Question about Sony KV-27S42 27" TV
Part no of VDR505 in KV-27S42
I connect my KV-27S42 which is 120V AC to a 220V AC source by mistake. power fuse and VDR-505 got burned,
hopefully that is all. need to know the model no. of VDR-505 to replace it. can any one help me please?
also if you advise me to test any other part that may have gone worng due to my mistake.
Many thanks to any contribution
  • 4,234 Answers
This part is a varistor part number 1810107051 which is available from for $9.09.
Posted on Dec 17, 2008
I accidentally plug my Wii that I got from US from 120v to 220v. I got the converter but I mistakenly plug it to the wrong voltage:(. I heard the poop sound. Did I burn the power adapter or the wii it...
You have most likely cooked the Wii itself, To check connect the correct power adapter to the correct system and in the correct power source ( 120v or 220v ) if it works all good if not you know you cooked it. If you are unable to test in this manner have it checked by a qualified technician.
Jan 11, 2013 | Video Game Consoles & Games
Dead NAD M15
There are fuse inside Nad M15. If you open the top cove then you can see there are 9 fuses lined up i the circuit board on the right side of the transformer. Check these fuses. Also check is there is any fuse behind the Power one of switch. If it is faulty the replace the same.
Before connecting the power after replacing the fuse. check the working voltage marking at the back side. Is it 120v or 220v. If its 120V then be sure that you are using 120V AC line.
If any fuse blows of when you connect the power then you have to consult any nearest service station.
The Voltage rating and Amps rating of the fuse can find marked up on the two metal strips at the two ends. My be laser mark or punching.
Check the link bellow to see the fuses
Check the 12th picture on the link.
Jul 29, 2012 | NAD M15 Amplifier
Hi, i have a dream machine sony ICF-c218 by mistak connected to 220v the original transformer is 120V & i also would like know the output voltage of this transformer so that i can change it 220V p
My self sushil from india pl.find the details
yellow-blue is 3.2 VAC
red-white is 4.2 VAC.
Clock is well functioning without frequencies difference error. I think the clock is using crystal for pulses generator instead of AC power supply frequency.
May 22, 2012 | Sony Audio Players & Recorders
The fuse of my Sony KV-27s42 somehow got burnt.Can anybody tell me what is the fuse model and where to buy it?
The fuse rating is printed in the main board beside the the fuse terminal, to purchase the fuse it is available in all electronics shop.
Sep 03, 2011 | Sony KV-27S42 27" TV
Good morning, I bought a dryer from Sears, model 11068002010, but I took it to Morocco. So I need to know how to connect it. In Morocco we have 220V electricitu power. Cood you please send me the...
Most dryers manufactured in the US are rated for 120v ac and will not operate on 220v ac.
You may want to look into the possibility of getting a 220v to 120v step down transformer.
Mar 03, 2011 | Dryers
I am trying wire a motion Senior its has 3 wires coming out the back red white black
To connect a separate motion detector to a light fixture (and assuming the fixture uses incandescent or the newer twisted florescent light bulbs), the RED wire from the detector is attached to the black ("hot") wire from the fixture; the WHITE wire from the detector is attached to the white wire from the power source; the BLACK wire from the detector is attached to the black ("hot") wire from the power source. Sometimes the white and black wires from the power source are mixed up, reversed. So it is best to check to determine which wire is actually "hot" (shows voltage in a meter between the wire and the ground wire or the metal box the power wires come from). In general, a colored wire (often black) in the power source, if wired properly according to accepted custom, will be "hot" and 120v in US. The white wire in the power source is called the "neutral" and should be neutral with the ground wire and/or the metal box. If there is another colored wire in the power source (often red) and if it is not taped with some black tape (to indicate it is really a black wire), then it too may be a 120v. hot wire, but it may also be an 120v. hot wire that is 120v opposite the other 120v wire. That is, one 120v wire is 120v+ and the other is 120v- The difference in voltage between these 120v wires + and - is, hence, 220v. If you see multiple colored wires, it is also a good idea to check the voltage between them to know if you are dealing with a power source that entails 220v. In short, you want to know what you are doing, obviously for personal safety, but also to accomplish what you want... to properly connect the motion detector.
Dec 12, 2010 | Home Security
Wii power source probably broken
Plug something else into the adapter to make sure it works, if it works you may have blown the Wii's fuse which will need repair.
Jul 28, 2009 | Nintendo Wii Console
Plugged 120v window AC into a 220v socket
Window air conditioners generall do not have fuses.
Jul 24, 2008 | Heating & Cooling
Blown Subwoofer
Hi , you will have to open the box and check for any fuses along the power input line, replace them if any and try it out but i strongly believe what happened there is that you fried the power supply in your subwoofer , there is no easy fix to this , you will need to replace the transformer and possibly check to see if the rectification circuit is damaged too, and the amplifier too. Good luck
Mar 21, 2007 | Logitech X-230 Computer Speakers
Sony KV-27S42 27" TV Logo
152 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
