Question about Maytag M7DH45B2A Dehumidifier
Won't Power On
Ran the unit one summer without problems. Turned off and unplugged for the winter. When I attempted to turn the unit on the next spring nothing happens. I press the power button and nothing, no lights or anything. Could this be an easy fix I could do? I hate to have it shipped for repairs.
  • Anonymous Mar 04, 2008
    will not power on!
    *plugged into hot outlet
    *float switch in proper run position
    this unit ran for {1} season.
    I need an operating manual please help!
    thanx
This reply does not solve the problem, however my MAYTAG M7DH
45B2A DEHUMIDIFIER had the same problem.
Circuit Board COR 268BV1.O had circuits burned (on lower side of
board). The circuits that showed signs of arching were the right end
of D1, D 2, D3, D4, and at C2, C3, C4, C5, J1, O1,.
Apparently water must have entered the area and shorted these circuits. But I do not know. The only alternative is to replace circuit
board or junk it
MY LAB
Posted on Jul 03, 2008
The dehudifier won't come on in and in the digital display the message CH 01 comes up. Any idea what the problem is?
CH 01 usually indicates that the filter is dirty and needs to be removed and cleaned. Turn the unit OFF and unplug it, before removing the filter. Never operate the unit without the filter in place.
Thanks for choosing FixYa.
Sep 07, 2011 | LG LHD659EBL Dehumidifier
I have a whirpool gold 50 pint dehumidifier. Bought in 2009 worked like a charm turned on for the summer the coils are always freezing and not picking up water from the air. Phoned wirlpool they said...
Sonia, There are 5 basic, but solvable reasons for what you described. Please pay particular attention to number 2.
1. The humidity extraction level is set to HIGH. Lower it to 32-35%.
2. Air intake filter is dirty or clogged. Turn unit OFF, & Unplug the
Unit, before removing to inspect & clean it, if necessary. If washed,
allow filter to completely dry before reinstalling. DO NOT operate
the unit without the filter.
3. Obstructed air flow. Maintain a minimum of 12 to 18" of clear air
space around the entire unit.
4. Cooling coils are dirty and need to be cleaned. Use warm water & dish washing liquid to
cleaning the coils. Rinse and wipe dry. Apply a light coating of WD40 to the coils.
5. Ambient air temperature at floor level is between 40 - 60 degrees.
dehumidifiers do not work well between those temperatures
(Unless, you have a Low Temp Unit). This applies mainly to
where the air temperature at floor level is colder than at shoulder
level
in basement applications. Raising the unit up off the floor,
onto a sturdy table, counter top, etc, that can handle the weight
of the unit, plus a full tank of water, will usually resolve this
problem.
Hope this helps you and thanks for choosing FixYa.
Jul 31, 2011 | Whirlpool Dehumidifiers
Was full - turned off to empty - replaced empty bucket, won'r turn back on and keeps beeping full
Try reinserting the bucket, making sure that it's positioned properly. So that the safety switch is engaged. If that still doesn't solve the problem. Turn the MASTER ON/OFF Switch to OFF and unplug the unit from the wall outlet. Wait 12 - 15 minutes and plug the unit back in. Turn the MASTER ON/OFF Switch to ON and hopefully, if the bucket is positioned properly, the unit will have reset itself.
Hope this helps you to solve the problem. Please let me know.
May 08, 2011 | Maytag Dehumidifiers
My dehumidifier says the bucket is full, when it is empty. the red light flashes and it beeps. I can't get any buttons to work. I have taken the bucket in and out several times. Any suggestions? It did...
First, the unit may need to be cleaned and after that, unit may need to be reset. Turn the Master ON/OFF Switch to OFF and unplug the unit for 12-15 minutes. Then plug it back in and turn the Master ON/OFF Switch to ON. Set the controls as you normally do. Hopefully, that 12 - 15 minute timeout, allowed the electronics to reset themselves. If this continues to occur frequently, contact an authorized Frigidaire Service Center
Hope this helps you troubleshoot and solve the problem.
May 02, 2011 | Frigidaire FDF70S Dehumidifier
Freezing problwm; very small amount of water was collected.
Here is a tip that I wrote that will help you understand why and what you can do with a dehumidifier that ices up.
Dehumidifier is Freezing up and not working
heatman101
Apr 27, 2011 | Soleus CFM-40 Dehumidifier
Does dehuidifiers stop working as hard in the winter months then in the summer months. Because my water bucket has not fill up since gotten cold. I live is Alexandria Va and it is winter here.
Generally speaking there is more moisture in the air during the summer months. As the humidity goes down in the winter your dehumidifier will not collect as much water because there is less moisture in the air.
Dec 28, 2010 | Haier DM30EAL Dehumidifier
Kenmore 54701 (70 pt) dehumidifier will not power on.
This unit has had a lot of problems. It has come up in other forums. The fan motor is thermally protected. Could be the printed circuit board is bad. Check out this forum:
http://forum.doityourself.com/humidifiers-dehumidifiers/177549-kenmore-dehumidifier-fan-stopped.html
May 04, 2009 | Kenmore 54701 Dehumidifier
Power OFF button doesn't work; unit keeps running, overflows, and doesn't stop
I have the same problem! The "pcb" referred to in the previous reply is undoubtedly what Sears refers to as the "COVER ASSEMBLY, DISPLAY", part number 3551A20109B. It is possible, but highly unlikely, that the defective part is the ESCUTCHEON, p/n 3831A20079D. Sears lists the cost of the COVER ASSEMBLY, DISPLAY as $17.25 plus, undoubtedly shipping and tax. The part seems to be available only from the Sear Web Site under "PArts Direct". This dehumidifier is a piece of garbage. I previously had to replace the SENSOR ASSEMBLY, p/n 6877A30013L. This item turns off the unit when the water tank is full. This dehumidifier has my room flooded - twice - when the unit failed to turn off and overflowed.
While under waranty Sears/Kenmore attempted to repair the unit five times. They never succeeded and when the warranty ran out they would not repair the unit unless I paid for it. Thats when I started doing my own repairs!
Oct 01, 2008 | Kenmore 54701 Dehumidifier
Will not power up
it is summer and I just turned on the humidifer. it is dead
Jun 21, 2008 | Fedders A7DH65B2A Dehumidifier
No water colledction
Check to see that the air is flowing freely through the dehumidifier. They will accumulate dust particles and become plugged. Also make sure that it is not freezing up (you would see ice forming inside through the vent openings). I have had to remove the case to clean lint from some units to get them to operate more efficently. Always unplug the unit to clean and service it.
Dec 31, 2007 | Crosley MCR40ES Dehumidifier
Maytag M7DH45B2A Dehumidifier Logo
232 people viewed this question
Top Maytag Dehumidifiers Experts
Bill Long
Steve
Mike Squire
Are you a Maytag Dehumidifier Expert? Answer questions, earn points and help others
