Question about LG 42PC3DV 42 in. Plasma EDTV
TV shut off and won't turn back on??
My plasma is about 2 years old and it shut itself off. When I try to turn it back on you can hear the switch or "click" trying to come back on. The light on the front turns green and then it turns itself back off. So the light turns red again. Could it be something in the switch and how can this be fixed???
-Thanks
  • dturman Jan 30, 2009
    i have the same problem walked out the room and when i return the tv was off what could have caused this
  • LG Master
  • 2,778 Answers
The voltage rating of a condenser is not the voltage you can expect to find if you take a measurement across it, its the maximum voltage that can be safely applied, generally capacitors are rated at about 85% by engineers, although this isn't always true but a typical capacitor rated at 400VDC would have 340 to 360 volts across it.
Posted on Nov 10, 2017
  • Larry Nov 10, 2017
    Now to get to your problem, unfortunately a plasma TV is more complicated to service, they have about double the amount of boards and almost every board has a separate power regulator on the board. If your comfortable doing it pull the back off and get the voltages coming out of the PSON, it should be either a volt or 2 and go to around 5 when the power button is pushed or it will be at 5 and drop to a volt or 2, if that voltage is correct then we can go into some other tests, if its not right then it sounds like you have a main power supply issue. Here is the service manual for this set and it does have flow charts in it for troubleshooting but they can be kind of complex sometimes.https://www.manualslib.com/manual/818452...
    Habit-Forming:
    Scholar:
  • 122 Answers
Sounds like my Samsung. Searched web and said to check the capacitor (good thing there was only one capacitor) rated at 100 uf at 450 volts. Measured at the capacitor - has only 380 volts. Have a 150 uf and 220 uf at 400 volts. (Samsung's capacitor was 450 v.) Worrisome, yes. Tried all combination, but only 150 uf plus the 220 uf would work. Measured 390 volts.
Posted on Nov 07, 2017
  • 45 Answers
SOURCE: plasma won't stay on red light flashes and shuts unit off
I had similar problem with 42fd9932, run for a few secs or minutes, shutdown and flash red led for ever. Fans in this unit were not causing shutdown although I could stop one and get the red led flashing thing.
Replace c2212 100uf, c2508 4.7uf changed to 10uf, c2664 100uf. I also added clip on heatsink to U7203 8.5v TO-220 case regulator( next to c2212) and a drop of oil to each fan(poked a hole through label center). Something else I did was add a 47 ohm 5w in parallel with fan ps 100 ohm 5 w resistor.
These parts are all located on the two power supply boards. Use Caution 380V is present on these boards. Allow a few min for caps to discharge.
Posted on Nov 04, 2007
pizzaguy3274
  • 4 Answers
SOURCE: 42pf9956/37 philps plasma
I don't know why but this got my TV on.
I took off the back cover and found the source of the clicking.
Two blue plastic rectangular relays in the exact middle.
When I pushed the power button, I felt the top relay click, and I saw a flash from the bottom one. (they are right next to each other)
I took a hair dryer and placed it over the two relays for about 1 minute and tried the power.
It clicked only 4 times and then came on!!!!!!!!!
For some reason heat helps the relay.
If anyone is a tech and can explain this, please do.
Good luck!!!!
My tv is on and it didn't cost me anything.
I just can't turn it off now!!!
Posted on Apr 11, 2008
SOURCE: Lg tv will not turn on, red light
i think your bulb is shot must be replaced
Posted on Apr 29, 2008
SOURCE: 52" plasma tv - turns on - and I hear something reset inside
i hear a clicking noise- the clicking noise is most likely you ballast trying to power the lamp, but failing. this may indicate a defective ballast if you have recenty purchased a new lamp.I recomend you have your lamp tested to help narrow down the cause of the defect. It's highly unlikely for a new lamp to be dead on arrival
Posted on Dec 21, 2008
  • 135 Answers
SOURCE: Lg 42pc1da plasma tv wont turn on
will be a fault with either power or y-sus x-sus board is the tv still under warrenty if so request repair
Posted on Jan 18, 2009
Hitachi 55" plasma TV. 5 years plus old, used a
Please let me know whats the model number of the tv so that I can tell you what the PCB LED diagnostics are pointing to. It sounds like a power supply or Main board issue so I would like to confirm which one of them it is.
Dec 22, 2011 | Hitachi 55HDS69 55 in. Plasma Television
I have a 1 1/2 year old Panasonic TC-P42U1 plasma tv. While watching a show, it suddenly shut off and won't come back on. What do you think caused this and how can i fix it? Thanks.
Try unplugging it completely for 30 seconds to 1 minute. Plug it back in. If it still won't come on, it's likely taken a power surge and popped a fuse or power supply, which means a trip to the service center.
Jun 18, 2011 | Panasonic TC-P42U1 42 in. Plasma HDTV
50" plasma panasonic 720p tv has several colored
Flashing error codes could be the Direct tv box itself.Because tvs have problems within itself don't flashes error codes on the tv screen,the problems,just show up.Tries tv and Direct tv satellite box unplug,replug it back like about an hour later.By letting the tv resetting itself back to the factory setting and the Direct tv box updates it softwares data's.The problems should be solved,if have the same problems,first call Direct tv for a replacement box,see how it work out.Than turn ur attention to the tv.
Feb 08, 2011 | Panasonic TC-P50X1 50 in. Plasma HDTV
3 YEAR OLD SANYO DP 32746. SHUT ITSELF OFF, CAN NOT TURN BACK ON
If you leave the tv unplugged for 2 days (atleast) then plug it back in and try to turn it on and if it comes on its the power supply board. If it comes back on it will probably shut off between 30min to 4hrs and you would have to unplug it for 2 days again. All the power needs to drain out of the tv. If thats the case take the back pannel off and check the part number out on the internet. Not hard to do becarefull touching things the power supply does store a little bit or shock in it. Good Luck.
Dec 13, 2009 | Sanyo DP32746 32 in. LCD Television
I have a Fujitsu 42'' PDS4221 - 10 years old - shuts itself off
See Fixya tips and tricks:-
'Fujitsu Plasma 42" random shutdown - continuous flashing red'
While the model of your set is slightly different, the checks described generally still apply, as it is very similar.
Nov 18, 2009 | Cars & Trucks
Tv turns it self off after only 2-3 seconds and makes crack noise
Since the set is less than 1 year old, it should still be under warranty. Request warranty service.
The noise you are hearing is probably arcing inside the set on the power supply board. Continuing to attempt to turn on the set will only make things worse. Please request warranty service as this is unusual for a TV that new.
Dan
Jan 16, 2009 | LG 50PB4D 50 in. Plasma HDTV
TV suddenly shut off, blinking red light in power button
The TV's power supply capacitors probably went bad.
Check with a mobile tv repair co. to see if it is worth fixing.
Dec 20, 2017 | JVC GD-V502U 50 in. Plasma Television
Panasonic 50 inch Plasma
it could have over heated you can try to reset it first unplug it for about five minutes and try to turn it on if that dont work the remote might have a set button try holding that down until the red light flashes twice, then turn it on if not then hold the power button down on the set for a good five seconds to see if that resets it. if none of that works you will have to go to panasonic .com for the reset instructions.with the red light blinking the power supply is most likely good you just need to reset i.
Dec 24, 2007 | Panasonic TH-42PD50U 42 in. Plasma EDTV
LG 42PC3DV 42 in. Plasma EDTV Logo
208 people viewed this question
Steve Allison
Steve Allison
