Question about Maytag Ensignia 3.3 cu. ft. Top Load Washer
Clothes are still wet after spin cycle
Brand new Maytag Ensignia. I washed for the first time and thought the clothes were wetter than normal. Continued to do the laundry and then realized for sure that after the spin cycle the clothes were filled with water and soap residue. I put on the additional spin cycle and it did no better. They were still just as wet. Tried to find another washer but they didn't have one and repair man can't come for a wk. Very upset.
  • 4 more comments
  • Anonymous Jan 26, 2008
    Same problem, however, have checked drain & this is clear.
  • Anonymous Mar 20, 2008
    All water is out of tub after spin cycle stops, but water starts dripping into the tub from the supply valve at the top so that clothes are wet if they sit after spinning. Solution is to put back into spin mode, after clothes start spiinning, interrupt the spin mode and quickly remove them before more water can run in.
  • fhig Apr 28, 2008
    After cycle is complete, water drips from above and will fill the tub back up. Just started happening last week. GOtta get those clothes out fast. Whats the part that needs to be fixed? Maytag Ensignia.
  • valkyra_mo Aug 11, 2008
    Yep...mine too is full of water after the spin cycle...obvious design flaw....tried the double spin and all....any others want to take a shot at this?|
  • Anonymous Mar 13, 2014
    does not dry on spin cycle
  • Anonymous Mar 23, 2014
    the washing mahine spins and water drains out but the cloths are still very wet even after spinning them again the residual water seems to stay
45 percent...wait for the next service bulletin...55 percent installation...or both ....100%...that's the formula and also forget to read the use and care...trifecta of **** thats the ("FixYa!")
Posted on May 28, 2008
    President:
  • 1,462 Answers
Possibly not a machine fault. if drain is connected to sink plumbing, remove the drain hose and see if it pumps out into a bucket.
Posted on Mar 26, 2007
I have a maytag frontload washer 2000 series that will not start spin cycle won't even try unless the washer is empty. no error codes showing, even after I do diagnostics. help...wife is miffed..
After determining that the washer is plugged in, the drain hose is free from kinks, the "No spin" option is not selected and the washer door is securely closed, the cycle should be reselected to see if the washer will spin. If this does not solve the problem, it is advised to contact a trusted repair service. Problems with the lid switch assembly, drive belt, drive pulley, drive motor, tub bearing or transmission can also cause a Maytag washer not to spin. These repairs should be carried out by a professional.
If the washer is spinning but clothes are still wet at the end of the cycle, one should ensure that the washer is not overloaded or unbalanced and that the correct wash cycle is selected. Delicate or handwash cycles spin at a lower speed, resulting in wetter clothes
Oct 12, 2016 | Maytag Washing Machines
Why does the Drum spin erratic even without clothes in it?
might be a warped spin basket or the dampers could need to be replaced. could even be a bad spin bearing. if it was bearing, normally would be associated with a loud noise during the spin cycle though.
Feb 27, 2015 | Maytag Ensignia MAV2757AWW Top Load Washer
My washer is still spinning the cloths but the clothes are much wetter that they used to be after the spin cycle. Any ideas of how to trouble shoot?
Check your belts and also check the drain hose to be sure it is pumping the water out at a good pace. Hope this helped.
Jun 08, 2011 | Maytag Ensignia MAV4758AWW Top Load Washer
My Maytag Ensignia is filling with water then stopping. If I manually move it through the cycle it does nothing. Won't spin or drain. There is no noise when it goes to the agitate or spin cycle (as if it...
f the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it. You will need a putty knife to release the clips located of the front corners of the of the lid. If you look along the seam of the top and the front panel, just near the corners, you will see them. Just push in on the clips and lift the top to access the switch.Here is a link to the part.
Jan 04, 2011 | Maytag Ensignia MAV3757AWW Top Load Washer
Maytag ensignia makes a great deal of noise during rinse cycle
"If you dont have a noisy spin cycle and the noise you hear is only on the rince cycle, dont be worried, as this is totally normal. Water sprays onto the drum while the spin cycle is in progress and rewets the clothes to allow any existing soap to be desolved. This noise is in effect the water hitting the drum during the rince part of the cycle.
Sep 03, 2010 | Maytag Ensignia 3.3 cu. ft. Top Load...
Maytag top loader on final spin cycle leaves the clothes soaked
how much water is in the bottom of the tub and is it louder than normal if so could be small droplets of water leaking from tub seal if not the pump is restricted by something and req replacement
Aug 20, 2009 | Maytag Washing Machines
Spin cycle not working like it should
If the washer doesn't reach it's proper spin speed, the clothes may be wet at the end of the cycle. Since you have replaced the belt, it could be that you have a worn motor pulley or tub bearing. Check for damage to the pulley and shaft and for free play. Also make sure that there are no clothes or foreign objects caught between the inner and outer tubs or something causing friction on the drive train. Hope this helped.
Jul 16, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Spin cycle not working properly
On the transmission there are two shift arms. One shift arm controls the agitator and the other shifts to spin the cloths. If the washer has been making a "clicking" sound when it trys to spin, the solenoid that shifts the spin shift arm is not catching and the drum will not spin. The other possibility is the spin clutch is slipping and make a "grinding/ratcheting" sound. Neither, unfortunately are inexpensive to fix.
If you can describe the sound and when it occurs, I might be able to get closer.
Let me know.
Regards,
May 15, 2009 | Maytag Ensignia MAV4757AWW Top Load Washer
Maytag Ensignia 3.3 cu. ft. Top Load Washer Logo
539 people viewed this question
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
