motor will not turn. Fan is under the cubby hole
SOURCE: mercedes c180 immobiliser has stopped working, was
have you syncronized the remote to the receiver and have u checked the fuses
SOURCE: Mercedes c180 2002 model
Well the first thing i would do is scan the computer for codes,but without a scan reader you cant. see if it has fuel preasure,start there.
Don't you have some warning lights on your dash? MB cars are fly-by-wire that tend to depend so much on battery electricity when shut off. Use a high amps battery or battery recommended matching your car model. Check on some instruments that can be a parasitic drain to your car like, car alarm, sticking relays on auxiliary fans, radios. Worse you have a short somewhere or a wiring harness issue, but it should be giving you a warning on the dash.
yes the radiator is full please can someone tell me the ideal temperature at what point should be the guage meter. the local mechanics say iyour car is fine the meter should not cross 100deg ican someone tell me if its fine upto 100deg
Normally the rule is that the needle is on the half of the gauge. Have you enough oil in the motor that help for temp too.
do you mean engine oil if yes then i have recently changed oil with a new filter
