Error Code SC570 for copier Aficio 1224C
My copier ran out of fusing oil and has began displaying error code SC570, the fusing oil has been replaced but copier is still displaying the error code!!
  • 2,794 Answers
It could be covering the sensor. Clean the fuser oil sensor off and see if it goes away.
Posted on Dec 17, 2008
The Fuser oil like all consumables has a pre-determined value in the Nvram. .Check and reset oil counters in Pm Reset mode.Ps not just the pm reset but the oil counter reset value ,then reset machine and sc570 will disapear.Before this code arrived i would guess that oil level low was displayed and refilled but not reset.Typical non trained tech scenario catches em out every time
Posted on Jul 27, 2012
Imprimente ricoh afico 1224c sc670
SC 670 - Engine response error.
After powerig on the copier machine,a respons is not received from the engine .possible defect controller board or SBCU installed incorrectly.Try reset the code to turn ON/OFF the main power switch.
Mar 01, 2013 | Ricoh Aficio 3232c 3214c 1232c 1224c Oil...
Ricoh (Aficio) 1224c. code sc670 we want to decode this codesc670
Hi, it looks like a bad controller board. Try resetting it from in service mode with 7807. Also if you can view or printout the error history with 5990-004 for further trouble shooting. Hope this helps
Aug 03, 2011 | Ricoh Aficio 1224C Black and White Copier
Ricoh Aficio 1224c error code SC 544
Well, I have no idea why changing your password would affect it this way. the code you're experiencing is a fuser warm up error, due to blown fuse, thermostsat, possible power supply prob...regardless, it can only be reset by a service tech in service mode once the problem is fixed. Sorry.
Mar 05, 2009 | Ricoh Office Equipment & Supplies
Aficio 1224c copier sc 571
SC 571 is a fusing error caused by not being seated properly or the oil sensor is coated with oil.
More than likely when the machine was move oil coated the senor in the fuser and it has to be taken apart to be cleaned.
Sep 22, 2008 | Office Equipment & Supplies
Error code SC305 for Photocopier Ricoh Aficio 1224c
Its a charge corona cleaning error. Try turning the power off, wait 10 seconds and turn it back on.
If that doesn't reset it, it could be the pcu, toner collected on the mechanism.
If turning it off and back on isn't fixing it, you should get a technician to look at it to see what the trouble is.
Jun 18, 2008 | Ricoh Aficio 2015 Copier
Error code SC305 for copier ricoh aficio 1224c
This SC code relates to the charge corona cleaner not working or not working properly. the charge corona is located towards the bottom left of the machine after opening the front cover. It will have a screw you can undo by hand and a cable with an end like a telephone cable plug. toner may have fallen in to the unit or the motor that drives the cleaner along the wires has decided to jam up. remove the charge corona and blow it out with compressed air. You can also remove the end of the unit and check that the motor is not gummed up. Be very careful you do not break the hair thin corona wires! Hope this helps.
Dave T
Jun 18, 2008 | Office Equipment & Supplies
987 people viewed this question
jasbo
jasbo
