Question about Vizio L37 Television
Vizio 37 inch plasma tv changing inputs all by itself
I bought a 37 inch Vizio Plasma Tv in June at Walmart. Two days ago, every now and then the tv will start switching to different inputs by itself. Its like I took the remote and hit the input button several times in a row. Any help would be grateful.
  • Anonymous Mar 26, 2014
    I may have hit a button on the remote but now I have a narrator almost as if it was for the blind. How to I cancel that?
    Genius:
  • 1,003 Answers
Have the mainboard replaced parts found on ebay or shopjimmy.com!
Posted on Feb 08, 2013
    Sergeant:
    Champion:
  • 247 Answers
It sounds like you have a glitch in your tv. i would hope that you have the warranrty for it. and i would contact vizio right away and tell them about your problem and they will have to fix the issue. hope this helps you.
happy holidays,
tom
Posted on Dec 17, 2008
  • Thomas Dec 22, 2008
    Did my solution work for you? If so will you please change the rating to fixya, please?
    Thanks
    Tom
Is there a special bracket to mount the 50 inch D series vizio to the wall?
Many aftermarket mounting brackets are virtually universal in application provided your 50-inch Vizio TV can meet the size and weight limitations stated.
Nov 29, 2014 | Vizio VP504F 50-inch 1080P Plasma TV...
Pixelation
The problem is more or less with the LCD screen itself. The manufatcurer covers dead or burnt pixels.I would suggest contact Vizio Support on the following number
Technical Support
Toll-Free: 877.698.4946
Thanks
proton
Aug 09, 2008 | Vizio Gallevia GV42LF 42 in. LCD...
I have a five year old Vizio P50HDTV20. While watching it the other day the center 1/3 of the screen went black from top to bottom. The left third and right third are fine. This condition persists with...
Sorry the problems,ur tv it is having,it can't be repair,the tv Plasma screen panel itself it is shorted and dead,that why the tv plasma screen panel have only a third of the plasma screen panel it have a good clear picture and the other 1/3 of the tv plama screen panel is black and dead.The tv that have a broken or shorted dead plasma screen panel it is not worth repairing,because only way repair it is by replacing the whole entire plasma screen panel itself.The tv plasma screen are about 90% of the cost of the tv and can't buy it anywhere else except the tv corporations dealers themselves.Sorry tv now,only can be salvages for those electronic boards for parts that it.
Apr 08, 2011 | Vizio P50HDTV20A 50 in. Plasma HDTV
My vizio 50 inch plasma tv will not turn on. what
Tries unplug,replug about an hour,see if it reset itself.Not than must replaced the signal tuner board.Plasma have this problems alot.
Jan 08, 2010 | Vizio P50HDTV10A 50 in. Plasma HDTV
My vizio 37" plasma tv has a green line running down the right side of the screen
Vizio does not make 37" plasma TV. for the green line problem, does it happen on all inputs or just when you what TV (cable or satellite)? That line should only be present on some channels due to signal processing compatibility. To get rid of it, you can use the horizontal size adjustment and expand the picture side way.
Jul 03, 2009 | Vizio L37 Television
50" Vizio Plasma reads "No Signal" on all inputs?
Well, your TV is still under warranty. That's the good part.
The only thing I can recommend without voiding the warranty is leaving the TV unplugged for 30min. That way, the TV can reset itself and hopefully correct the problem.
If that doesn't solve the problem, it's time to use the VIZIO warranty.
Here's contact info if you need it.
Technical Support
(877 MY V I Z I O)
Technical Assistance Emails:
techsupport@vizio.com
Customer Service
Toll-Free:888.849.4623
(888 VIZIO CE)
Jun 17, 2009 | Vizio VP50 10A 50 in. Plasma TV
We also have a Vizio with red horizontal lines and our TV is new
It's possible that the motherboard or the controller board for the screen is defective. At this point, I would use the warranty from Vizio. It should be no doubt that it covered. Here's the info you will need from the Vizio web site.
http://www.vizio.com/support.aspx?id=1588
Jun 13, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
I just got a Vizio 37" TV from Walmart.When I turn it on, I get a blue screen that says No Signal. Help.I have Dish Network. What am I doing wrong?
Check that the connection where the dish box is connected to the TV is the selected input on your TV.
You should have either a component connection (5 cables) or HDMI (1 cable) connecting the dish box to your TV. The VX37 has two component inputs and two HDMI inputs (if I remember correctly). Use the INPUT button on your remote to select the correct input.
Once you confirm this and still have problems, post a response and I will follow-up.
Dec 21, 2008 | Vizio P2 42 in. HD-Ready Plasma Television
Vizio GV42L LCD TV screen black when turn TV on first time
If you are using a set top box this might be caused by turnig the box on at the same tie as you turn the tv on or slightly after you turn the tv on.  If you are using compnent or HDMI inputs the set needs to see the signal as it is turned on to know what formt the signal is in.
I’m happy to help further over the phone at https://www.6ya.com/expert/dewayne_4a10eab6caecdb92
Oct 15, 2007 | Vizio P2 42 in. HD-Ready Plasma Television
Vizio L37 Television Logo
298 people viewed this question
Top Vizio Televison & Video Experts
pzarnold
Level 1 Expert
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
