Question about Air Tools & Compressors
Motor rotation we have recived a ssr-ep15 with no manual I dont know the proper rotation of the moter and dont want to start it
  • 3 Answers
Kindly note that what ever motor it be, it runs from left to right ( clockwise direction)
Posted on Dec 17, 2008
HAVE A SSR 15-50HP SCREW COMPRESSOR WITH GC-14 INTELLISYS CONTROL KIT AND IT SHOWS "REV ROT MOTOR" WHAT THIS MESSAGE MEANS?
This is letting you know the motor rotation is incorrect. If this is a new unit or has just been installed or other rewiring work done in your plant etc. you need to get your electrician to roll 2 of the 3 incoming power leads. If this compressor has been in service and operating you have a vacuum switch or transducer possibly bad. you also need to check the transducer line or vacuum switch line ( both are normally 1/4 inch plastic tubing) for tightness and leaks. For example the line has rubbed a hole in it. When you try to start the unit the transducer does not see the required vacuum. The controller interrupts this low or no vacuum as the rotation is incorrect and thus gives a check motor rotation alarm and shuts down.
Feb 22, 2011 | Ingersoll Rand Stationary Air Cooled...
I have an Ingersol Rand SSR-EP40SE Rotary screw Air compresor. We ordered a new control panel for the unit because the old panel had a burnt resisitor. The new panel was installed and wont start the unit...
First you need to program the controller. Controllers do not come programed for a specific compressor. You will need to enter factory set point and and set all parameters. Horse power, pressure, DOL start or wye delta start etc. The new controller is probably set incorrectly. Look at factory set points on the old controller and copy all the parameters and then set the new controller to those set points.
Sep 06, 2010 | Ingersoll Rand Stationary Air Cooled...
My boat lift electric moter was replaced... it now run slow or needs a manual assist to start... what is the problem? Current level?
check input voltage check to see if its the proper phase check tension on belts, gear, or connection from motor
May 28, 2010 | Leeson Reversible Electric Motor 3/4 HP
I have a EP15-SE I have a code on the screen
T2 represent for temperature sensor. Check sensor at the bottom of air end.
Feb 16, 2010 | Ingersoll Rand Stationary Air Cooled...
My old GE potscrubber 700 dishwasher stopped working
moter has probably locked up TAKE FRONT LOWER PANEL OFF AND YOU CAN ROTATE ROTOR/ if itis not free and rotates easly then the motor has failed / mm
Dec 07, 2009 | Dishwashers
Ingersoll Rand SSR compressor shuts down loaded or unloaded with no alarm, and then shows ready to start . Will not run more than a few minutes either loaded or unloaded. installed meter on incoming power...
When it shuts down, press DISPLAY SELECT button once and use the up down arrows to see the code just before shutdown.
HIGH AIREND TEMP
HIGH AIR PRESSURE
LOW SUMP PRESSURE
PRESSURE OR TEMP SENSOR FAIL
CHECK MOTOR ROTATION
MOTOR OVERLOAD
FAN MOTOR OVERLOAD
STARTER FAULT
I am assuming this has a Intellisys controller.
Aug 25, 2009 | Air Tools & Compressors
Need a services manual with codes and fixes
E000 : The main thernistor is opened.
E001 : Thermistor in short circuit.
E002 : SSR faulty
E003 :SSR and PCB faulty
E004: SSR in short circuit.
E005: Fixing web taken up.
E010: The main motor defected.
E012:Drum motor blocated.
E013:Wastw toner feedscrew faulty.
E014:Fixing motor defect.
E020:Hooper motor failure.
E032:PCB defect.
E061:Laser unit faulty.
E100 :The DC controller PCB malfunction.
E110:Laser scanner motor defect.
E121:M4 cooling fan defect.
E196: EEPROM faulty.
E202:Scanner home positin faulty.
E204:ADF controller faulty.
E220:Lamp inverter faulty.
E225:Xenon tube malfunction.
To reset in service mode press COPIER-FUNCTION-CLEAR-ERR.
Aug 11, 2009 | Canon imageRUNNER C6800 Copier
Blower moter fan
Before attempting to remove blower, run the motor and note the direction of rotation. The blower wheel can be very difficult to remove. It is screwed on to the motor shaft opposite to the motor rotation such that every time the motor starts, the blower wheel gets tighter. The best way to remove, is to put an adjustable wrench on the blower wheel (from the motor side) and using another wrench or locking pliers on the side of the motor shaft where the belt goes. Rotate the motor shaft where the belt goes, in the opposite direction of normal rotation while holding the wrench on the blower wheel. It will be VERY TIGHT. If unsuccessful, the only alternative is to strike the blower wheel REALLY hard and break it off. GOOD LUCK!
If you need further assistance, let me know
Regards,
reg501
Jul 07, 2008 | Whirlpool LER5636P Electric Dryer
Air Tools & Compressors Logo
125 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
