Question about IBM (03R0329) Motherboard
Ibm bios problem
I have ibm (82845) system. first time when i switch on the cpu, the power LED is glowing ON but on display. i need to press the power switch untill the power LED is OFF. once i press the power switch
the led automatically goes OFF within 5 sec. third time i need to press the power switch , then only the system gets ON.
the same problem is in more than 30 nos of systems.
pls help me to solve this problem
thank you
  • msumil Jan 04, 2009
    Can you please describe the model number (or model name) of IBM pc (like Televista)? B'coz I have also same problem and I am searching for a Bios Chip if You have number of same model PCs you can get the Bios Chips flashed by an expert or flash the another chip compatible to BIOS and then place the same on the M/B
    Milind
    milind.chutke@gmail.com
  • buenso80 Apr 04, 2009
    Did you find a solution?
Ibm i845 bord date & time save nahi hota cell b change kia ha pls solve problem thx
Posted on Feb 09, 2011
The capslock and the numlock leds r flashing continously. the screen is blank
How many blinks between pauses if there are pauses? Look at this chart.
Number of Blinks or Beeps Location of Blinking LEDs Component Being Checked Error Condition Continuous glow Battery power LED Battery The AC adapter is attached and the battery is charging, but does not yet have sufficient charge to power the notebook. 1 Caps Lock/Num Lock CPU CPU not functional 2 Caps Lock/Num Lock BIOS BIOS corruption failure 3 Caps Lock/Num Lock Memory Module error not functional 4 Caps Lock/Num Lock Graphics Graphics controller not functional 5 Caps Lock/Num Lock System board General system board failure 6 Caps Lock/Num Lock BIOS BIOS authentication failure Continuous blink AC power adapter LED Power adapter Insufficient power
Jun 30, 2011 | Compaq Presario Notebook
When i turn on my hp the screen stays blank and there is no pic screen seems dead the lock a button is also flashing is this normal
hi,
nope this is not normal. I have a article included below from hp. read this and you will understand the problem and also some ways on how to fix it. The blinking lights is a code on where the system fail or what component that fails.
Hope this helps you.
Don't forget to rate me OK!
Thanks for using Fixya!
regards,
John
HP Black screen error codes
Support details
This document pertains to HP Notebook PCs with the HP Unified Extensible Firmware Interface (UEFI) beginning in late-2008.
On startup, you may see a blank screen. If the diagnostic utilities detect a specific problem with hardware components, the fan turns on, but the screen remains blank. To help identify the cause of the problem, various LED lights on the keyboard blink a series of codes.
The diagnostic utilities use the LEDs near the Num Lock or Caps Lock keys to blink a series of error codes. At the end of the series the blinking stops. The pattern of blinks will occur any time you attempt to start the computer until the error is resolved.
Battery power LED blinks
The Battery power LED indicates the condition of the power supply. When starting the computer, or when the computer is in operation, use the chart to identify the power condition.
Battery low charge or failure
Battery power LED blinking Battery Insufficient charge on the battery
LEDs near Caps Lock and Number Lock keys blink when starting notebook
The LED lights near the Caps Lock and Num Lock keys will blink if an error is detected during the start up process. The LEDs will blink a number of times in a sequence and then stop. The number of blinks in the sequence indicates what component caused an error when it was being tested during start up.
If the LEDs stop blinking and the computer does not start, you can press the power button again to repeat the tests. Count the number of blinks, and use the chart to identify the error condition.
Knowing the number of blinks is helpful when you contact an HP support agent for technical help.
Caps Lock/Num Lock LED Component Tested Error Condition
LEDs blink 1 time CPU CPU not functional
LEDs blink 2 times BIOS BIOS corruption failure
LEDs blink 3 times Memory Module error not functional
LEDs blink 4 times Graphics Graphics controller not functional
LEDs blink 5 times System board General system board failure
LEDs blink 6 times BIOS BIOS authentication failure
Error code explanations
The sections below provide some common explanations for each error code listed in the table above.
AC Adapter not connected or battery low charge
When the computer is on battery power only and the AC adapter is disconnected, if the Battery Power and Caps Lock / Number Lock LEDs do not glow, there is either a very low change or no charge in the battery. Connect the AC power adapter, verify that the battery power LED glows, allow the battery to charge for 15 - 30 minutes and then attempt to start the computer. If it starts, run the battery test and calibrate the battery. If it does not start, if possible, connect a replacement battery to verify that the battery is the problem.
If the computer does not start after charging the battery, remove the battery and connect the AC power supply. Verify that the battery power LED glows, and then attempt to start the computer. If the LED still does not glow, either the AC adapter has failed, or there is a bad connection between the adapter and the system board. If possible, connect a different AC power adapter to verify that the adapter is the problem, or contact HP for support which may require a service event.
showhide
If the battery light LED (which looks like a lightning bolt ) flashes, the battery has insufficient charge to start the computer. To resolve this error, try the following solutions.
Connect the notebook PC to AC power and attempt to start the computer again.
o
Check the AC adapter to confirm that all of the plugs are securely seated.
o
Determine if the power LED on the AC adapter is lit (if available) to verify that the computer is receiving AC power from the wall outlet.
If the computer operates on AC power correctly, charge the battery for thirty minutes to one hour and then restart the computer.
NOTE: Charging the battery for this length of time is called "trickle charging". Trickle charging is a continuous constant-current charge at a low rate, which recharges the battery slowly when it is in a deep discharge state. Deep discharge occurs when a battery is left unused for extended periods of time.
The computer processor (Blink code 1) has stopped functioning properly. Contact HP for assistance.
If a BIOS corruption error occurs (Blink code 2), you may not even notice the blink codes, because as soon as the computer recognizes the error, it restarts, attempts to recover the BIOS, and then restarts again. You may notice an extra-long startup process as a result, and a message indicating that the BIOS has been recovered may display on startup. If this occurs, update the BIOS on the computer. For more information, refer to the HP Notebook PCs - Locate and Install Updated BIOS, Drivers, and Software .
If you experience a memory failure (Blink code 3), follow the guide in the table below.
If Using Original Memory If New Memory Is Added
Reseat the memory.
If reseating the memory does not resolve the problem, try replacing the memory with new memory. Reseat the memory.
If you continue to experience this error code after reseating the memory, the problem may be with the memory itself. Take the new memory out of the computer, put the original memory back into the computer, and then retest it.
If you do not feel comfortable reseating the memory yourself, take the computer to a computer retailer and ask them to reseat it for you.
NOTE: Some memory module errors may allow the computer to start but will then cause the computer to restart and display a blinking error code.
If you experience a graphics controller failure (Blink code 4), contact HP for assistance.
A general system board failure (Blink code 5) is the failure of a component not covered by the other LED error codes. Contact HP for assistance.
The BIOS authentication error (Blink code 6) is extremely rare. It is the result of a discrepancy between the BIOS and the hardware that is installed on the computer. This error occurs when the BIOS cannot authenticate signatures from the hardware on the system. The purpose of the BIOS authentication is to be sure that no one has tampered with the BIOS on the computer.
If a BIOS authentication failure occurs, the computer automatically performs a BIOS recovery. If the computer does not automatically recover the BIOS, manually perform a BIOS recovery. To manually perform a BIOS recovery, press all four arrow keys at the same time to cause the BIOS to go to the EFI partition to find and recover the current BIOS.
Jan 17, 2011 | HP Compaq nc6220 Notebook
My fan is running but it won't load windows. The monitor says power saving mode
Check the NUM LOCK led status when power on the computer if it is on and off when you press num lock key that means your cpu is working fine only issue with screen resolution for that when you power up th computer press F8 key 5 to 6 times then you can see safe mode and other menu.Enter in "enable vga mode " then go to display settings change scree resolution to 1024*768 then check. but if num lock led stay constant then open cpu cabinet cover reconnect RAM memory.Pull cmos cell from motherboard for 10 minutes then put it back. Reconnect pci or vga card if any. Reconnect processor and it's fan. Make sure motherboard is not ground with cabinet.Also make sure harddrive is recognized in bios if you are able to see bios. For that when you power up the computer press F1 or F2 or del or ALT+F2 key to enter in bios then check. Let me know if you need further assistance. Thanks for using Fixya.
Dec 11, 2010 | IBM ThinkVision L170 17" LCD Monitor
IBM X3400 Server Power Led Blinking and Pressing power SW, Machine not power up.
hi,
Welcome to Fixya
1: Check whether the power switch has any problem 2: Check Ac and DC led on smps is glowing 3: If it glows , probably the planner(Motherboard ) has the problem
Thanks
Nov 23, 2010 | IBM x3400 Server
My cpu green led is glowing but monitor screen is black and keyboard led is continue glowing
There are No display in your system .Pls remove Power cable from CPU and again plug it and start your system.If display still not comes then pls remove RAM chip from slot in the Motherboard and re-install goods one and check it.if still display not come then issue with Motherboard .Its detter call vendor for repair the Motherboard.
Nov 19, 2009 | Intel Motherboard
D865GVHZ mother board Doesnt boots
If everything was working fine before, and you flashed bios unsuccessfully, then yes, if would be a bios problem.
If you didn't flash the bios you should check the connections on your monitor. If that's okay then check your memory, hard drive and cpu.
Good luck,
Hank
Aug 17, 2009 | Intel D865GVHZ Motherboard
System won't boot - show's green battery icon only
Contact with notebook repairing engineer. Might be coz of some short circuit, BIOS corruption or any malfunction of the hardware.
Regards;
Hassan
Jul 07, 2009 | IBM ThinkPad T42 Notebook
Its not booting and the Leds VRM and NMI are with amber color
VRM and NMI lights lit usually indicate an issue with CPU #2's VRM which can be replaced. Also check 5 lights on back middle of system. If VRM light is lit here remove CPU 2 and VRM and reboot system. If system boots, this was the issue...
Apr 25, 2009 | IBM eServer xSeries 346 8840 (884022U)
Last Night I use my PC for 4 hours but after that i turn off properly but when in the morning i try to on my PC it didn't turn on when i press the power button nothing displaying for me only one light is...
First of all when you switchon your PC, checkout whether your processor Fan is running. Because problem might be because of SMTP failure [Power Supply in your CPU] if its working fine and you are able to see LED glowing in *********** board, might be loose connection in your Hard disk cable.
Let me know this didn't help you out or if you need more info.
Mar 13, 2009 | IBM NetVista PC Desktop
Thinkcentre M55 8806 power on off problem
May be your computer motherboard wires connection get loose or getting moisture in wires. Or there may be some earthing problem in ur power switch. First, check the wires connection & tighten up properly. if problem persists, check the earthing by power tester. Check you RAM if it is properly tight in the jack.
Dec 26, 2008 | Computers & Internet
Computers & Internet Logo
230 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Steve Allison
Steve Allison
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
