Question about Dimplex DS5603 Heater
My on switch is lit up red all the time
I have Dimplex storage heater, i believe they are an older model. We have them switched on to give a late boost. I heard that the on switch on the wall should only light up at night after 11 when the heat is generating. Mine is glowing all of the time, and we just got a 420euro bill for a one bedroom apartment. I have called ESB who were completly unhelpful. Please help, if the light is on all the time is this eating our electricity?
  • cdoher2 Dec 17, 2008
    Hi Skeemo, were you able to sort out your heater? If so what did you have to do?
  • Anonymous Feb 19, 2009
    The red light is on all the time; I too understood that this light was supposed to come on to show that the heater was storing heat at night-time during night-saver rates. I changed the fuse recently after it blew and that seems to be when the problem started.
  • 3 Answers
Hell Yes, my electric bill was 200.00 ave. a month last yr
Posted on Dec 17, 2008
Do Dimplex XT C Storage Heaters contain Asbestos?
Probably a little bit late to be answering this now, but no they do not contain asbestos.
You could have received an answer to this within about 5 minutes by calling Glen Dimplex direct or even any electrical wholesaler
Mar 06, 2015 | Dimplex Heating & Cooling
Dimplex DS3311 switch is overheating and melting. What to do?
How long does it take before the switch melts?
You could try retrofitting a switch from the hardware store that has a higher watt/amp rating...
Jan 16, 2013 | Dimplex Heating & Cooling
Hi, I have recently moved into a new flat with simplex storage heaters, however the letting agent has no idea how to use them and the landlord is away. They seem to be really old models which you turn on...
Here is a link to a video that will help you understand the theory of how the Dimplex Storage Heater works. It may be a little newer than the model you have, but it does the same thing.
http://www.youtube.com/watch?v=bXrbk-cPWG0
I hope this was of help to you and tanks for choosing FixYa.
Sep 20, 2011 | Heating & Cooling
Hi - I have an old Glen Dimplex CLX (I think is the name) wall heater. The switch for turning on the heater broke 2 days ago. It sounded like a fuse blew. How on earth can I get this fixed?!
You say the heater is 'old', so I assume that it's out of its 2 year warranty? Are you referring to the wall-switch or the switch on the heater itself?
The customer service department will be able to give you guidance on finding the problem and resolving it. If you call 0845 600 5111 and have your series number (top left of the unit) and model (CXL) to hand they will be able to help you.
P.S. Please don't try to take the heater apart or remove it from the wall unless you have experience in working on storage heaters, as the unit is VERY heavy!
Nov 16, 2010 | Dimplex DXLWP400 Electric Wall Mounted...
Wiring diagram for Dimplex wall heater Model 6100770000
installing a wall mount heater not sure on the wiring .heater has 3 wire black red and blue sources has white and black what wires go together
Jul 16, 2010 | Heating & Cooling
Dimplex oil heater FR24. 2400W oil heater. shorts fuse box
I would suggest that the element may have absorbed some mloisture whilst being left in storage for a period of time. You may need to take it to a local repairer to see if they can dry out the element.
If there is moisture in the element it is not safe to use, hence it trips your circuit breaker.
May 27, 2010 | Dimplex Heating & Cooling
My dimplex night storage heater is not heating up, the power supply is fine. Is there a fuse or trip switch anywhere
thermal heat line melted just 2years 3 weeks old should this heater have been recalled some were put in by the warm front scheme frozen old age pensioner
Dec 19, 2009 | Dimplex Heating & Cooling
Hi, Last night none of the Dimplex storage heaters in my home came on. I checked the fuse box and nothing has been trippped. They were working fine the night before and I cant think of any reason why they...
It may be that the off peak to your house has failed to switch on, possibly due to the off peak time switch in your meter cupboard not working, I suggest you contact your local electricity board and ask them to check your off peak supply
Dec 15, 2009 | Dimplex DS5603 Heater
Hi, I don't understand how the early and late boost works on the storage heater. Someone told me I should turn the output switch off when I am at work during the day, then turn the output control up when I...
Output switch is the one that says Cool-Off-Heat. Turn this offwhen you aren't home.
Output control is the thermostat. If you want to heat the room turn up the thermostat to the desired heat after putting the output switch on heat. It will take a few minutes for the heater to get hot. Early boost would be if you want immediate higher blower speed to speed up keep the heated air from being too hot and late boost will hold off the fan until the heater is higher in temp and the air temp discharged will be hotter.
Nov 19, 2009 | Dimplex DS5603 Heater
Dimplex DS5603 Heater Logo
253 people viewed this question
Top Dimplex Heating & Cooling Experts
Paul Carew
David Burbee
David Burbee
Oloyede Monsuru
Are you a Dimplex Heating and Cooling Expert? Answer questions, earn points and help others
