No green light on vent damper
Boiler will only run when bypass vent damper by jumping black and red wires. when damper is hooked up it puts vent damper position to close not open.
  • Anonymous Jan 25, 2009
    how much to change gas vent damper?
  • 69 Answers
The damper is no longer funtioning and needs to be replaced
Posted on Dec 22, 2008
How do I bypass my Honeywell D896 vent dampner?
The furnace was probably originally equiped with a damper bypass plug that was removed to install the vent damper. Of course some were hardwired in as an accessory. But look inside the furnace vestibule or in the homeowner instruction envelop and see if the original installed tossed the plug in there during installation. That would be GREAT !!!!
Without the wiring diagram of the furnace AND the vent damper, I cannot give you specific input on the wiring. But the damper has to have 24v to operate it and there has to be a switch circuit for making and breaking the gas valve control circuit.
You may have to call a service company to get your issue safely resolved.
Dec 29, 2014 | Honeywell Heating & Cooling
I'm looking for help. Installing a Woods 59007 timer. It has 4 wires, red, black, green, white. My current electrical setup is a black, white, and ground wire in the box. How do I hook this up? T
Hook all the white wires together.
Hook all the greens or bare copper wires together.
Hook your hot black to the timer black.
Hook your black wire that goes to your light to the red switch wire.
then try the switch if the light doesn't work switch the red and black switch wires around black to light red to black power.
Oct 19, 2014 | Woods In-Wall Digital 5-10-15-30-Minute...
I have a 12/2 (black/white/ground) power source to the leviton 1755 switch. And, I have two (2) 12/2's going to a Broan 100hl (vent, light, heater). Please help wiring switch and Broan; on...
The switch that you have works like 3 seperate switches. most of these switches will have gold screws
on one side and silver screws on the other side, lets say that the left is gold and the right is silver, and
the switch may also have a green screw for ground. your 12/2 with ground is your main hot, you may
want to mark it with a piece of tape, so you know it's the incoming hot. the ground off your hot will tie,
to the green screw on switch and continue and tie to your vent light which should also have a ground
the white coming off the hot is your neutral, it will go straight to your white or whites on your heater.
the black hot wire at your switch will go to each gold terminal on one side of the switch,there are two
ways you can do this, go to one side and just run a jumper, or put one wire on each gold screw and
tie in to your hot-black wire with a wire nut. now for the switch legs, you will need to run from your, switch
to your heater either another pair of 12/2s or a 12/3, each side of the switch that has one silver screw,
it's easier with a 12/3 normally a 12/3 will have a red,black,white,and ground.
top switch red to red on heater,black to black on light and the white blue on the vent,so from your switch
to the heater you would have to run a12/2 you would not use the black only the white and ground.
remember the white-neutral coming from the switch will be tied to all the whites at the vent,light,heater
except for the 10/3. the 10/3 is used stricktly for the switch legs. good luck!
Jul 09, 2011 | Leviton 1755 Triple Rocker Switch Decora
We just bought a house and the living room has a light fixture and there is a dimmer switch that controls it. I removed the light fixture and installed a ceiling fan but the fan barely moves and the light...
You're correct. The dimmer switch was not made for that fan.
The Green is ground > so you're right there too. I assume other plugs nearby are working when dimmer is on. Check that to make sure.
By your description, I assume there is NOT another switch or dimmer that connects to same light. If so, you need a 3-way switch and the following instructions are void.
I suspect when you wired the new fan, that you saw the red and small black wires in the ceiling box. Did you connect the fan and light to those wires? If so, the following information will help you wire the switch.
Your incoming Hot line is probably the larger black wire that connects to Dimmer black >>> this wire will connect to either screw on the new switch
To test Hot wire for sure: Take out dimmer and mark wires for identification. Separate wires. Turn on power and test each wire to bare ground. Tape tester leads to wood sticks so hands are away from power. You'll be fine. Tester lights up on Hot wire.
Next: The smaller black and a red wires are a toss up.
Here's how I would proceed. Connect the black Hot to either screw on switch. Connect red wire to other screw. Put wire nut over small black. Turn on power. Flip switch. Check both lights and fan to see which works with red wire.
Next reverse the toss up wires. Put wire nut over red. Connect small black to switch. Check both lights and fan.
If red and small black control the light & fan, then connect them together on the same screw, and you're done.
If you want to control the fan and light separately, buy double switch, and then Hot connects to dark-colored screw on one side of switch, and red and small black connect to two different screws on opposite side of switch.
Oct 04, 2010 | Solar 10 Eagle Almond Commercial Double...
I bought Utilitech #0141224 7 day digital in wall timer. I have just 2 wires at the junction box both of which are painted over but assume one could be black and other white. The 7 day digital timer...
Hello, I bought an in door smart digital timer (G.E.) or Jasco product for my front porch light. I hooked all the wires as instructed and programmed according to instructions. I have a two wire system, so i left the green wire unattached. The light comes on but flashes very fast. What's up with that? This is the second one i've replaced, the first one did the same thing!. Whats wrong?
Thanks,...
M Jones
Sacramento, CA.
Aug 16, 2010 | Intermatic Inc. ST01C Digital In-Wall...
Red boiler light will not go on. The boiler does heat up.
Open the steam valve when you turn the machine on that will vent out the boiler, keep it open until it starts to hiss slightly and produce small steam bubbles, then close and machine should heat to temp. If that solves your problem then the vent valve needs to be replaced, until then you can turn using the steam valve open trick.
May 31, 2010 | Isomac Tea Espresso Machine
Heat works fine during the day at night it stops if you run hot water power vent turns on then boiler fires is it the presure swith in the power vent its model ck-92fal thanks ron
Turn on the boiler and jump out the pressure by putting a wire between the 2 electric connections only after the unit fires up than put the jumper on, if it runs ok it is the pressure switch.
Jan 08, 2010 | Calvin Klein The Field Controls Company...
I have a Clarion VZ409 I need to bypass the green brake wire so audio will play all the time
just audio or you meen video to while driveing just buy a toggle switch and put the red wire from the togglt to the skinny yellowish or greenish wire and put the black from toggle to black from your car and deck flick it and watch whatever you want when you drive
Dec 27, 2009 | Jensen VM9510 Car DVD Player
I'm trying to install a GE digital timer (model number 15086). The timer itself has three wires (red, black and white) and the light switch has two wires, one red and one grey. How do I hook this up? BTW,...
the extra white wire from timer goes to the group of white wire ganged together in rear of box. you need to connect a jump wire to tha group and lead to timer. grey wire goes to black. red to red.
Dec 20, 2009 | Hardware & Accessories
Re sent wire diagram gat all messed up
Hi
have we spoke before in previous post?
the red can go to any 12v live peramanent such as wire to clock or other item that has power with ignition off and the same with the yellow if your putting these to the same permanent live say from clock you can join these to together red/yellow to red on clock
the black can go to any metal or neg wire.
This should then have your device working the only problem im looking at for you now is the pink wire as this stops you using the device whilst driving as it goes to handbrake but i need to find out if its live or negative.
You could just wire the red/yellow to live and black to earth then see if it switches on and works if not then let me know and ill see about the pink wire ok
Makes sure you use inline fuses on the live wires so as not to short the device out.
Make sure you know what is permanent live to put the yellow/red wire to.
It doesnt need to be ignition it only says this so you cant use it with ignition off but you can wire it into any live feed from clock or switches so its up to you what to wire it to its just the pink wire im concerned about.
PINK: does it tell you to put it to live or earth on handbrake switch?
let me know ok
Apr 19, 2008 | Car Audio & Video
Heating & Cooling Logo
166 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
