Inoperating Carriage Return IBM Correcting Selectric II typewriter
OK!! The platen is off and the case has been removed at this time. Carriage Return and the plethora of individual performances in that general area seem to be OK, but I don't see anything out of the ordinary that would attract my attention as something broken and flagrantly seeming to need attention. I will say, this has to be the worse inside of a typewriter I have ever before seen! It is gooey, gunkey, lots of oil and fuzz beyond decription; there are layers of gunk with filth on top; it doesn't appear to have ever been cleaned. When you have a chance and make sure I'm available, perhaps we might get together for live chat and see if we might be able to diagnose where and what needs attention. I would greatly appreciate any assistance you have to offer. I do want to make this worth your time; you have gone out of your way so far, to help me. With my experience using the office machines (IBM typewriters) I have come to believe these machines have never heard of "Sloanism" or "Planned Obsolesence". I will wait on you at your convenience. I do thank you for your time and consideration in this endeavor. Raymond
    Scholar:
  • 183 Answers
You should really have this cleaned and serviced by a professional.
Posted on Dec 19, 2008
My ibm selectric ii type impression is messy and sometimes missing part of the letters. I have check for proper ribbon placement and cleaned the ball element, but the impressions are still dirty looking. ...
Left Rear chrome lever with ABCDE or - marks should be towards the typist and the red ball next to the typing ballo should be moved to a higher number. Messy printing is caused by paper not being held tight against platen(black roller)
Jan 31, 2013 | IBM Correcting Selectric II
IBM Selectric III correcting. Carriage return and
You most likely have a broken torque limiter tension spring. We have them in stock but tou must have a good mechanical ability to install.
DiclyO
216-241-0027
Jan 29, 2010 | IBM Office Equipment & Supplies
My IBM selectric II typewriter carriage stuck in right margin
Sounds like the return lever arm is not putting enough pressure on the return clutch, or the clutch is slipping. The exp key uses the same clutch but the pressure comes from your finger. Theres no way you can fix this yourself. Get an IBM mechanic.
Oct 14, 2009 | Lexmark Wheelwriter 15 Series II...
I have a IBM Correcting Selectric II and I'm having trouble clearing out the margins. Can you help?
space to the right side of the machine, hold down the tab clear key and hit return.
If the carriage stops partway back, one of the tab stops has rotated too far on the tab bar.
remove the platen and paper pan, go to the stuck stop, rotate it to the rear of the machine to line up with the other tabs
Jul 16, 2009 | Nakajima AE-710 Typewriter
IBM Selectric II typewriter stuck in correcting position
If you know how to remove the right dust cover (black inside the T/W below the carrier) next to the R. side frame is the correction set up mech. spray some WD40 on the arms especially where they pivot, they should free up.
DickyO
Jul 02, 2009 | IBM Wheelwriter 30 Typewriter
IBM Correcting Selectric II; correction ribbon frozen in front of typing ribbon.
Move the grey lever on the R. side of the carrier to the R. and remove correction tape, try the machine, if it seems to work OK install a new correction tape.
DickyO
May 28, 2009 | IBM Wheelwriter 30 Typewriter
IBM Correcting selctric II keys are jammed
It sounds like the cycle shaft is not fully in home
position. With the machine OFF, try to turn the print shaft (the steel shaft with the single groove that goes through the carriage) top towards the back of the machine. Then turn the machine on. Try the space bar first. If it works, your machine probably needs the cycle clutch spring adjusted or replaced.
Feb 18, 2009 | IBM 3500 Typewriter
Carriage return problem
If it returns with the express key the latching mech. on the rt. side is probably gummy. Take off the case, get some WD40 and spray the mechinism that latches the ret on the rt. side below the platen.
DickyO
Dec 08, 2008 | Office Equipment & Supplies
IBM Selectric II correcting won't power up
Open the upper cover, remove the platen (roller) there is a latct on each side that has to be pressed down, after the platen is out thetre are two latches one on each dide just inside the the sides of the case pull them to the front, flip the margins inside and lift the case, give the motor a little push, if it starts get a can of WD40 and spray everything inside the T/W that moves.
DickyO
Oct 01, 2008 | Office Equipment & Supplies
IBM CORRECTING SELECTRIC II TYPEWRITER
Is the key stuck in the down position? If you pull the key off you should see a spring underneath. Maybe out of position or damaged.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Aug 10, 2008 | IBM 3500 Typewriter
113 people viewed this question
k24674
Marvin
Marvin
