Question about Yamaha Full-Size Keyboard
Water spillage on keyboard has modified some notes.
We have a Yamaha Gran Touch 2 piano, about 5 years old.
10 notes, from bottom, first B,C,D#,E,G,G#,B,C,D#,E do not give full resonance 'legato' when struck and held without pedal. They sound short 'staccato'. This problem disappears when the sustain pedal is depressed. All notes are then fully sustained.
Some water from a vase was spilled inside the hood at the treble end of the piano.
Can you identify this problem and indicate the solution please?
  • 4 Answers
Hi John. Doesn't sound good at all. Your Digital piano is an expensive piece of kit and I would seek a professional repairer to put it right. I would Contact Yamaha Kemble and seek advice.
At the end of the keys are small optical sensors that pick up your keysrokes and turn that into Digital Data. I would suspect that the water has shorted them out and they might need replacing.
UK Technical Support is available by telephone on 0870 4445575 - Monday to Friday, 9am to 5pm (4.30pm on Friday).
Regards
Posted on Jan 02, 2009
There is one note, the B below middle C, which is much louder than all the rest. Please advise how to rectify this. Many thanks
If your keyboard is a few years old then it is likely that the pressure strip that runs under all the keys needs replacing. This will cost around £50 to pay someone to supply and fit.
Mar 12, 2015 | Yamaha Used Arius Ydp140 Digital Piano...
Yamaha P-70 digital piano. A few keys are making a loud knocking noise. The note still sounds, but the knocking noise on the few keys can be heard at the other end of the house
There's an extremely comprehensive pair of videos about repairing this problem on YouTube thanks to David Allyn. I have embedded them below, or you can search "P70 Noisy Keyboard Repair".
Jan 03, 2014 | Yamaha NP 30 76 Key Lightweight Digital...
Yamaha Gran Touch problems
bit late. I have had the same problem. I replaced the optical module which solved the problem for me. The optical module is located above the keyboard and is used for scanning the keyboard.
Good luck,
F van Duijvenvoorde
Mar 12, 2010 | Yamaha Full-Size Keyboard
Kurzweil digital piano unpredictable voices and volume
The contacts of various switches and keys are likely dirty. They are often conductive rubber and need cleaning with 99% isoprophly alcohol and q-tip. Clean both the conductive rubber pill and th circuit board traces they contact.
Sep 17, 2009 | Yamaha NP 30 76 Key Lightweight Digital...
What needs to be removed from my Yamaha YPG-625 to
DO NOT open the case unless you are aware of and comfortable with the fact that you could _destroy_ your piano. Easily.
Observe appropriate anti-static precautions. It should go without saying that this is an electronic repair, and dangerous voltages may exist inside the case.
1. Remove the stand if you have one
2. Lay the keyboard upside down (bottom up) on workbench
3. Remove all 90+ screws from the bottom of the chassis, including the 14 inside the speaker compartments
4. Carefully lift up on the bottom case part, taking not to damage the speaker lines
5. Unplug speaker connector and set lower case aside
6. LCD is mounted beneath main logic board
9in the center), my problem lies elsewhere, but competent and cautious service technique should lead you where you need. I would strongly recommend replacing the LCD assembly module, unless you are experienced in LCD repair.
Jul 06, 2009 | Yamaha Full-Size Keyboard
Yamaha digital piano clp 170
This is a common problem with Yamaha keyboards. The problem is caused by worn-out rubber contacts in the keyboard assembly. In my old Clavinova CLP-500, there was one long rubber contact strip under the keys with two parallel strips of semiconductor material. The Clavinova circuitry determines key velocity by measuring the timing between when the key hits the first and second strips of semiconductor material. The harder you play a key, the less time it takes the key to hit the second semiconductor strip after hitting the first.
After years of playing the keyboard, the keys eventually cause tears in the semiconductor material and this messes up the timing measurement for key velocity. The only solution is to take the keyboard apart and replace the rubber contact strip with a new one.
I got rid of my CLP-500 four or five years ago and got a new CLP-170. The CLP-170 is now having exactly the same problem that the CLP-500 had. Yamaha has re-designed the rubber contacts in the CLP-170 so that there are now eight individual contact strips instead of one long one. The problem is essentially the same, though. You have to take the keyboard apart and replace the worn out rubber contacts.
Here are the part numbers for the rubber contacts that need to be replaced in the CLP-170: V8286600 Rubber Contact, 12 keys, D-C#   Qty. 6 V8286800 Rubber Contact, 11 keys, A-C#   Qty. 1 V8286700 Rubber Contact, 5 keys, D-C   Qty. 1
I suggest you also get a copy of the CLP-170 service manual, part number 001677. It has descriptions of all the steps necessary to take the thing apart and put it back together again. You'll also need a "rod" (which is just a long dowel), part number TX000670. Before you take the circuit boards off the keyboard assembly, you have to insert the dowel between the keys and the frame to keep the keys from falling back and getting in your way. A 5-foot long 1/4-inch dowel will probably work. (I haven't yet taken apart my CLP-170, and I don't have Yamaha's "rod," so I'm not sure if 1/4 inch is the right size or not. I'll report back here if it's not.)
Good luck, Howard
Sep 03, 2008 | Yamaha Full-Size Keyboard
Yamaha Full-Size Keyboard Logo
530 people viewed this question
Top Yamaha Music Experts
Michial Gueffroy
Mike
Are you a Yamaha Music Expert? Answer questions, earn points and help others
