Front end vibrates when turning. Vibration eventually disappears after driving a few minutes.
SOURCE: Toyota Camry the front end vibrates
try gitting the wheels ballanced and see if that helps and have the front end check out. have the wheel barings tie rods and ball joints checked
SOURCE: Rattle/Vibration from front of vehicle when idling at stop
Hi and welcome to FixYa. Please try this:
GO out to the car, and lift up on the hood. Does it raise a bit and rattle? If so;
Open the hood, and look at the perimeter of the front radiator support. You will see 2 small rubber thingys, that look like that they are screwed onto the metal that is holding the radiator. Unscrew them a little, and close the hood. Pull up on the hood and see if the rattle goes away. If not, repeat unscrewing the rubber things until the lift disappears.
A FixYa rating (4 blue diamonds) would be greatly appreciated for my assistance.
Suspension recall :front control arm lower ball joint. NHTSA Recall: 05V225000. Your going to LOVE this one!! Due to manufacturing issues, the surface of the ball joint may be SCRATCHED and they assembled the units which may lead to excessive wear and looseness, resulting in increased steering or ball joint may seperate resulting in loss of steerng control and a crash could occur without warning. OH! WONDERFUL. 7 THOUSAND Vehicles! I have a 2004 toyota tundra,bought new in o4 and was sent a ball joint recall and had them replaced,it was free.Call local dealer.
