Back to:
Tags:
ViewCast Osprey-230  Video Capture
The microsoft doesn't identify the osprey 230
posted by sun1976 on Mar 25, 2007
I reinstalled the driver for a osprey card on the xp system.
I can see everything fine in the device manager. But the micosoft encoder just doesn't identify the video capture. But, it can recoganize the audio capture.
And the Avstream does the same thing.
I reinstalled the driver several time, but doesn't help.
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Jun 06, 2007
Not Rated (0)
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
try an older osprey driver. it might work.
I had a similar problem. we had an older version downloader earlier. it worked. sometimes after the online update of windows causes similar problems.
regards,
sven@swarnavahini.tv
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on The microsoft doesn't identify the osprey 230:
I don't want to Accept this solution
Solution #2
posted on Mar 25, 2007
Not Rated (0)
bobby mac
Rating: 0%, 0 votes
since the audio works but not the video, it sounds as though the problem might be in the codec, not the driver. check card provider to see if there is an updated codec pac or new service pac. try: http://www.viewcast.com/driverdownload.a...
Thank You!
Can you Help with these Input Adapters problems?
Input Adapters
How to I change the rear output synthesizer to front input...
Input Adapters
I have a 19" Balance 2019 model F 192 and need the...
Input Adapters
Hi, i have problem with my card on linux. I found original...
Input Adapters
how can i delete movies recorded from compro dtv4 Large...
ViewCast Osprey-230 (OSPREY230) Video...
My computer recognizes the card. I get a picture in...
Loading problems.
Repair Service
Find Input Adapter Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
