Question about Maxtor DiamondMax D540X 100 GB ATA-133 Hard Drive
How can I detect maxtor 3200 ide as slave
I removed seagate 160gb and connected into secondary drive but it can't detected. what do I do?
  • 26 Answers
Somewhere on the harddisk, you should be able to see a label indicating jumper settings. Check that the jumbers are set to slave sattings.
Posted on Dec 18, 2008
Bios not recognize new hard drive dell ide
The problem is with your BIOS settings. You need to make sure the drives are set to AHCI in the BIOS.
Sep 21, 2013 | Dell XPS Computers & Internet
I have a 250gb seagate sata but when i put my 80gb IDE hdd it only detects in booting and in bios but after that if i open my computer i cant see my 80gb IDE Hdd and even in device manager my hard disk was...
there was wrong in the set up of jumper in your 80gb hdd. Look closely to the 80gb harddrive, in between the ide cable terminal and the power supply connector you will see 8pin terminals paired together and a jumper use to short the paired terminals. It is most likely that the jumper was configure to detect your hdd as master. If the ide cable you use for the 80gb hdd was also use for the dvd/cdrom drive then it will conflict with it if both jumper setting was set to master. See the description of jumper settings in the sticker of the hdd. Position the jumper to slave.
Reboot your system again and see if the 80gb finally appear in your system. When system boot upon detection of hdd, the primary master should be 250gb while your primary/secondary slave will be read your 80gb hard disk.
Jan 24, 2011 | Seagate 80GB 7200 rpm SATA/150 8MB Serial...
What happen if i dont put jumper in a hard a hard drive?
If you don't put jumper in harddrive is detects it as cable select means if you connect your harddrive to middle socket of ide cable and then it detects it as slave but if you connect it at the end of ide cable it detects as slave.But make sure that otehr device is not set as master only 1 device is set as master or slave .
Let me know if you need further assistance.
Thanks for using FixYa.
Jun 01, 2010 | Seagate U6 (ST340810A) 40 GB Hard Drive
I am not able to instal OS in my home PC. Asking me to install scsi drive. my hard disk seagate. where download this flopply disk bios drive software
hi
Checked the Bios Setting and check whether the Hard drive is recognizing or not -
Check the Boot sequence
Check Boot from the CD Drive
Format the Hard drive
it will work
Feb 23, 2010 | Seagate 500GB Maxtor Diamondmax21 SATA2...
Was burnt out can I save files how can I
If the drive works independently of the case then yes you'll be able to recover your info. The drive must be removed from the case and then slaved onto another hard drive either using a USB bridge or connecting as a secondary IDE drive.
Apr 02, 2009 | Maxtor Personal Storage 3200 (U01E200) 200...
How to detect the hardrive?
setup the first drive as slave ( sometimes No Jumper ) then the furthest away drive as Master.
If this fails, and you have 2 IDE Slots on the motherboard. ( Primary/Secondary ) Put 1 drive on primary as Slave. And DVD Rom As Master ( same Cable ) Then put second drive On Secondary IDE Slot. ( Set As Master Or Slave )
If none of these solutions Work For you, check to see if Both Channels are activated in the Bios.
Thankyou For Using Fixya.
Mike @ compurepair.
Jan 28, 2009 | Maxtor Hard Drive
Dual seagate hd on pl 2506 controller, only one drive detected.
yes it does matter what second one is jumpe dto it must be slave on middle of ide cable end of cable master one slave on sec drive do it
Oct 12, 2008 | Seagate HDD 40GB 7200RPM ATA100 2MB...
Damn windows wont detect it
http://seagate.custhelp.com/cgi-bin/seagate.cfg/php/enduser/std_adp.php?p_faqid=4996&p_created=1194886713&p_sid=D7lFEhVi&p_accessibility=0&p_redirect=&p_lva=&p_sp=cF9zcmNoPSZwX3NvcnRfYnk9JnBfZ3JpZHNvcnQ9JnBfcm93X2NudD0xNDg2LDE0ODYmcF9wcm9kcz0mcF9jYXRzPSZwX3B2PSZwX2N2PSZwX3NlYXJjaF90eXBlPWFuc3dlcnMuc2VhcmNoX25sJnBfcGFnZT0x&p_li=&p_topview=1
click on the flash guide
Jan 09, 2008 | Maxtor Hard Drive
Asus a7n8x deluxe
Please make sure your HDD are in proper configuration. An IDE device have two cofigurations. Master and slave. Any motherboard will have two IDEs. Primary and Secondary. You can connect two drives to one IDE in Master and slave configuration. This is determined by setting a small pin called jumper setting. You should visit the following website to know more about setting jumper for a Hard disk. http://www.seagate.com/www/en-us/support/installation_assistance/jumper_setting_illustrations/ http://www.seagate.com/ww/v/index.jsp?locale=en-US&name=ATA_Jumper_Settings&vgnextoid=cbc974850ce0e010VgnVCM100000dd04090aRCRD This way you could solve your problem.
Sep 26, 2007 | ASUS A7N8X-E Deluxe NForce 2 Ultra 400...
Seagte purchased Maxtor in 2006. They kept the group that supported these products intact. Check Seagate's support site for specific information and/or contact Seagate's support group. They should be able to help you. The website is: http://www.seagate.com/www/en-us/support... As a last resort, you can get a free replacement from Seagate via their warranty repair group. They track via serial numbers, so no receipts should be needed.
Sep 28, 2006 | Maxtor Personal Storage 3200 (M1227310)...
Maxtor DiamondMax D540X 100 GB ATA-133 Hard Drive Logo
169 people viewed this question
Top Maxtor Computers & Internet Experts
Computer Links
Phil Whisenant
Phil Whisenant
Alun Cox
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
