Question about Linare Desktop, AMD Sempron 2200,40 GB HDD & 128 MB RAM
Missing usb port
No USB port in the device manager. I keep on using the installation cd of my motherboard to install the USB but to no avail. Please help.
  • 115 Answers
Probably USB port is disabled on the Bios setup. Enable it on the bios setup. Rest will be done automatically.
Posted on Dec 17, 2008
I think, i am having a usb port malfunction. i just formatted my lg-ibm xnote lm50a with xp3 and installed all the drivers but all my usb ports don't function. it does not detect printers and mouse...
Have tried installing the CHIPSET Driver for the Motherboard?
Check the device manager for any bang on the devices meaning either a driver is missing or a wrong or incorrect driver is possibly installed, unless a REX "x" is foung beside USB hub then that would mean that is it busted or damaged.
but it is unlikely to have a USB hub/port to be busted unless physically, install the chipset driver and check again make sure you restart the system after installing the CHIPSET driver to make sure that it is properly installed in Windows and that it will detect the USB ports in device manager.
Oct 30, 2011 | LG X-Note LM50 Notebook
My computer is saying it is not connected to my Lexmark x2670 printer but I have everything connected. I need my printer! Help please.
Cannot Communicate; install USB; Install cable; installation USB; Installation cable; Cannot continue installation; Unable to press Continue; Unavailable Continue button; Continue button not active; Opaque Continue button; Gray Continue button; Continue button grayed out; USB connection not recognized
Solution
What you will see The Continue button is gray (i.e. Continue), preventing further driver stallation. connect the Installation Cable; using the supplied installation cable, connect to any USB port on this computer. Back Quit Continue There are several possible reasons for an inactive Continue button. Try the following suggestions in the order provided to resolve this issue: Action
1 Make sure the printer is turned on:
2 Confirm a solid connection of the USB installation cable on both printer and computer. HINT: The USB port is identified by this symbol:
3 Keeping Step 2 in mind, disconnect the USB cable from both printer and computer and then reconnect the USB cable at both ends.
HINT: Listen for audio alerts or notification icons or balloons in the Windows notification area. For example, or or .
4 If your computer has multiple USB ports, try connecting the USB installation cable to a different USB port.
NOTE: Passive or self-powered USB hubs may cause a problem.
5 If one is available, try connecting another USB device to the same USB port to see if it is recognized by the operating system.
6 If one is available, try a different USB cable that is under 10 feet.
NOTE: Some port replicators or docking stations for laptops or notebooks may cause a problem.
7 Confirm that you are installing the correct software driver for your printer model. For example, a 7600 Series driver works with the X7650 and X7675 All-In-One.
8 Turn off the printer, and disconnect and reinsert the power supply and power cord. Click here for image.
9 Click Quit to exit the installation. Remove the CD from the CD or DVD drive. Then reinsert the CD and try to perform the installation again.
To save time you can skip or close the hardware setup wizard if you have already completed these tasks. 10 Confirm that Device Manager recognizes the device. To open Windows Device Manager: Click on Start and then Run.In the Run dialog, type devmgmt.msc. Click OK.11 Next, disconnect the USB cable from the printer and reconnect it. Watch the Device Manager indow while you do so. The appearance of the items in the screen should change as Device Manager tries to recognize the device. Click here for image.Macintosh users: System Profiler is the Device Manager equivalent. Click here for instructions on accessing System Profiler, and look under Hardware > USB for the printer.12 Does Device Manager show a change in appearance?-If Yes, contact Lexmark Technical Support for additional assistance. -If No, there may be a problem with your computer and its USB support. The computer must recognize the USB cable in order for installation to work. 13 Reboot your PC and try these steps again.
Oct 02, 2011 | Lexmark X2670 All-In-One Printer
USB port is not working
first check whether ur os is windows 98 or xp if it is 98 then for any device u need usb driver. if it is xp ten its ok. check the device manager whether usb driver is loaded in ur system. right click on my computer icon not the shortcut icon. then select mange then select the device manager from the option available on left hand side of the window. then check the usb section whether any driover is loaded into ur system. if not then install from ur motherboard cd. if that also does not work them u need a replace of the usb port.
tell me u have a error message window cannot recognise the usb. if this appears then it need a replacement of the port. thank u
Feb 25, 2010 | ASUS P5PE-VM Motherboard
USB port not sensing after reinstalling windows xp, drivers are installed properly. not able to use usb stick, tried to access cam with usb port, nothing is working. pls help email id :...
Check your Device Manager "Start > Run > devmgmt.msc" you may have not installed controllers for your motherboard. Look for "!" and install the drivers using your motherboard driver disk. If driver CD is not available you can download updated drivers from Gigabyte Support Site.
Hope this helps.
Jan 04, 2010 | Gigabyte GA-8I845GVM-RZ Motherboard
Usb not work
i have this same motherboard.
i had issues with usb and video output and a few other things.
i had other issues with another asus board i had.
i suggest an ASROCK board as they are future compatible and have an excellent tech team.
ASUS tech support is rubbish.
Feb 24, 2009 | ASUS P4S800 (351000598) Motherboard
USB ports suddenly not functioning
hi, see if you have installed any new devices/hardware to see if its conflicting, often grafics cards conflict usb devices, also just check that in the setup(when you boot up)that the usb ports have not been disabled or usb keyboard support hasn't been enabled/disabled. good luck!!
Apr 01, 2008 | EliteGroup nForce3-A Motherboard
Usb not working
hi
what is your os.
try this
install inf update utility for your bord.
install intel chipset installation utility.
Mar 28, 2008 | Compaq Presario 5000 PC Desktop
Cant access USB Ports
Using XP?
You can download latest driver for your motherboard here
Mar 27, 2008 | Foxconn WinFast K7S741MG Motherboard for...
USB problem
Dear Sohamroy,
please install windows service pack 2. then try to update your windows with the help of this link www.update.microsoft.com.
Feb 12, 2008 | Intel D101GGC Motherboard
Computers & Internet Logo
67 people viewed this question
Top Linare Computers & Internet Experts
gautam jha
Level 1 Expert
Carlos L. Burgos
Carlos L. Burgos
Iqbal Husain
Iqbal Husain
Are you a Linare Computer and Internet Expert? Answer questions, earn points and help others
