Question about Directed 1100d Car Audio Amplifier
My 1100d directed amp cuts n and out as i play it, and sometimes
I got a 1100d directed amp and it cuts in and out as i play it.... also it takes a few mins for it to turn on... I had orion 600d b4 this amp and every thing was fine so i am sure it has 2 be the amp. and if it is the amp where can i send it to be repaired? thx
  • 15,935 Answers
Most reputable car audio shops can give you (or have thier own) repair techs. is the new amplifier rated down to the same impedence you have your subs wired to?
Any protection lights coming on the face of the amplifier?
It has a lights that come on for Thermal, DC offset, over/under voltage, reverse polarity and short circuit protection.
May be a faulty turn on module.
Get it repaired before more happens internally for a costlier repair.
Posted on Dec 22, 2008
The green light and protection light on my 1100d constantly blink and the interior lights in my car blink in sequence with the lights on the amp and I get no sound out of the amp and sub setup. What could...
Sounds like you have an issue with the amp, the install, or possible blown subs.. check, test and if all else fails get the amp serviced or get a new amp.
A good car audio shop can also help you check it over.
Feb 06, 2011 | Directed 1100d Car Audio Amplifier
I have orion 8004 connected to 2 ev`s and it wont turn on everything is connected correct but the amp doesnt turn on,It just blinks red every 5 mins and one knows what could be wrong ? or how much to fix ?
check the ground this is the most important part of a system! it shold be grounded directly to the fame and to bare clean metal NO PAINT! then check the ohm od from the subs. make sure it not too low for the amp to hadle. if its too low the amp could go into protection. if not the amp couldbe internally shorted or the power supplies might be shot. i cant give you an exact price bt my guess would be $100-$200 depending on he exact probm
Sep 14, 2010 | Orion 8004 Car Audio Amplifier
How install orion 600d to kiker 12sl5 subwofeer
Look up your question on youtube. Honestly it will help clear things up a lot. Don't worry about the exact subwoofer your connecting it to. But type in "how to connect orion 600d amp to a 12 subwoofer(s)
Mar 03, 2010 | Orion 600D Car Audio Amplifier
Ihave an orion 6000 what is the power rating of
I am sure you have misread the number on the amp. Look again you should see 600D. here is the link to the PDF on your Amp. http://www.directed.com/guides/manuals/og/orion/G47395.400.405.410_11-04.pdf
I hope this helps if not I will try to down load it for you and post it directly to the reply.
Roy
Dec 01, 2009 | Orion HCCA-D5000 Car Audio Amplifier
How do i connect a directed 1100d amp to a jl audio 10w3v2-dual voice coil
Hello disciple_sco,
The 3v2-D4 Jl's have 4ohm voice coils. The 3v2-D2's have 2ohm voice coils. If you have the D4, you should run the voice coils in parallel, both positives and both negatives to the respective amp terminal. This will result in a 2ohm load to the amp. If you have the D2, I'd series the voice coils, jumper one positive to the other negative and connect the other positive and negative to the amp terminals. This will result in a 4ohm load to the amp.
Hope this helps.
Jul 02, 2009 | Directed 1100d Car Audio Amplifier
Car Audio problems
If your voice cuts off when you use too much power i.e. operating power windows you are taking power away from your amp. An amp operates in stages; therefore you must increase the available (battery) power in your vehicle; possibly you can run two batteries (do not connect them in series)
May 14, 2009 | Car Audio & Video
Directed 1100d is it 1 ohm stable?
I don't know how you are coming up with a total load of 1 ohm , but if you do manage to hook that amp to a 1 ohm load you will almost certainly blow that amp. Good luck and please don't forget to rate this answer.Thanks.
Apr 12, 2009 | Directed 1100d Car Audio Amplifier
Directed 1100 d turns on but no sound
hi there
few steps to try
1) try grounding amp to a new location
(make sure the amp is grounded by itself)
2) check the power wire from the battery to the amp
3) if the 2 steps don't solve the problem try turning your amp settings down and disconnect the power wire from the amp after a few seconds reconnect the power wire and amp should reset itself.........
if this doesn't work let me know there are other tricks that can be done but these are the most common firsts to be tested (also make sure the ground wire is larger than the power wire)
hope this helps
Mar 04, 2009 | Directed 1100d Car Audio Amplifier
Directed 1100d Car Audio Amplifier Logo
171 people viewed this question
Top Directed Car Audio & Video Experts
Marvin
Marvin
Colin Stickland
Colin Stickland
Ric Weide
Ric Weide
Level 1 Expert
Are you a Directed Car Audio and Video Expert? Answer questions, earn points and help others
