Question about Cyberhome Televison & Video
Cyber home CH DVD 402 comming up with "insert disc" in display Cleaned laser also not playing cds Laser lights up but turntable motor not running I am a service engineer but i have no diagrams for this unit Can you help David
So you want to charge me for infomation on my cd player?
But if i have already fixed the problem you want the info so you can charge someone else?
PLEASE !!!!!!!!!!!!!!!!!!!!
Posted on Dec 18, 2008
This problem is with my home theater HT-TZ512. The disc sometimes loads, plays for 15-30 minutes, then randomly stops. The picture is still on screen. It looks like I pressed the pause button. When I...
You need to try a DVD Laser Lens Cleaning Disc.
If this doesn't work then you'll need to remove the cover and clean the Laser Lens with some Lens Cleaning Fluid and a QTip. Just use a few drops on the QTip and then wipe over again with a dry one.
If the above fails then its the Laser that's failing which isn't normally cost effective to replace.
A good way to check is if it will still play CDs but not DVDs then its the Laser.
Jun 11, 2011 | Samsung HT-TZ512T Theater System with...
My DVD has problem read disc DVD. When I put inside disc VCD everything is fine. I have region 0 on my dvd.
hi,
i have got the same complaint some days ago. your players spindle motor is faulty.
its winding have some problem. spindle motor is that one on which the dvd spins. when u insert the dvd it is not rotating at the required rpm. thats why it is not reading. the problem will not be with video cds . because it doesn't required a high rpm. replace the spindle motor. it will not cost a lot. its sure that ur problem will be solved.
if then also the problem remains,
your player's laser pick up unit have some problem with its DVD laser. there are two types of laser in dvd players. one for reading and playing audio cds, mp3 and video cds and the other for reading and playing dvds. in your player dvd laser have problem. dont think that these are two separate unit. the lasers are mounded in the same unit. if any of the laser get damaged you have to replace the whole unit.
if u need any more assistance feel free to contact me through fixya.
bellow is the image of laser pickup mechanism
ok
Jan 26, 2011 | Cyberhome CH-DVD 300 DVD Player
FAILURE TO READ DISCS. TECHNICS SL-DV280 (SC-DV280)
if the disc starts to rotate when helped by hand then you definately have a weak spindle motor. dvds spin faster than cds which gives more wear & tear to the motor. i've repaired these faults numerous times. hope this helps?
May 08, 2009 | Technics SC-DV290 System
Can't play dvd
Maybe your dvd got some capacitors dried on the power supply.
But you can also clean the laser lens maybe is dirty.
Jun 21, 2008 | Cyberhome CH-DVD 300 DVD Player
CyberHome DVD Player CH-DVD 402 will not recognise DVDs previously played in this player. The only thing to happen in the meantime has been to play Audio CDs in the DVD player.
The DVD laser pickup has worn out. That's common in cheap chinese products. Throw the DVD away and buy another, the repair is expensive because the factory doesn't produce spare parts.
May 05, 2008 | Televison & Video
Lg da3520 home cinema system refuses to play DVD discs. It has no problem playing CDs but DVDs it either says "Check Disc" or "Disc Error" or continues to attempt to load the disc but...
you have probably to clean up your dvd player with a clean up CD. After that if your dvd player doesn't want to read a dvd but play a cd, your laser output must be to fix. you'll have to go to a specialist.
Apr 23, 2008 | Televison & Video
"no disc" message
sounds like you have a problem with the laser.laser has to focus a lot sharper to play dvd thus will play vcd but not dvd.Try cleaning first and if this doesnt work would suspect laser faulty,.
May 29, 2007 | Cyberhome CH-DVD 300 DVD Player
Televison & Video Logo
73 people viewed this question
Top Cyberhome Televison & Video Experts
zappal
Demonic-2011
Demonic-2011
Are you a Cyberhome Televison and Video Expert? Answer questions, earn points and help others
