Question about Kodak EasyShare C330 Digital Camera
Lens Error 25
About a week ago, I put my Kodak EasyShare C330 into my purse. I guess my purse got bumped around and turned the wheel on the camera into the "Favourites" position. I noticed this had happened before the batteries drained completely and turned it off. I turned it back on to make sure it was ok, the lens came out like it was supposed to, but it said "Lens Error 25" on the screen. I tried turning the camera off, but the lens didn't retract and when I turned the camera back on, I got the same error message. I've already tried banging the bottom of the camera (that's what some people say works). Any help is appreciated.
Guess what I tried banging the bottom of my CW330 camera, as suggested by Timewarped, and the lens retracted and the "Lens Error 25" cleared. I can't believe it, you saved me about $80 in repairs. Thanks
Posted on Aug 31, 2007
This happened to me also. It was fustrating and i thought my camera was broken. I twisted the lens to the right as you suggested and it worked!!! The lens just went back into place. Thanks alot for your help!! You saved me a new camera!
Posted on Apr 22, 2008
I had exactly the same issue with my camera. To fix mine I twisted the lens to the right while it was extended, it takes quite a bit of effort, try turning the camera on again and see what happens, if it doesn't work twist it back into its original positions again. When I did this it started working again, although the lens is not as smooth on extension or retraction as it was before the issue. Also take out the batteries in between use as they always turn themselves off and on which I'm sure is the cause.
Posted on Jul 14, 2007
Kodak lens error 126,1,0,-2
Posted on Mar 26, 2007
What does lens error 14 mean. Screen goes black
This is a lens error. KODAK suggests a repair for this fault.
However a repair for this model is around 48 pounds, you are properbly. better off considering a new camera. KODAK also offers a trade up option where you will have the opportunity to trade up to a newer model 25-30% cheaper than the market price.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Feb 08, 2010 | Kodak EasyShare C330 Digital Camera
Lens error 22...help me
In order to clearly determine the fault the model of your KODAK camera is needed
However this will be a repair of around: 48,44 - 88,07 pounds.
Contact KODAK:
Nov 01, 2009 | Kodak EasyShare C330 Digital Camera
The screen keeps saying lens error 14 then its says lens error 22
pls tap the bottom of camera and see if it works i mean tap hard it might come out or not it is stuck with dust and sand or something like that or the GEAR might be broken then i will suggest buy a new one dont waste time in replacements
consider FUJIFILM.com they are good in cameras
Pls rate me WELL !
Regards
Zohail
May 28, 2009 | Kodak EasyShare C330 Digital Camera
Lens error 25 of kodak camera C330
    According to the symptom you have to replace the optical lens assymbly.
THANKS FOR USING FIXYA.
Apr 29, 2009 | Kodak EasyShare C330 Digital Camera
Lens on camera (kodak easyshare c330)
Hi There,
Try removing the batteries the reinstall them and press the Power On Button. Let me know if the lens retracts.
Mar 30, 2009 | Kodak EasyShare C330 Digital Camera
Kodak Easy Share C330 lens error 14 and lens error 22
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Oct 08, 2008 | Kodak EasyShare C743 Digital Camera
Lens error 25 and 15
Mar 25, 2008 | Kodak EasyShare C330 Digital Camera
Lens error 12 & 22
Our school uses this camera. It's reporting a lens error 12 and the lens does not extend. Bumping it did not work, nor does pulling the lens out with a fingernail.
One teacher said that another school had LUCK by installing a new battery pack. The old one might not hold enough power to fully boot up the camera, causing the lens error.
I have noticed that the battery does not hold a charge for any length of time. This will be our next approach.
Cameras that are dropped, banged or bumped are not covered by a warrantee, so beware.
Oct 22, 2007 | Kodak EasyShare C330 Digital Camera
I bought two of these on clearance and gave one to my in-laws. She suspected that one of her kids may have dropped the camera or pushed in the lens. I don't remember which lens error number had shown up, but I dis-assembled the camera to find out what the deal was. If I remember correctly, there is a way to manually turn the gears to put he lens back out. I left the lens out and turned it on and it worked perfectly. Fair warning though. It is VERY IMPORTANT not to touch the contacts for the flash EVEN WITH THE BATTERIES OUT!!! God did it hurt like hell... unfortunately it is fairly easy to do and I must have accidentally done it about 4-5 times while messing with it..
Sep 05, 2007 | Kodak EasyShare C330 Digital Camera
Kodak C330 [lens error 14]
I have this camera and I have had this exact error...and I'm sure it was caused from being in my purse and turning on and off all the time. All I did to fix it was push the lens a little bit while it was already retracted and it made a slight popping noise like it was going back onto a track and then it worked perfectly ever since then.
Aug 26, 2006 | Kodak EasyShare C330 Digital Camera
Kodak EasyShare C330 Digital Camera Logo
468 people viewed this question
Top Kodak Cameras Experts
Jerry Greenberg
Jerry Greenberg
Computer Links
Are you a Kodak Camera Expert? Answer questions, earn points and help others
