Nuendo error `cant open reason
I recently started getting this Nuendo error `cant open reason engine'. I never had this before. I`ve reinstalled both programs but with no success. Tried different ASIO drivers, no joy. Its getting pretty desperate as I`ve got projects to finish. Any suggestion would be great. Cheers
  • 4 Answers
SOURCE: not responding
I have a thought on the 144 running on xp. If recording is such a memory hog and some say a minimum of 1 gig ram is needed then has anyone upgraded ram and had success? And or is it possible to create a dedicated swap file of some sort in place of ram. Actually I would like to know if it is indeed the lack of ram freezing the machine (.5 gig) and might there be a work around?
Posted on May 27, 2008
  • 3 Answers
SOURCE: The Asio Driver OmegaAsio could not be started!
I get this too. I don't know how to stop it happening in the first place, but if you find you can't record after it happens, this is what sorts it for me:
Go to 'Devices' and then 'Device Set-up'. Make sure you're in the 'VST Audio System' part of the menu. Click on 'Set to Defaults', then 'Apply' and 'OK'.
I have to say, though, I'm finding the Omega a total pain because of all these random issues!
Posted on Aug 09, 2008
  • 30 Answers
SOURCE: World of Warcraft ERROR #134 (0x85100086)
This is what worked for me –
Made a copy of the file expansion-speech-enUS.MPQ changed the copied file name to speech-enUS.MPQ, both files are in the same folder.
This problem hunted me for quite a while, and this simple solution was a gr8 relief.
Posted on Sep 07, 2008
mohanchennai
  • 490 Answers
SOURCE: I have a Canon DR-3080C II that the images scanned
Check the brightness setting. Try keeping at close to the maximum and scan. If it is still black, may be the lighting module or Scan module is affected. Check for any loose connections.
S. Mohan
Posted on Oct 22, 2009
  • 551 Answers
SOURCE: Two Edirol UA 25 audio cards cannot be used simultaneusly in Nuendo 4?
you should try it according to sound system.
Posted on Mar 27, 2013
When I try and transfer a file to back up it says "error 50" what is it? I have an i book. has worked fine in the past
there could be a number of reasons you are getting this error message
until you know the reason/cause you cant deal with it
click start control panel administrative tools computer management then select event viewer depending on what operating system you have this may vary
extend the events there you will ((see errors in red)) you will no what exactly what the error was and at what time it occured
you might be able work your way through the problem if it's a program file you might uninstall the program restart your computer then reinstall some of these files/software
Nov 01, 2011 | SimpleTech (GTW-USB235/250) 250 GB Hard...
What is causing igi starting error?
There are so many reasons why the fatal exception error has occurred. First, your video card maybe has below specs and need to upgrade. Second, maybe you didn't install a direct x in your computer that's why games didn't run successfully. Last, some files are corrupt so the game will not run properly. Solutions:
First, upgrade your video card to a higher spec.
Second, try to install a direct x in your computer. This is the link to download DirectX
Third, try to uninstall the game and reinstall it again.
Aug 17, 2011 | Computers & Internet
Activation code
Having trouble with opening nuendo on my computer
Oct 02, 2010 | Steinberg Nuendo 3 for PC
I CANT REINSTALL MY HP PSC1410V PRINTER. THE PROGRAM INSTALLS SUCCESSFULLY BUT THE DEVICE MANAGER SAYS IT CANT START THE PROGRAM BECAUSE THERE IS AN ERROR IN THE REGISTRY?...AND THE PROGRAM HAS EITHER AN...
First don't post in caps it is considered shouting.
Second Service pack2 or 3? If 2 then upgrade to 3. To find out click start then right click my computer and select properties.
Third uninstall the printer and switch it off
Forth. Fix the registry error with ccleaner available free from here
http://download.cnet.com/ccleaner/
Last Reinstall, switch on when prompted to connect by the install prog.
Get back if this does not work.
Jul 23, 2010 | HP Office Equipment & Supplies
Nuendo 3 not working in windows 7
Looks like you may have to run your windows 7 in XP mode to get this working. Nuendo 4 seems to have latest windows compatibility. However, it would worth checking whether the latest version they say is vista or windows 7.
Jan 29, 2010 | Steinberg Nuendo 3 for PC
Noises on recordin
is it popping or hissing? your recording level could be too high
Aug 28, 2009 | Steinberg Nuendo 3 for PC
D3DERR_NOTAVAILABLE
its direct 3d driver: you need to reinstall the last version of directx, or perhaps your videocard driver before
Nov 21, 2008 | Microsoft Windows XP Professional With...
Did you try uninstalling the last batch of updates?
To see the updates under "Add or Remove Programs", you'll need to check the appropriate box at the top.
If uninstalling does not help, you may have to start over.
Possible approaches to avoid the same issue when starting over:
  • Don't use SP3, unless you know that you *need* it. Check Wikipedia to decide whether you need it.
  • Install OS with SP2 and all updates, only then apply SP3.
  • Don't install all updates at once. Install them in batches of, say, 10 a batch. If the same thing happens, you know which batch was responsible.
Aug 04, 2008 | Microsoft Windows XP Professional for PC
159 people viewed this question
 Grubhead
Grubhead
Steve Allison
Steve Allison
