Best Solution
posted on Sep 24, 2007
Guest
Rank:
Apprentice
Rating: 0%, 0 votes
Rating: 0%, 0 votes
heat up a cup of water and dishwashing liuid to boiling, and let it sit for 5 minutes. then use a clean sponge with "baking soda", and gently wipe down the interior. the 5 minute soak lessens elbow greae and uses modern chemistry to loosen stains and dried spills.
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Aug 08, 2005
Lizzy - usenet poster
Rank:
Apprentice
Rating: 0%, 0 votes
Rating: 0%, 0 votes
Cleaning the Interior
1. Wipe away crumbs and stains from the inside of the microwave using a damp paper towel. (Image 1)
2. Remove remaining food and stains by gently scraping them away with a dull blade or a fingernail.
3. Spray with an all-purpose cleaner. (Image 2)
4. Wipe away cleaner with paper towels. (Image 3)
5. Repeat, if necessary.
6. Wipe dry with a clean paper towel.
Cleaning the Exterior
1. Spray the exterior of the microwave with all-purpose cleaner.
2. Wipe away cleaner with a paper towel.
3. Spray the exterior window with glass cleaner.
4. Wipe dry with a paper towel.
Solution #3
posted on May 26, 2008
Guest
Rank:
Apprentice
Rating: 0%, 0 votes
Rating: 0%, 0 votes
microwave a wet sponge or wet cloth dish towel inside for about a minute. This will create steam, be careful the sponge or towel will be hot. Wipe out interior with wet paper towel, removing glass carousel or tray to wash in sink.
If you have stubborn stains or dried food, add some baking soda onto your damp paper towel, and scrub with this. The baking soda is a very mild abrasive as well as being a good solvent for food and other baked on ****. Rinse, repeat and dry when finished.
Solution #4
posted on Dec 14, 2007
I found an easy way to clean the interior of a microwave oven....boil about 3 or 4 ounces of vinegar in a bowl and then wipe the interior clean with a sponge. If the inside is really caked up, it may take more than one time of doing this. Only disadvantage is if you can't handle the smell of the vinegar, but it goes away quickly.
Suggest a new solution for this problem
Post a New problem for Westpoint TV-201 900 Watts Microwave
Email this problem
Email this problem
This Problem Also Relates To:
GE JVM3670 1100 Watts Microwave Oven
GE JVM1660 1000 Watts Microwave Oven
GE JVM1750SMSS 1000 Watts Microwave Oven
GE JES738 700 Watts Microwave Oven
GE JES1289SK Stainless Steel 1000 Watts Microwave Oven
GE JES1358 1200 Watts Microwave Oven
GE JEM25 800 Watts Microwave Oven
Can you Help with these Microwave Ovens problems?
Westpoint TV-201 900 Watts Microwave Oven
Westoint Dishwasher
Westoint Dishwasher
I have looked in the manual... Answer This...
Repair Service
Find Microwave Oven Repairman Near You:
