My washing machine drum will not go around
Hi i have a problem with my diplomat 8512 the drum will not go around it will run through the cycle but will not actually wash the clothes or spin as the drum is not going around anyone had the same problem could it be a motor problem?
  • Washing Mach... Master
  • 3,463 Answers
Certainly sounds like the motor, see if you can see if the drive belt is o/k, if it is then I would remove the motor and check the brushes for wear, if they appear to be o/k ,then I would think you have a controller problem.
Plz rate my solution.
Thamks.
Posted on Dec 17, 2008
Severe vibration/noise during spin cycle. What could the problem be and how do I fix it?
if the machine was run severely out of balance (rugs) you'll need to get a look in the back up near the top with a good flashlight , this involves unhooking power and hoses and turning it around , you may have broken a drum suspension link , this device (three) keeps the drum from contacting the shell , if its true and its allowed to run this way you will brake off water hoses on bottom of drum and water will runout on floor
Feb 09, 2016 | Bosch Washing Machines
GE Washer stuck in wash cycle and not draining.
humming is usually the result of bad motor windings , are u saying it washes for 20 minutes or just stays on that cycle without doing any washing? a non moving drum can be a bad motor coupler or belt if belt driven.
Mar 30, 2015 | GE Washing Machines
Hi, I have a frigidare affinity front load washing machine and when it is running a cycle it sounds like the drum is banging around in the machine. It's a new noise, did something come loose? What
Hello gen0313 - From what you are describing it sounds like the unit could possibly have a broken shock/bearing or damaged tub. A certified technician will need to accurately diagnosis the bearing and pulling system behind the drum for repairs.
Feb 21, 2013 | Frigidaire Affinity ATF7000E Front Load...
I have a hotpoint WMA63. It goes through the washing cycle, and the water drains but when the spin cycle starts, the 'spin' light just flashes continuously. The drum goes around fine during the...
Hi, My guess is that you have an uneven load in machine. When it's time for the spin cycle to run, it will not complete that spin. You will have to open the door and rearrange the load so that it will spin.( machine will not run when door is open). good luck.
Jun 08, 2011 | Washing Machines
Where to put soap powder in Diplomat 8512. There are three compartments in the dispenser drawer.
it goes in the iddle one, the right hand one is for softner and the left is for pre-wash. hope this helps.
cheers
iain
May 03, 2011 | Washing Machines
I have a SIMPSON ENCORE 555 heavy duty washing machine. It will do a normal wash cycle, but when it comes to the spin cycle, it doesn't distribute the washing around the drum and hence won't spin. any...
Hi just read your posting.Now does the washing tangle around the agitator?In your posting you mentioned the washing not distributing around the drum.Could you confirm that your machine is a top loader for me,because the word "drum and distribute" are terms for a front loader.If your machine is a top loader which I think it is then the problem could be your brake arm or spin coil is not operating.Please reply and let me know if the clothes are tangling around the agitator.Looking forward to your reply.
Sep 07, 2010 | Washing Machines
Diplomat Dishwasher motor cutting out on hot mid cycle
Hi ,This problem is your main wash motor the origonal is an ascol
motor ,but the replacement is a motor with copasiter costs
around £80.00 for new motor
Nov 19, 2009 | Dishwashers
Washing machine drum won't turn when loaded
your gers in the cluch sistem are gon for good ,,sorry
Apr 05, 2009 | Fisher and Paykel (IWL12)
Diplomat 8512 Washing machine - water spilling out of detergent tray? Here's hoping for a simple solution.... When I start any program the water fills up the drum and then starts to pour out of the...
This is a problem with the pressure system usually caused by a build up of powder residue but can be caused by other blockages. Remove machine lid and locate pipe which is about 6mm in diameter. follow pipe down which will lead to pressure bottle. Clean out and replace and should be ok. If bottle is clear check pipes for other blockages and check preesure pipe for damage.
Nov 07, 2008 | Washing Machines
Washing Machines Logo
206 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
