Back to:
Tags:
Denon AVR-1400 Receiver
Power don't turn on
posted by johnjin on Apr 07, 2007
There is a problem for this receiver. When I turn on the power switch on receiver, stanby lamp shortly blinks once, but receiver is still off.
I searched forum site to fix this problem and common result was checking the protection circuit, mainly output transistor and the resistors, capacitors.
When I opened the receiver, I couldn't discriminate the protection circuit. But I can discriminate the elements such as transistor (BJT/MOSFET), resistor, capacitor and so on.
Which one is output transistor ?
Could you let me know which part is protection part ? Then I can check whether the circuit is shorted or not by myself using multimeter.
In addition, if any, could you give another cause for the problem ?
Because the warranty is over, I have to fix it. I don't want to pass it away.
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Apr 09, 2007
Helpful (85)
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Look for a large aluminum heat sink with the output transistors bolted to it. You should see anywhere from 4 or more large transistors bolted to it. I doubt that the protection circuit is malfunctioning. I would bet that it is doing exaclty what it is supposed to do. If you do find some bad output transistors, be sure to check all the components that work in conjunction with those transistors. Good luck.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Power don't turn on:
I don't want to Accept this solution
Can you Help with these Receivers problems?
Receivers
kvt-715 dvd monitor with dvd reciever i dont have the code...
Receivers
plz help me i cant get the surround speakers to work on my...
Receivers
I have a Rotel RA-01 Amplifier which is now longer working...
Receivers
juice ja590 amplifier , the existing old amp is fine,but...
Receivers
I have a Y reg ford mondeo Ghia x with a 6006e cd changer...
Loading problems.
Repair Service
Find Receiver Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
