Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Rca D52W20 schematics
Sound like i have the same problem with the capacitors. Shuts off by itself and all that. Could you send me a copy of the schematics to bowmaster30@yahoo.com.
Also, where would I find the capacitors for replacement?
Thank You
  • 2 more comments
  • Anonymous May 03, 2009
    i need the schematic jricksus@yahoo.com
  • fresa00 May 04, 2009
    I have the same problem. If the tv turns on at all, it will only stay on for about 30 seconds and then turn off. What cost am I facing in terms of parts and labour?
  • jsthompson5 May 11, 2010
    can you send a copy of the schematics to me too? jsthompson5@charter.net
  • j P
    j P Feb 05, 2018
    and to me jpcook@yahoo
I have a similar problem. could you send me a copy of the schematic. rastacey@nl.rogers.com
thanks
Posted on Nov 15, 2009
    Genius:
  • 1,139 Answers
Hello bowmaster30,
I can send you a copy of the schematic, Radio shack has these capacitors, also www.electronix.com has them. In fact any electronics parts store would have them. Let me know if you still need the schematic.
Thank you,
Shuttle83,
http://www.electron-age-technologies-llc.com
Posted on Dec 18, 2008
RCA D52W20 ATC221 TV Schematics/Service Manual
go to www.tvrepairworld.com they can assist you and they have all the components for the RCA ATC and ITC series televisions and very knowledgable staff for RCA problems based on symptoms.
Apr 09, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 TV powers on fine, then shuts itself off after 5 - 10 minutes. After 20-30 minutes, I can turn tv back on, but then shuts off again in 5 minutes.
it looks like the problem is in the 16v line..try to take it apart..and there's gonna be a 2200mf cap leaky.
that will solve your problem.
Jan 05, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 Light blinks 3 times, Replaced Flyback, Caps
I have the schematic, did the same thing and still have the problem. Any help?
Aug 12, 2009 | Televison & Video
My r.c.a d52w20 rear projection shuts on and off by itself.
Hello james,
The problem happens to be a capacitor. your TV uses the ITC222 Thomson chassis and it has a flaw in which CP150, CP140, and CP120 dries out and then explodes or becomes bloated and causes the problem you are reporting. Here is a URL to get the schematic daiagram:
http://www.eserviceinfo.com/downloadsm/3692/Thomson_ITC222.html
Once you have the schematic, the actual component is on the Deflection board (the one on your right hand side facing the back of the set. The component is behind a heat sink with a transistor on it. Now make sure you find all three capacitors (the two other are on the same deflection board).
I hope this helps,
Thank you,
Shuttle83
Jun 27, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rca 52 inch power light comes on no pic.,shuts off makes noise
I think you have a shorted hori output Transistor NTE2324 if it makes a low squealing sound also ck capacitor 114,120,150 if 150 is puffed up on top it is bad 2200uf 16v use 25v and other 2 are 220uf 35v.
Apr 06, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA HDTV MODEL # D52W20 SHUTS OFF AFTER 10 MINUTE.
There is a common power supply problem with these that requires the replacement of four capacitors on the power board. This could be causing your problem.
Mar 25, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA d52w20 TV will not turn on, already replaced flyback & cp150(was blown)
Hello weewilliemom,
Have you tried to see if CP120, CP140, and CP150 are good? These capacitors usually are the cause of the problem you are experiencing. I have a copy of the schematic is you need it.
I hope this helps,
Thank you,
Shuttle83
Dec 17, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rca 52in rca hdtv
Hello lindseyskirk,
This is a common problem with this TV set as it uses the ITC222 chassis. The problem is usually localized to a group of capacitors
CP120, CP140, and CP150. If you have a background in electronics I can send you the schematics and you can unsolder them and replace them using the schematic to get the values from. If you do not have a background in electronics, I would suggest you have a qualified Television Technician do the replacement for you.
I hope this helps,
Thank you,
Shuttle83
Rca d52w15 turns on and stay on
This is being caused by a series of faulty capacitors CP120, CP140, and CP150. One or all of these capacitors are malfunctioning. They are located on the HV Power board. You will need to replace them of have them replaced. The schematics are available on line, if you can not find them I have a copy, I can send you. If you have a background in electronics this should be a snap, if you do not have a background in electronics, I would suggest that you have a qualified television technician perform this task.
Thank you,
Shuttle83
Dec 15, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA TV
Solder bad connections...main board with hv transformer on it..
CL035 capacitor and any others...use magnifier........T.
Nov 28, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
628 people viewed this question
Top RCA Televison & Video Experts
jason
Steve Allison
Steve Allison
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
