Question about Bosch SHU3305 Dishwasher
Re dishwasher unit / sgs46m78au. water pipe/hose/ connections
I cannot follow your instructions regarding the water pipe /hose connections.Which is the outlet connection and which is the inflow connection.And does the inflow water hose connect to the hot water or cold water.How do i identify which is the hot water or cold? And when i disconnect the water hose/ pipe can i expect water discharge? And when i connect to the designated water inflow do i need to purchase addition plumbing bits? the instructions indicate additional washers and bits.
  • 67 Answers
The water connection is the smaller of the two and generally near the front of the machine, usually a threaded fitting on a electric solenoid will need a pipe to compression 90 fitting if its not already installed, it needs to be hooked to the hot water and that can be found on the left side going up to the sink faucet to be sure run some hot water and the side that gets warm is the correct one, you will need to turn off the water and install a T to connect the dishwasher if an unused shut off is not already there for the dishwasher. The drain line takes a hose and clamp and will hook into your drain iether through a dishwaser t or the disposal if you have one has a connection for it.
Posted on Jul 10, 2009
Frigidaire FDP635RFR3 wont drain.
Theres a drain pump located at the bottom of the unit if you follow the hose from the pump then to the drain if your unit isnt draining you might have to call for service from a technician to have them change your drain pump. If the water is just sitting inside the unit and when u start the unit it should fill with water again.Also if you have a cancel function by pressing this you will make the unit drain if you dont hear anything when u press the cancel button you definetly need a pump
Apr 28, 2010 | Dishwashers
Dishwasher won't drain or seems to drain to other diswasher.
possible blockage at sink pipe where the drain hose connects to. the drain hose is attached to the spout on the pipe. remove the clip holding the drain hose to the spout, remove drain hose gently, put drain hose into a bucket and then turn unit on to a cycle. it should start draining straight away.if it does drain into bucket u have a blockage in the spout. put a small screwdriver into spout to unblock . then put drain hose back onto spout with clip and run a cycle. before i forget when and if the water starts draining into the bucket turn off the unit so u can put the drain hose back on. if u need more help please reply. good luck.
Apr 27, 2010 | Fisher and Paykel 23 in. DD603H SS...
Whirlpool dishwasher Leaking water
Hello there:
Troubleshooting Leaks
If the dishwasher leaks, and you know the problem is not related to tub overfilling, the pump, or inlet valve problems, the plumbing connections may be faulty. Most dishwashers are connected to the water supply with metal pipe fittings, and the leak could be at these fittings. If the fittings are threaded, tighten them with an adjustable wrench. If this doesn't work, chances are the threads are stripped or the fitting is cracked or otherwise damaged. In this case, replace the fitting.
Most dishwashers discharge used water through a pipe or a hose connected to the drain or garbage disposer under the kitchen sink. If the drain line is made of flexible hosing, it may have cracked from prolonged exposure to hot water. Examine the hose; if it's damaged, replace it. If the hose is leaking at its connections with the disposer or dishwasher, tighten the fittings or clamps at the connections, or replace the clamps. Also check for water leaks around inlet valves, drain valves, and anywhere you see flexible hoses and hose connections. Leaks at clamps can be stopped by tightening or replacing the clamps. Leaks in hoses can be eliminated by replacing the hoses.
I HOPE THAT YOU FIND THIS INFORMATION VERY HELPFUL
BEST REGARDS MICHAEL
Nov 13, 2009 | Dishwashers
MY DISHWASHER IS CLOGGED UP. HOW TO DRAIN?
You could try to remove the flexable hose that connects from the dishwasher to the drain pipe (remove drain pipe end) and try to force water into the dishwasher
Aug 08, 2009 | Kenmore Dishwashers
Hotpoint dishwasher buzz when turned on an thats all it does
If the buzz stops when you open the door it could be the water solenoid valve which if it is not filling with water there is a 90% chance it is the valve. Turn off the water supply going the dishwasher under the sink or by the pipe. Pull the dishwasher out and unplug it if the hose length allows it to pull out. Put a towel or pan under the dishwasher hose connection disconnecting the hose on the dishwasher valve. Remove the racks and tip the unit forward with the unit unplugged and unbolt the valve where the water inlet is connected. Undo the hose clamp and wire connector. Check the valve or order a replacement and reinstall clamps and connectors. Be very careful when using the unit the first few times that no water leaks from hose connections by using a tissue touching the connections to see if water is present. Mold sucks so use a flash light looking in the front panel and tissue even after replacing the unit back in its final place.
Jul 14, 2009 | Hotpoint Dishwashers
My clients unit is leaking substaintial water in
Check the drainage hose to see if its connected properly. it is located under the unit. it may be loose or, not connected correctly. if the drainage hose is connected properly, this will be a faulty water valve. replace if found to be faulty.
Jun 16, 2009 | Dishwashers
Water leaking from underneath pipe connector to the dishwasher
Check the following:
* Loose or mis-positioned hose clamp at the drain spur connection
* Rotted or brittle hose
* Split hose
* Cracked joint at the drain spur connection or split drain spur fitting
Apr 27, 2009 | General Electric Dishwasher Timer
Water gets into disher when not inuse
dishwasher drain enters sewer system tapped into waste pipe below kitchen sink
water flowing from kitchen sink passes the opening of the dishwasher pipe
If the dishwasher hose does not loop up higher than the kitchen sink before going down to the bottom of the dishwasher water may flow downhill through the dishwasher drain into the dishwasher
ensure the dishwasher drain hose is screwed to the underside of the kitchen counter, to provide a stop to water flow.
The installation instructions suggest this
but often the dishwasher is at the end of its 'stretch'
and the installer assumes looping is just to use up excess hose, and doesnt.
an extension drain hose is available at most appliance stores
Oct 27, 2008 | Kenmore 22422 Top Load Washer
Dishwashing machine not fully draining (2 inches of water remain). I have an open problem concerning this problem. I have a new pump. dishwashing machine not fully draining (2 inches of water remain) For...
Following a cycle, a small pool of clean water inside the tub is typical. Excessive water means the pump isn't pumping water out properly, the drain hose isn't carrying it to the drain pipe, or the house's drain lines are backed up. If dirty water spews from the air gap, the drain line is kinked or clogged. Note: If you've recently installed a garbage disposer, be sure the knockout plug for the dishwasher was removed when the connection was made (see your disposer instructions).
Apr 19, 2008 | GE 24 in. GLD5860LSS Stainless Still...
Bosch SHU3305 Dishwasher Logo
307 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
