Question about Brother IntelliFax-2820 Laser Fax
Brother Fax 2820
We have changed the main PCB with new one but no action on display. Some thing appears on display and nothing is happened. Actually, we have replaced the main PCB of this machine into a other machine. Now we got new main PCB and fixed in that new machine but problem is same as mentioned above.
Brother Intellifax 2820 LCD screen has no display, all other things work fine.
Posted on Jul 26, 2011
    Scholar:
  • 75 Answers
Sorry to say but the new board needs to be flashed. Only can be done by a authorized service center.
Posted on Jan 30, 2009
1E code display. Checked water pressure, changed inlet valve and float. Still 1E code
You need to check the voltage on the inlet valve coil terminals to see whether the main control board is actually switching the valve on to take in water.
If not replace the main control board PCB as this is the only other problem remaining.
Mar 08, 2015 | LG 24 in. LDS 5811ST Stainless Steel...
Electrolux washing machine wh1092 when turn on lights 1,4 and 8 flashes. Nothing happens
If I understand correctly there is blinking LED-s from "Prewash","Rinse Hold" and "End of cycle". In binary code it is fault E91 what means communications error between main PCB and display board.
So, could be: main electronic PCB, display board or wiring.
Dado
Dec 13, 2014 | Electrolux Washing Machines
I have installed a new LCD screen on my acquasmart WL80T65CW1 and teh csreen now shows fault code 9. Please advise how to get rid of it and resize machine. Thanks.
Hi
If ever you replace the display PCB or the main controller PCB then you must set the size of the machine in to the memory of the controller. This should of been in the instruction sheet that came with the display.
This Is Fault Code 9 ,which indicates Size setting or
size error . When you changed the display did you size your machine to the new display module? Did you get the re-size set of instructions with the new display board? Ring up where you brought the display from and i"m sure they can help.
If this appears in your screen it will be necessary to set the size of the Aqua smart....
1. Press and hold the SPIN button, then press the POWER button until three beeps are heard.
2. Press the FABRIC SOFTENER button once to size the machine.
3. Press the POWER button.
If nothing works you need to reset your machine, please check the bellow link to get the manual and check page 18 and 23 for the reset instructions.
http://www.fisherpaykel.com//admin/pdfs/pdf_usecares/3731_LCDLED_Aquasmart_FINAL.pdf
Please get back to us if you have further query else please accept the suggestion.
Mar 20, 2011 | Washing Machines
Error e000733
E733
0001 A fault is detected by the main controller PCB in the communication between
the DC controller PCB and the main controller PCB.
Main cause The connector has poor connection. The DC controller PCB is faulty.
Action
1. Connector, DC controller PCB
Is the connection between the connector J1015 on the main controller PCB
and the conductor J316 on the DC controlled PCB normal?
NO: Correct the connection.
YES: Replace the DC controller PCB.
Mar 04, 2011 | Canon imageRUNNER 2200
My samsung 540n monitor wont display only white light, how to resolve it?
if only white display is appear on screen it's means the problem is in main pcb section. its may be a loose contacting of the flap beetween main pcb & lcd panel. plz check it. if the main pcb will defective then no way to repair and replace the pcb.
Mar 03, 2010 | Samsung SyncMaster 540N 15" LCD Monitor
Error code e000733-0001
E733
Action
Jan 23, 2010 | Canon (6981A002AA) for imagerunner 2200,...
Canon powershot A80 camera. LCD display works fine but no picture. Camera will take pictures but no display and nothing but black appears on download. Everything else works fine. I think it is the lense?
Sounds like the CCD or the Shutter are not working. Canon only sells the CCD as part of the optical unit, which includes the shutter. However the new optical unit will require reprogramming of the main pcb to focus correctly
Nov 11, 2008 | Cameras
Inverter PCB
if you can remove it get the part num or you can give to a service personnel to replace for you
May 28, 2008 | Televison & Video
Samsung cooltech SRL551DP
no i did not solve it, i changed the main pcb, probes ( all ) and the pcb in the door behind the display. i also disconeted the defrost heater and the other heater ( they are the brown and white wires up top going into your main pcb ) that did nothing either. as far as i can tell it happens every 10 -12 hours, no one on this site has been able to help? if you find out what it is could you let me know, im over re-seting it but used to it now.
Thankyou.
Mar 16, 2008 | Refrigerators
Brother IntelliFax-2820 Laser Fax Logo
207 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
