Question about Mitsubishi VS-50605 50" Rear Projection Television
Mitsubishi vs-50605 i have a problem with my bigscreen when u turn it on it fine for about 30 min and then it start butting lines throughout the tv straight across please help if you can new convergence ics.It should run about 250 for repair from a honest tv repair shop. Best Solutionposted on Mar 22, 2007 this unit needs new convergence ics.It should run about 250 for repair from a honest tv repair shop. need to know if you know a great repair shop in the portland area our oregon city
  • 81 Answers
Where do you live?
Posted on Apr 08, 2007
SOURCE:
Shaky picture once warms uphorizontal lines stream through it continuisly
there are some capacitors on the signal board that are associated with the pwer supply regulators off the 5 volt and other sources there that need to be replaced
if you have the tools and know how and soldering station you can do the repair your self if not then you might want to contact a servicer in your area
i can get you the cap location numbers if you like
Oct 24, 2009 | Mitsubishi VS-50605 50" Rear Projection...
Rolling lines until tv warms up
Vertical output IC bad capacitors in vertical circuit 100uf 35v sometimes vertical IC needs to be resolder and that fixes problem look for poor solder joint s.
Sep 27, 2009 | Mitsubishi VS-50605 50" Rear Projection...
No picture . tvturns, immediately turns off
Your TV set is in protect mode .To protect further damage of some component parts.There is something internal problem inside maybe there is a shorted.
Good luck;
Regards:
VOTIT
Jul 01, 2009 | Mitsubishi VS-50605 50" Rear Projection...
Mitsubishi 50605 Convergence Board - Replacement?
Replacing the whole board will fix it, but is a bit of overkill. If you can solder and feel comfortable working inside the set, you can fix this yourself. Let me know if you wish to attempt the repair and I'll proviode additional details and instructions.
Dan
Oct 13, 2008 | Mitsubishi VS-50605 50" Rear Projection...
Mitsubishi big screen tv
Do the self test first find the error code. Look on here or ctechnicians.com
Jan 02, 2008 | Mitsubishi VS-50605 50" Rear Projection...
Mitsubishi VS-50605 - Colors separated
You have a convergence problem and need to reset
Nov 26, 2007 | Mitsubishi VS-50605 50" Rear Projection...
Mitsubishi vs-50605
does not sound like convergence have had a few with bad capacitors. any good at soldering
Oct 23, 2007 | Mitsubishi VS-50605 50" Rear Projection...
VS-50605 Screen
might measure the opening and buy a piece of plexiglass, wont look quite as good, but cheaper than a new one and usually available at glass shop.
Jul 06, 2007 | Mitsubishi VS-50605 50" Rear Projection...
Lines through picture
Mar 22, 2007 | Mitsubishi VS-50605 50" Rear Projection...
Mitsubishi VS-50605 50" Rear Projection Television Logo
176 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
