My Pioneer Laser Jukebox CJ-V50 has an Err1 message on it. Evan after following instructions in the manual,i am unclear as to what the error is. I have attempted to Delete and clear the error via the Service Mode but I still can't clear the "Err1" message. This is preventing Jukebox from working. PLEASE HELP!
  • cfcomms Mar 21, 2009
    same probelm with err1 message on jukebox.. please hepl
SOURCE: Toshiba Satellite L3550-S7812 - Following
Ok! I'm not an expert, but I took advantage of my Toshiba warranty and got some tech support. Fortunately, I remember what they told me to do and I wish to help. :D I have Windows Vista, so if something isn't quite the same, ask and I can probably clarify it for XP.
We will be editing the registry, so please back up your computer/set a system restore point.
First, make sure all programs and windows are closed, then open the start menu and type into the "command" into the start search field (for xp users, go to run, then type in "cmd") and press enter. This will open up the command prompt window. It's a black window.
Now, in the black box, type in "regedit" and press enter. This will open up the registry editor. We will be deleting two values from the registry in order to make the computer properly detect the DVD drive.
Once you have the registry editor open, you will have to open a series of folders to access the particular registry values that need to be deleted. It will be displayed like this:
Folder>Sub Folder>Sub Sub Folder
Please open the following folders in the registry editor in the following order:
HKEY_LOCAL_MACHINE > SYSTEM > CurrentControlSet > Control > Class
From here, you need to select the folder which is ninth from the top in the Class folder. The name of this folder is {4D36E966-E325-11CE-BFC1-08002BE10318
In this folder with an extraordinarily long name of jibberish, you will find two files entitled "LowerFilters" and "UpperFilters," respectively. Click on LowerFilters to select it then either right click and select the delete option or simply press the delete key on your keyboard, then confirm that you would like to delete it. Click UpperFilters to select it then repeat the process followed for LowerFilters.
Lastly, close all windows and restart your computer.
Your DVD-RW drive should work now. To test it, put in any CD/DVD/whatever.
I hope this helps and if it doesn't, then I apologize. I wish I could help more, but I'm just repeating the process Toshiba tech support went over with me.
Have a good one. :)
Posted on Jun 25, 2008
jackiboy721
  • 8 Answers
SOURCE: audi tt cd changer err1 message
i would try just removing the negative batterie for about 15 to 20 mins and then see what it comes up with...
Jack
Posted on Sep 10, 2008
yooperbud
  • 8637 Answers
SOURCE: Brother HL-4040 Laser Printer -- Print Unable 6A Error
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 26, 2009
taran_2005
  • 10515 Answers
SOURCE: Won't print - Screen message: "Service error 5C10
This is a VERY VERY common problem on this model. Usually this is a hardware failure - ( logic board ) which is not economical to replace compared to the cost of the printer.However, the main concern is Canon does not make this kind of multifunctional machine anymore, which combines print, fax, scan and print to CD/DVD.
There are few tricks that might work. The tricks are mentioned below :-
A)
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not,
press the Power button once more.
8. Your printer should respond as normal..
B)
Open the machine and remove the ink cartridges then look inside with a flash light and make sure nothing is in the path of the carriage.
Then turn off the machine and wait 30 seconds. Turn it back on and wait for the insert cartridge message. Then reinsert the cartridges into the machine.
Then move the cradle back and forth a few times manually by hand.
Then close the cartridges access door and turn the machine off.
Then unplug it and wait 10 minutes.
After 10 minutes plug it back in and turn it on.
If this does not solve the problem, you need to send the unit for repair.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Nov 21, 2010
  • 183 Answers
SOURCE: Canon printer i865 Orange light blinks
Dear Bruce,
Blinking in orange 5 times indicates that the print head of your printer is faulty. To ensure this you can compare by using another print head. But first,please remove the print head and check whether it is burnt. Some short circuitry may cause the problem. Thanks.
Source:
Printer Clinic
Posted on Dec 26, 2010
Testimonial: "Will purchase a new printhead. Many thanks for your advice."
What is err1 and err3 in elekta dishwasher?
Electra Dishwasher Error Codes and other critical errors can occur when your Windows operating system becomes corrupted. Opening programs will be slower and response times will lag. When you have multiple applications running, you may experience crashes and freezes. There can be numerous causes of this error including excessive startup entries, registry errors, hardware/RAM decline, fragmented files, unnecessary or redundant program installations and so on.follow the instruction on the link below to find your solution http://www.saetechnologies.com/electra-dishwasher-error-codes/
Mar 03, 2015 | Dishwashers
Error message ERR1 on BWD1212 washer dryer?
Door not closing properly. Hinges may need adjusting. The door switches are very sensitive
May 06, 2014 | Haier washer BWD1212 User Manual
Masterbuilt 20072612 ERR1 error code
ERR1 MEANS YOU NEED A NEW BODY KIT. PER MASTERBUILT, THE SMOKER IS DEAD AND NEEDS A FULL BODY KIT (BASICALLY THE ENTIRE UNIT)
Apr 18, 2014 | Masterbuilt 20070106 Electric Smoker
Pioneer CJ-V51 CD jukebox error 1
1 Open top door (display shows OPEN)
2 Press and hold SERVICE button until beep (display shows P5)
3 Press and hold CLEAR button until beep (approx 25 seconds)
4 Press and hold SERVICE button until beep
5 Close top door
Apr 06, 2012 | Pioneer AVH-P4900 Car Video Player
Manual
did you know allready what's the problem?i got the same so can you help me?wurlitzerbe@hotmail.com thans
Mar 29, 2009 | Pioneer AVH-P4900 Car Video Player
Keep getting err1 all the time.
what unit are you talking about? need to know to help :)
Dec 25, 2008 | Sunbeam Health O Meter Body Monitoring...
THANK YOU DAVE, THE PIONEER PLAYER MODEL NUMBER IS PD-M427 IF YOU COULD BE SO KIND AND INSTRUCT ME WITH MORE DETAILS ON ALIGNMENT /SERVICE MODE PROCEEDURES WOULD BE APPRICIATED. I AM REPETING THIS TEXT...
As you are a 'service centre' you should know to check the laser power with your laser power meter before anything else after checking the sled motor and spindle motor, assuming the laser is lighting.
It is simple, follow the service alignment procedure as laid out in the service manual from Pioneer. Ref RRV2905 page 22.
Mar 14, 2017 | Pioneer Audio Players & Recorders
Jukebox error
error 61 on the nsm is a cd read error nothing to do with the amp, clean laser lens with a cotton bud and spit not spirits etc just saliva, then make a blank selection and see if the laser emits red beam, if not then the laser is faulty, check connections etc, if it picks up the disc but does not spin it its the decoder at fault, places like act marketing london, jukebox showroom, capital coin, herondata sales or anyone operator within the amusement industry will gladly sell you an exchange unit, or just try the coinslot industy magazine online or order via wh smiths
Mar 04, 2008 | Audio Players & Recorders
Error message on display of my Pioneer DEH-P8000R
Try buying a cleaning CD that will clean the laser lens and see if that helps. Otherwise it sounds like a trip to the repair shop for you. Good luck.
Feb 01, 2007 | Pioneer DEH-P8000R
Unable to sync with Outlook
View/Folder in Outlook Open the Calendar Click on "GO" on top Toolbar. Click on "Folder List" Should show "Pocket Mirror" Folder ( Cant access it from Mail Folder. The instructions are unclear in the Palm Help.) Took me ages to find the above Even following the instructions by adding the Note in Pocket Mirror with the new handheld name I still get the same error as you and so GOOD LUCK!
Sep 13, 2005 | Handspring Visor Neo Handheld
446 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
