Question about Sharper Image (SI714SL2) Compact Refrigerator
Fridge Heats but dosen't cool
Someone donated a minifridge the "SI714SL2" if I recall thats the right model number, but the problem is that it heat's up but dosent cool. Some things I noticed is that the fan in the back of the fridege never spins and I have yet to hear anything internally running when it is on cold or even hot.
  • Louis Donalds Mar 26, 2007
    What is the stat? And when I put it on "cold" it get't hot inside as well as the back. So which wire should I check for. IDK what the stat is
  • Kforbregd Jul 15, 2008
    Does the fan have a variable voltage feeding power to it? I only have 5 or 6 volts to my fan motor. That just enough to make it turn slowly.
This fridge uses a Peltier effect cooler sometimes referred to as a TEC or "Thermo Electric Cooler".
In order to cool it must be able to dissipate heat and it sounds like the fan in the back that it uses to do this has failed.
Replace the fan with an 80mm by 80mm 12v computer cooling fan and make sure the fan blows the correct direction.
The fan will have small arrows stamped into it on one of the 4 sides indicating the direction of rotation as well as the direction of air flow.
NOTE: You can use a 3 wire fan (yellow, black, red) if that is all you can locate, just don't connect the yellow tach wire (the wire that reports fan speed to the motherboard of a computer).
Good luck and have fun.
Posted on Mar 07, 2008
    President:
  • 1,462 Answers
Probably the stat - disconnect fro mains, short stat terminals together (but not the earth wire) and check if it runs
Posted on Mar 26, 2007
I Have a Dometic RM2652 it heats up in the back, but, neither the fridge or freeze will cool down.. I've checked the fuses, tried gas and electric.
First thing I would do is check this dometic site for recall information. Have model and serial number ready.
http://67.238.126.140/recall.php
Jun 15, 2011 | Dometic RM2652 Refrigerator
My Dometic refrigerator model # Rm2652 does not cool anymore. The element heats up on both gas and electricity. I noticed an amonia smell and there is yellow matter at the bottom of the stack where the...
Your cooling unit is done, and will need replacement. I will urge you to take down model and serial number and go to their site, or call Dometic , ( www.dometicusa.com) 1-800-544-4881, and inquire whether your unit falls into the recall on some of those models. You may end up with a new cooling unit, free of charge.
May 23, 2011 | Dometic RM2652 Refrigerator
Fridge is not cooling
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
fgsjkysk
Sep 24, 2010 | Sharper Image (SI714SL2) Compact...
Is Model MSD2556AEW one of the fridges being recalled? Our fridge has stopped freezing in the freezing but is cold. The fridge is warm.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Can't find a recall on that..
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
heatman101
Sep 10, 2010 | Refrigerators
Will not cool. Electric is on and there is a strong amonia smell.
TURN THE FRIDGE OFF AND DO NOT USE!!!! Your cooling unit is leaking!!!! You will need to replace either the cooling unit or the entire fridge. There is usually about a 400 dollar difference in the two. Check your model number and serial number of the fridge and call your local dometic dealer to see if it is under recall. You may be able to have it repaired for free. If you provide me with the model, serial number and serial number of the cooling unit (located in the rear through the door on the tank assembly), I can provide you with this information.
Again, TURN THE FRIDGE OFF and DO NOT USE!!!!!
Let me know what happens,
Jeff
Jul 03, 2009 | Dometic Refrigerators
My Dometic trailer refridgerator is warm but freezer is freezing.
Brandi4723,
Unfortunately, you have a bad cooling unit in your refrigerator. Then ammonia smell means that you have a leak in the unit. TURN THE FRIDGE OFF!!! Do not use the fridge on AC or Gas until you have the cooling unit replaced or buy a new fridge. Depending on the model number and serial number of the fridge, it may be under recall by dometic and you might be able to have it repaired for free. If you will provide me with the model number, serial number and the serial number of the cooling unit (found on the outside of the unit in the fridge compartment, lower tank of cooling unit), I can then tell you the pricing of the repairs or whether it is under recall.
Again, TURN THE FRIDGE OFF and do not use it...RISK OF FIRE!!!!
Hope this helps,
Jeff
Jul 03, 2009 | Dometic RM2652 Refrigerator
Honeywell minifridge not cooling, blinking, funny sounds
there is a 1000 Uf electrolytic capacitor on the power supply unit that was bought from a bad supplier. It's suffered a failure as they ALL did. Replacing it with a new 1000 Uf capacitor 16 volts or higher will fix it. Just remember they are polarity sensitive. i found mine at the dump and fixed it in less then 1 hour. The top of it will be bulging out and it could even leak
Jun 07, 2009 | Refrigerators
Refrigerator portion is not cooling
My side by side fridge was doing the same thing. I replaced the thermister and defrost heater. Check to see if you are having an excess of ice building up in your freezer. If you do, your defrost heater (simple little fix needs to be replaced). It looks like a mini flourecent light bulb, except has a spring-like coil that runs through it. This is what heats up coils in your freezer to prevent all the frost build up. If too much frost builds up on the coils, no air can pass over the coils which blows into your fridge portion of your unit. Depending on the type of fridge you have you may have 1, 2 or three different thermisters. These look like little probes, and they act like your thermostat in your home. (It tells the fridge when it needs to run)
Hope this helps!
Dec 02, 2008 | Refrigerators
Fridge and freezer will not cool down
69....hard to know from here. What heats up and becomes quite humid? Newly restarted refrigerators take about 12-24 hours to cool down. They should be opened very infrequently during that period, if possible.. Do you hear the compressor and fans? Have you properly set the cooling controls?
Dec 21, 2007 | KitchenAid Superba Architect KSCS25INSS...
Sharper Image (SI714SL2) Compact Refrigerator Logo
451 people viewed this question
Top Sharper Image Refrigerators Experts
Marvin
Marvin
Gil Shultz
Are you a Sharper Image Refrigerator Expert? Answer questions, earn points and help others
