Question about Canon PowerShot SD700 IS Digital ELPH / IXUS 800 Digital Camera
Spot on lens
Yesterday I bought a new canon sx1 is.
I noticed a little spot on the lens (about half a square cm surface), which is not shown on the pictures until now. The spot was not altered after wiping with soft cloth. What should I do?
Thanks in advance,
Dimitris
    Sergeant:
    Champion:
  • 293 Answers
Best thing to do is take it back from where you purchased the camera and ask for a exchange or you money back .
Posted on Dec 17, 2008
I need the torque spec for the cylinder valve cover 2004 toyota sienna?
20. INSTALL CYLINDER HEAD COVER SUB-ASSY
(a) Apply seal packing to the cylinder head as shown in the
illustration.
Seal packing: Part No. 08826-00080 or equivalent
NOTICE:
 Remove any oil from the contact surface.
 Install the cylinder head cover within 3 minutes after
applying seal packing.
 Do not start the engine within 2 hours after installing.
(b) Install the cylinder head cover with the 9 bolts. Tighten the
bolt uniformly in several steps.
Torque: 8.0 Nm (80 kgf cm, 71 in.lbf)
(c) Install the engine wire harness with the 3 nuts.
Torque: 8.4 Nm (85 kgf cm, 74 in.lbf)
21. INSTALL CYLINDER HEAD COVER SUB-ASSY LH
illustration.
NOTICE:
(c) Using an E6 torx) socket wrench, install the engine wire
harness protector with the 2 bolts.
This is year/make/model specific to the 2nd Gen Sienna. Taken from the 05 Toyota Sienna repair manual. Hope this answers your torque specs for the valve covers which uses 10 mm bolts. If in doubt, as Scotty Kilmer asserts, do a "German tight".
Nov 20, 2017 | 2004 Toyota Sienna
Find the perimeter of a square whose area is 1225 cm2
I could just give you the answer of 140 cm
but I think you need to know how I got this answer
A square is an object that has equal sides
area is calculated by length multiplied by width
so 1225 cm^2 area by using the square root of 1225 cm^2 gives you 35 cm
so each side is 35 cm and there are 4 sides so 35 cm +35 cm + 35 cm + 35 cm = 140 cm
If you are doing homework always show how you got the answer because in an exam having the working out shown can sometimes result in getting some marks even if you slipped up slightly and got the wrong answer.
Nov 05, 2017 | The Computers & Internet
There is a dark spot that is showing up on all my pictures and it's getting larger
To make sure this spot is where I think it is, on the sensor, You should put the camera in manual, A priority and whose the highest value. Shoot in bright light a complete white paper.
Then evaluate the picture on the monitor. If the spot is clearly viable the spot is on the sensor. With a fixed lens on your powershot, you can't repair or correct yourself. You should contact Canon. Don't tell Canon, you were in a moist environment. Perhaps a mould is growing on the sensor.
Feb 06, 2014 | Canon PowerShot Cameras
Canon Sx1IS lens error Hi My Canon Sx1 is is
sounds like the motor is cactus to me, have you checked to see if there is any drive (power) to the motor?
Sep 06, 2013 | Canon PowerShot SX1 IS Digital Camera
I have a Canon SD780IS camera and now notice dark spots on the pictures. I tried cleaning the front of the lens with a Q-tip but they did not go away or move around. I have 2 such cameras . One with 6-8...
to thansen 3:
Yes, eventually everyone who owns this camera will see these dust orbs in every photo they take once the problem appears, and the problem continues to worsen until you will see no image at all. I've had my SD780IS for about 2 years. I was very proud of what this camera could do until the dust appeared and discovered there seems to be no do-it-yourself solution. Canon will "fix" this under warranty.
When Canon returns your camera, it will no longer take sharp photos, but the dust orbs will be gone..... for a little while. Soon, we will all tire of sending these crappy, expensive little cameras back and forth to Canon. All of us will eventually toss this expensive junk and find another expensive Canon to use for about one year before we toss that one too.
The spots appear due to the complex external lens assembly which by its very function (moving in and out) invites particulate invasion. Canon deliberately allows us no recourse for practical maintenance outside of never using the camera. Why didn't I consider this before I purchased? Well, I trusted a corporation whose mission I thought was to provide durable high quality product. The plastic disposable film cameras of yore were an honest version of what we have purchased here.
You may notice a tiny hole on the ring surrounding the lens. My guess is the Canon techs insert a $.25 tool here which with some certain push and twist of the fingers will pop the lens assembly, exposing the CCD and rear lens element for cleaning. Effective reassembly may be another matter altogether as proven by the less sharp images I experienced upon return of the SD780IS from Canon. I have yet to locate any good solution addressing this difficulty. However, my wife still likes this camera despite her 20/950 vision. Some people are very easy to please. When she notices the spots, I'll look into getting her another camera.
Nov 25, 2010 | Canon PowerShot SD780 IS / IXUS 100 IS...
I just purchased (about one month ago)a Canon 50 D with 28-135 is. Yesterday I recieved a Canon 2.8 IS L 70 -200mm. When I mount the camera to the lens ( the 70-200) I notice a little wiggle in the mount...
The larger lens is longer and the wiggle is the same amount of play but closer to the end of the lens it moves more due to it being longer/larger. Just insure there is no substantial movement at the actual connection or lens and body. It should lock in place exactly the same. These are very sensitive cameras and break very easily. Just be careful and you'll be fine.
Sep 02, 2009 | Canon EOS 50D Digital Camera with 28-135mm...
Problem with digital concepts teleconverter
The SX1 has an amazing 20X optical zoom. The teleconverter will allow to get pictures if the camera zoom is not fully on 20X. It means that you can't get a full 40X zoom images, but a 30X maybe. I don't why canon has this problem.
Jul 03, 2009 | Digital Concepts (1352T) Lens Converter
Grainy, Spot Filled Images when using Manual Modes Only
It sounds like the aperture is getting set very high. If the aperture is a high number, the lens opening is very small which lets less light in and would cause a dark image. This would also show any dust that is in or on the lens or image sensor. The dust doesn't usually show on apertures with a larger opening (smaller number). Make sure your aperture is being set to a reasonable number, probably no higher than 8 or so.
Oct 29, 2008 | Canon EOS-20D Body only Digital Camera
1 cm dark spot on left side of LCD
Return it for a refund? Contact the manufacturer? I would need to see this so called dark spot to make a decision on whether it is normal or not..
May 03, 2017 | Cambridge cd_745 Shelf System
Canon PowerShot SD700 IS Digital ELPH / IXUS 800 Digital Camera Logo
63 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
