Question about Epson C64 InkJet Printer
C64 ink and paper jam both flashing
Ink and paper both flashing and thats it no clicking no movement no nothing I think its met its maker
  • Gerry Millward
    Gerry Millward May 11, 2010
    Are the two red lights flashing together or alternately?
  • 353 Answers
If you don't respond to a reasonable request for more information, it is very difficult to help you. Please respond with a new comment if you still have this problem and we can then provide help. Otherwise let's just call it solved shall we?
Posted on Feb 14, 2009
Flashing paper and power buttons
This error means jammed paper or a foreign object is blocking print head movement. Turn off the printer, press the adjust lever down to the lowest position, and pull out the jammed paper. Open the cover and remove any jammed or torn paper, or foreign objects. Then do one of the following:
Sheet Feeder: Return the adjust lever to the position. Turn on the printer, reload paper, and press the paper button.
Manual Feed Slot: See page 15 of your manual for loading instructions.
Roll Paper: Cut off the printed portion with scissors, then remove and reload the roll paper
Mar 08, 2014 | Unknown Epson Stylus Photo R2000 Ink Jet...
Epson Stylus PHOTO R220 red lights keep flashing
I hope this will help you :)
* Green Power light flashes- The printer is receiving a print job, replacing an ink cartridge, charging ink, or cleaning the print head.
* RED paper light is On- If the CD/DVD try guide is open, close the CD/DVD tray guide, load paper, then press the paper button. Your paper ran out or multiple sheets loaded at the same time . Load paper and press the paper butoon to resume printing.
* RED paper light flashes- Paper is jammed in the printer. Press the paper button to eject the jammed paper. If the light is still flashing , open the cover and remove all paper, including any jammed or torn pieces. Then reload paper and press the paper button to continue printing.
* RED Ink Light Flashes - One or more cartridges are low on ink. Check the message that appears on your screen to determine which cartridge is low, or follow the instructions in " Checking the Ink Supply". Make sure you have a replacement cartridge.
* RED Ink Light is ON- One or more cartridges are out of ink or not installed. If you have just installed a new cartridge, it may be incomaptible with the printer or incorrectly installed. Reinstall it or replace it with the correct cartridge
* RED Ink and RED paper lights flash alternately- The CD/DVD tray guide was left open when you turned on the printer or when printing on paper. Just simply close it/
* Green Power Light is Off; RED paperand RED Ink Lights flashing- Paper may be blocking movement of the print head. Turn off the printer, then open the cover and remove any jammed paper or other foreign objects. Turn the printer back on again. Or it may have an internal error. Turn off the printer, wait a few seconds, then turn it on again.
Jul 06, 2011 | Epson Stylus Photo R220 InkJet Printer
Power light flashing and paper light ! epson stylus c64
the matter is that Epson, apart from the chips was invented so that when the printer takes a certain amount of printed pages (about 8000 or so, in most models), suddenly stops working , the two buttons start to flash and does not walk more.
This is because the ink that they will bring to the cartridges when cleaning heads, going somewhere.These are the waste ink tanks, this is where you stay, and the printer has a meter that estimates when the tank is full and stops the printer to prevent ink overflow and cause an internal short circuit.
How do I unlock it?
To save money and the hassle of carrying it to better manage service yourself. You download the software company that provides ssc, Static Control Components, the following page:
and the manual for use the program is here traslated onto english you migth choose your printer model and reset it!
May 13, 2010 | Epson Stylus C64 InkJet Printer
Ink and paper lights flashing alternately epson c64 photo edition. paper fine, ink levels fine, power fine, comms with computer fine, still wont work, Help.
-turn off printer
-disconnect from computer
-load a couple sheet of plain paper
-press & hold paper feed button while turning the printer on
-it should print a test page if it is working fine, otherwise it is bound for service
Apr 02, 2010 | Epson C64 InkJet Printer
Paper feed and ink lights are flashing alternately and printer refuses to work
This problem is caused by the waste ink pad counter thinking the printer needs a good clean. You can download the SCC service utility from This will reset the counter and the printer will then work. As for the cleaning bit, I'm still working on that but at least I didn't junk the printer and about $40 worth of ink tanks.
Dec 28, 2009 | Epson C64 InkJet Printer
Canon Stylus C64 paper jam
try this link below. Although the printer is lexmark but it can used the idea to solve the problem regarding paper jam issue.
Jul 31, 2009 | Epson Stylus C64 InkJet Printer
Epson C64 Printer
It sounds like the print head is jamming on the parking mechanism (usually because the actuation lever is stuck in the up position). Turn the printer on, and as soon as the print head moves, pull the power cord out of the back, or switch it off at the mains. You should now be able to move the print head over to the left by hand out of the way. Now look in the "parking bay" at the right end where the print head parks itself and see if there is a plastic arm sticking up. If there is, gently pull it towards you and it should spring down. Now turn the printer back on and it should operate normally. If it happens again, repeat the process a few times to see if it clears the problem. Otherwise it means the parking mechanism is gummed up with dried ink and needs a good clean (see below).
Alternatively, if you see that the whole parking mechanism itself has moved up to block the way, this means a spring has come off. To get this back on again requires the printer to be dismantled - as does the cleaning job above!
Should you decide to have a go at cleaning or re-fixing the spring, let me know via a new posted comment so I can provide further assistance.
Nov 09, 2008 | Epson Stylus® C64 InkJet Printer
Epson c64
try to remove the ink then clean it with a tissue paper then insert it again. it should get solved
May 24, 2008 | Epson C64 InkJet Printer
Epson C64 InkJet Printer Logo
67 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
