Question about Kyocera FS-C5015N Laser Printer
Kyocera Printer has a paper jam in a very awkward place and I cannot work out how to remove it
  • 154 Answers
Hi, go to this link, the pdf gives concise instructions to remove a paper jam
http://www.kyoceramita.com.au/files/1/FS-C5015_5025_5030_BOG-ENG.pdf
Posted on Dec 17, 2008
How can i fix my kyocera fs2100dn printer there is no paper but it says paper jam in the duplex unit
Hie firstly i would advise you to check where you had that paper jam if the sensor is in place because that will give you false paper jam
Feb 24, 2017 | Kyocera Office Equipment & Supplies
Printed paper path
sure...check your print manager settings, first, to see if that exit tray is selected as default..
Mar 15, 2008 | Kyocera FS-C5030N Led Printer
Kyocera 2100dn says paper jam in duplex unit but there is no jam paper.how can i fix?
the duplex unit is on top of paper cassette remove the cassette pull down the green lever inside the machine and remove the paper jam you cant see the paper otherwise
Feb 08, 2017 | Kyocera FS-2100DN Laser Printer - FS2100DN
My kyocera KM 1815 keeps saying "paper jam 00 open left cover and remove paper jam but there is no jam
Hi
Check all the paper movement from the tray, left or right cover, front cover, if so then remove jammed paper. Otherwise the paper sensor spring guide missing or fell off from its original position. Check carefully where the sensor locate. paper sensors detect all the paper movement in the machine during copying or printing, so locate the place in the machine which the paper usually jammed, see the screen of the machine, it will locate the place where the paper jammed mostly. Sensor not return to it original position that is why ( remove paper jam keeps blinking)
Aug 11, 2014 | Kyocera Mita Office Equipment & Supplies
Kyocera paper jam duplexer
The duplexer unit is located at the bottom of the printer. You have to remove the paper cassette first. Second, tilt the printer a little on the back side. In place of paper cassette, you will see an iron plate with a green handle in the left. Push down on the handle and the plate will go down. You may find paper jam there or pice of paper stucked. Release the handle and put back the printer and paper cassete, then open top cover and close it down. You may have paper jammed also under developer unit, or in the fuser section. Verify there, if the first solution won't solve the problem.
Apr 07, 2014 | Kyocera FS2020D ECOSYS Monochrome Laser ...
Paper jam
Did you try the door in the back of the printer?
Pull the paper cassette out then pull on the green handle to pull out the feed unit.
Jan 02, 2009 | Kyocera FS-C5015N Laser Printer
Kyocera C5015N paper jam can't remove
I guess it is stuck in the Fuser at the back, concertinaed at the exit claws,
Remove paper tray complete, pull green handle right side where paper tray came out, another tray will stop 3/4 of way out, there is a tab on each side, that you press in, one on each side of the rail, these are the bits stopping tray from coming out all the way, once you have the "process tray" removed you can see in to the fuser entry side and they may be enough to grab and remove it. If not unplug, top and sides off, unplug 2 cables, remove fuser screws and remove fuser.
Dec 17, 2008 | Kyocera FS-C5015N Laser Printer
PAPER JAM IN VERY REAR OF PRINTER KYOCERA FS1030D
sounds like a fuser jam. remove top and side covers, then rear exit tray. remove fuser screws and connectors. should be able to remove paper with fuser out of machine.
Oct 08, 2008 | Kyocera Office Equipment & Supplies
Kyocera KM-3035 - Paper Jam 00 error. Paper removed, still not working.
Check to make sure that their is no paper that is jammed in the paper draw. Also open the main panel where you would change the toner and pull out the little draw underneath the toner, I believe it is marked A2. Make sure that there is no paper there as well. Another place that paper will sometimes hide is in the left panel by the duplex system. Sometimes a little piece of paper gets left behind and this can cause the system to think there is still paper jammed in the machine. If all else fails try restarting the system. If you are still experiencing a problem than I would recommend you call your servicing dealer.
Hopes this helps.
Henry
Jul 20, 2008 | Kyocera Mita KM-3035 All-In-One Laser...
Kyocera Printer FS-1800 plus - paper jam Can't find the printer manual. Please provide steps to clear the paper jam and reset the printer.
Hi, first of all,pull out paper tray and check any paper,or scrap jammed.When paper tray is pulled out,open paper transport unit-You have green handle on the right side of machine,in the place of right side of paper tray.Pull out paper transport and remove paper.Just close paper transport unit and paper tray,open and close top cover.
Nov 29, 2007 | Office Equipment & Supplies
Kyocera FS-C5015N Laser Printer Logo
191 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Chris Schutte
Marvin
Marvin
Adorjani Laszlo
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
