Question about Faberware 10-22 Cup Coffee Urn
10-22 urn I lost my manual for my 10-22 cup urn.I need to know how much coffee to use for full pot
  • chattyk Dec 20, 2008
    I lost my manual also. How many scoops per cup?
  • Jyackle5
    Jyackle5 May 11, 2010
    do you have a part # that will help me get you the right a manual
If you have the L1350/155C, the manual states 1-1/4 cups coffee for 12 (5 oz) cups, for 30 cups use 3 cups coffee using standard measuring cups. Take the stem & filter out when the coffee has finished brewing so the bitter oils do not get into the coffee.
Posted on May 03, 2009
I lost the user manual to my 30 + cup coffee percolator and I need to know the amount of grounds to use when brewing coffee!
Use approx. 1/2 cup of coffee to 10 cups of coffee....so for a full pot use 1-1/2 cups... then adjust to taste..
heatman101
Sep 09, 2011 | Microwave Ovens
I just purchased, what seems to be in very new condition, a 55 cup Farberware electric pot. It did not come with directions. I would think a 1lb can of coffee in the basket? There must be a fill line...
Farberware manuals do not seem to be available online. Try contacting Farberware Customer Service at the following site:
http://www.farberware.com/customerservice.html?hm=Y&ct=N&anw=N
For coffee urns try the e-mail address for Electric appliances. Send your model number with your request for a manual.
Thank you for using FixYa!
Jul 23, 2011 | Faberware 12-55 Cup Coffee Urn
I need to know how much coffee to put in my 55 cup pot.
Hi. One pound of coffee for 55 cups, then adjust to taste.
Feb 13, 2011 | Faberware 12-55 Cup Coffee Urn
How much coffee do I use for the 22-cup Farberware coffee pot?
that would depend on the coffee, and how strong you like it.
as well as how large your standard cups are.
I use 1/4 cup of folgers classic blend for 4 'normal' cups of coffee. I also use an oversized camping mug - so 4 normal cups fills two of the mugs. - - - you may want to try 1 1/8 cup of coffee grounds in the filter if making a full pot.
regards,
Oct 12, 2010 | Faberware 12-55 Cup Coffee Urn
Need new lid for Hamilton Beach coffee urn model 40515
If you go onto the Hamilton Beach website and look at products there is a tab for spare parts.
www.hamiltonbeach.com/coffee-pots-coffeepots.html
Regards
Alan Hood
ami-man
UK
Mar 30, 2010 | Hamilton Beach GE 42-Cup Coffee Urn Coffee...
How much coffee do I use to make coffee in the 55 cup urn? How long does it take to brew the full urn?
use 7- 8 0z cups fresh grounds. Time to brew depends on efficiency of urn. Maybe 15-20 minutes on average.
Feb 02, 2010 | Faberware 12-55 Cup Coffee Urn
My 25cup Farberware urn quit perking coffee can it be reasonbly repaired?
I have the same urn and had the same problem.
There are 3 common causes of lost perk that can be dealt with at home, and cause about 1/2 of the failures with these urns. They are very common when the pots are used rarely or carelessly cleaned after use, and when coffee is ground too fine for perc (drip grind is too fine for perc). As long as the pot is still heating, check these three things:
1) Clean the _inside_ of the hollow stem )that holds the basket and moves the water from the bottom of the pot to the top), to remove all grounds. You should be able to see clearly through it.
2) At the bottom of this stem there is a very small cup that has little holes in it and fits into the little well at the bottom of the pot. Make sure these are completely clear.
3) Scour out the little well so all residue/ grounds are removed and the little cup fits perfectly into the well.
It is the perfect fit of the two that allows the perc-ing cycle to occur.
If the pot is not heating, or these cleaning measures do not work, a local electric repair shop can probably do the repair for about 1/2 the cost of a new urn.
Dec 04, 2009 | Faberware 12-55 Cup Coffee Urn
Need pump tube for 55 cup farberware coffee urn.
Hi. Go to repairshack.con. Good luck. bobbyone
Sep 10, 2009 | Faberware 12-55 Cup Coffee Urn
How to make coffee with 101-cup percolator urn (Regalware)?
Simply fill with COLD water to the number of cups desired.
Place the stem and basket in the pot and put one 8 oz cup of coffee for every 20 cups of water into the basket...when doing 100 cups I add an extra 12 oz of coffee for a good coffee flavor.
Place the perforated lid on the coffee basket that is in the pot (if there is a lid--some do not have a lid). Put the cover for the coffee pot in place.
Plug in.
Turn on if there is a switch.
Give these large pots about 1 minute per cup, brewing time...that is a little over an hour usually to brew 100 cups. The coffee maker will percolate with the water coming up through the stem and over the coffee as the water heats. Usually there is an indicator light that comes on when it is finished.
If holding the coffee for awhile, it tastes best if you remove the stem and basket and it will maintain the heat without doing more "perking" and becoming stronger or bitter.
Be sure to wash it out and dry it well, leaving the lid loose or upside down for storage so that the pot doesn't become pitted. Blessings, Louise
Nov 14, 2008 | Regal Ware 426473 Black Satin Coffee Urn...
Faberware 10-22 Cup Coffee Urn Logo
530 people viewed this question
Top Faberware Coffee Makers & Espresso Machines Experts
Starnley Johnwells
Starnley Johnwells
Steve
Kolbrun...
Are you a Faberware Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
