Question about Whirlpool Duet GHW9150P Front Load Washer
It gives a f-11 code but diagnostic always works fine
We bought this machine in 2004 and started replacing parts from the get go. First the drum leaked so fixed that then had to much soap figured that out ,now for the last two years it flashes F-11 code or door unlocked , unplugging and running the diagnostic check usually seems to be a short term fix, but lately I noticed the drain pump is really noisy, and today the door would not unlock for my daughter. Plus the bonus crappy smell this thing gets is a giant step backwards! The weird thing is every time we run the diagnostic it checks out fine. I got spoiled from our last washing machine it lasted fifteen years and still running washing rags at work, I could of bought five of those machines for this thing. help
  • 100 Answers
Http://www.applianceaid.com/duet_washer.html
just click the given link
F-11 MEANS================
Serial Communication Error
Communication between the Central Control Unit (CCU) and the Motor Control Unit (MCU) cannot be sent correctly.============== Check Wire Harness connectors to the MCU, the motor, and Central Control Unit (CCU) Check the Drive system for any worn or failed components Check MCU Check CCU Check Motor Check Wire Harness
Posted on Dec 17, 2008
Lg washer fills, starts to wash but stops
have you checked brushes on motor
Jan 27, 2014 | LG Washing Machines
I have a Kenmore HE3t washer than continues to stop during the cycle and flash the F2 error code even after cleaning out lines, hoses, trap, boot and replacing the drain pump.
It is possible that the brushes on the motor that spins the drum are worn down. The drum will start and stop when this happens. Check the brushes.
Nov 07, 2013 | Kenmore Washing Machines
Replaced bank 1 and bank 2 downstream oxygen sensors on 2004 5 speed automatic diagnostic code still says not working
Try resetting the codes by removing both terminals on the battery for 10 minutes. After the codes should be rest if they do not come back on the sensors are fine.
Jun 28, 2013 | Cars & Trucks
Audi a4 1998 all engine names/parts
Check the help link related to Acura car models:---
How to Clear OBD error Codes on Acura Car Models?
http://repairhelpcenter.blogspot.com/2011/11/how-to-clear-obd-error-codes-on-acura.html
Diagnosis and Testing Car Components?
http://vwrepairhelp.blogspot.com/2011/11/diagnosis-and-testing-car-components.html
Diagnostic Trouble Codes list for Acura Car Models?
Part 1.
http://repairhelpcenter.blogspot.com/2011/11/diagnostic-trouble-codes-list-for-acura_18.html
Part 2.
http://repairhelpcenter.blogspot.com/2011/11/diagnostic-trouble-codes-list-for-acura.html
Underhood components http://www.howtorepairguide.com/2012/11/lincoln-underhood-components.html
How to replace Power Rack and Pinion Steering Gear on Acura Car Models?
http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-power-rack-and-pinion.html
How to replace Power Steering Pump on Acura Car Models?
Also bleeding:
http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-power-steering-pump-on.html
How to replace Steering Linkage on Acura Car Models?
http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-steering-linkage-on.html
How to replace Steering Wheel on Acura Car Models?
http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-steering-wheel-on-acura.html
How to replace Power Steering Pump on 1999 Acura TL? http://howtobyme.blogspot.com/2011/11/how-to-replace-power-steering-pump-on.html
How to Test and Replace Fuel Injectors on Acura Car Models?
http://repairhelpcenter.blogspot.com/2011/11/how-to-test-and-replace-fuel-injectors.html
How to replace Fuel Tank Assembly?
http://vwrepairhelp.blogspot.com/2011/11/how-to-replace-fuel-tank-assembly.html
FUEL LINES AND FITTINGS on Acura Car Models?
http://repairhelpcenter.blogspot.com/2011/11/fuel-lines-and-fittings-on-acura-car.html
Replacing Fuel Charging Assembly on Car?
http://vwrepairhelp.blogspot.com/2011/11/replacing-fuel-charging-assembly-on-car.html
Intermittent Charging Problem with Engine warning Light?
http://whoisbyme.blogspot.in/2012/07/intermittent-charging-problem-with.html
How to replace Fuel Pressure Regulator on Acura Car models?
http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-fuel-pressure-regulator.html
How to test Fuel Pressure and replace Fuel Pump on Acura Car models? http://repairhelpcenter.blogspot.com/2011/11/how-to-test-fuel-pressure-and-replace.html
These will help.
Thanks.
Nov 22, 2012 | 2004 Audi A4
How to fix code 11 on my 2004 r6
Hi, Anonymous for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
http://www.r6messagenet.com/forums/r6-maintenance-technical/126098-fault-code-11-a.html
Yamaha Fault Codes motorcycle manuals
2003 2004 Yamaha YZF R6 Service Manual R6 Moto Data Project
OEM parts for Yamaha
http://mybikemanuals.com/yamaha/yamaha-yz-owners-manuals
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Aug 28, 2012 | 2004 Yamaha YZF-R6
Fix camshaaft timming on 2004 dodge ram1500 47cui
For this problems,check the help links below,click the link to o through its troubleshooting procedure :-----Crankshaft and camshafts timing marks? http://technoanswers.blogspot.in/2012/02/crankshaft-and-camshafts-timing-marks.html---------- dual over cam timing mark details? http://technoanswers.blogspot.in/2012/02/saturn-vue-30-dual-over-cam-timing-mark.html---------- How to replace Adjustable Camshaft timing solenoid? http://technoanswers.blogspot.in/2012/02/how-to-replace-adjustable-camshaft.html------------ How to Inspect Camshaft? http://repairhelpcenter.blogspot.in/2012/02/how-to-inspect-camshaft.html
camshaft Timing specifications? http://technoanswers.blogspot.in/2012/02/ford-mondeo-st220-camshaft-timing.html
Crankshaft Front Seal? http://schematicsdiagram.blogspot.com/2011/12/crankshaft-front-seal.html
How test cam shaft? Testing Car Camshaft? http://repairhelpcenter.blogspot.in/2012/02/how-test-cam-shafttesting-car-camshaft.html
How to service Cam Shaft? Camshaft servicing? http://repairhelpcenter.blogspot.in/2012/02/how-to-service-cam-shaft-camshaft.html
How to replace Camshaft? Replacing Vehicles Cam Shaft Assembly? http://repairhelpcenter.blogspot.in/2012/02/how-to-replace-camshaft-replacing.html
For OBD code problems check the list of help links below. Click the link below to go through its procedure.
Diagnostic Code P2195? http://schematicsdiagram.blogspot.in/2012/02/diagnostic-code-p2195-on-toyota-avalon.html
Diagnostic code P1330? http://technoanswers.blogspot.in/2012/02/diagnostic-code-p1330-on-kia-2wd.html
Diagnostic code P0700, P1330, P1121? http://technoanswers.blogspot.in/2012/02/diagnostic-code-p0700-p1330-p1121-on.html
shows error code P1330? http://technoanswers.blogspot.in/2012/02/2003-kia-sorento-shows-error-code-p1330.html
OBD code P1330? http://technoanswers.blogspot.in/2012/02/obd-code-p1330-on-2003-kia-sorento.html
OBD code P01300? http://technoanswers.blogspot.in/2012/02/obd-code-p01300-on-toyota-rav4.html
OBD code P0768? http://repairhelpcenter.blogspot.com/2012/01/obd-code-p0768.html
Evaporative Emissions System codes details? http://schematicsdiagram.blogspot.com/2011/11/evaporative-emissions-system-codes.html --------------- Engine Misfire codes?
http://schematicsdiagram.blogspot.com/2011/12/engine-misfire-codes-on-chevrolet.html
Misfire on cylinder 4?
http://schematicsdiagram.blogspot.com/2011/12/misfire-on-cylinder-4.html
ABS trouble codes for all models?
http://repairhelpcenter.blogspot.com/2011/11/abs-trouble-codes-for-all-1994-00-acura.html
Diagnostic code P0010? http://schematicsdiagram.blogspot.com/2011/12/diagnostic-code-p0010.html
Diagnostic Code P1396?
http://howtobyme.blogspot.com/2011/11/diagnostic-code-p1396.html
Code P0452?
http://howtobyme.blogspot.com/2011/11/code-p0452.html
OBD code P0172 on Buick?
http://howtobyme.blogspot.com/2011/11/obd-code-p0172-on-buick-park-avenue.html
DTC Code P0321?
http://howtobyme.blogspot.com/2011/11/dtc-code-p0321-on-buick-park-avenue.html
Error Code P0471?
http://howtobyme.blogspot.com/2011/11/error-code-p0471-on-2007-dodge-ram-3500.html
P0304 Error code?
http://howtobyme.blogspot.com/2011/11/p0304-error-code-on-dodge-neon.html
OBDII scan is receiving NO BUS CODE?
http://howtobyme.blogspot.com/2011/11/obdii-scan-is-receiving-no-bus-code.html
How to Clear OBD error Codes?
Diagnostic Trouble Codes list?
Part 1.
Part 2.------
OBD Code is cleared but check engine light will not RESET?
http://schematicsdiagram.blogspot.in/2012/02/obd-code-is-cleared-but-check-engine.html
Diagnostic Code 43 and 71?
http://schematicsdiagram.blogspot.com/2011/12/diagnostic-code-43-and-71-on-1991.html
Code P0132?
http://schematicsdiagram.blogspot.com/2011/12/code-p0132-on-acura-tl.html
P0031 code?
http://schematicsdiagram.blogspot.com/2011/12/p0031-code-on-dodge-dakota.html
How to get diagnostic Code without OBD Scanner on Pre 1995 cars?
http://schematicsdiagram.blogspot.com/2011/12/how-to-get-diagnostic-code-without-obd.html
OBD-II Trouble Code P0300?
http://schematicsdiagram.blogspot.com/2011/12/obd-ii-trouble-code-p0300.html
Getting diagnostic code P0016?
http://schematicsdiagram.blogspot.com/2011/12/getting-diagnostic-code-p0016.html
How to Read Codes from Check Engine Light?
http://schematicsdiagram.blogspot.com/2011/12/how-to-read-codes-from-check-engine.html
Diagnostic Code P0540 continues to return and the MIL light is on?
http://schematicsdiagram.blogspot.com/2011/12/diagnostic-code-p0540-continue-to.html
DTC Trouble Code P0401?
http://schematicsdiagram.blogspot.com/2012/01/dtc-trouble-code-p0401.html
Car misfires and error code P0306 and P0303 is shown?
http://technoanswers.blogspot.com/2012/01/car-misfires-and-error-code-p0306-and.html
Diagnostic code P0463?
http://technoanswers.blogspot.com/2012/01/diagnostic-code-p0463-on-ford-f250.html
Check engine light with codes P2195 and P2197?
http://howtobyme.blogspot.in/2012/01/check-engine-light-with-codes-p2195-and.html
Diagnostic error code P0121,P0505,P1000,P2101,P2104, P2110,P2135,P2106?
http://technoanswers.blogspot.in/2012/01/diagnostic-error-code.html
P0174, P0037 and P2197?
http://technoanswers.blogspot.in/2012/02/p0174-p0037-and-p2197-on-toyota-rav4.html
P0352 Obd code?
http://technoanswers.blogspot.in/2012/02/p0352-obd-code-on-toyota-rav4.html
Error code p0402?
http://technoanswers.blogspot.in/2012/02/error-code-p0402-on-ford-escape.html
Obd Code P0763?
http://technoanswers.blogspot.in/2012/02/obd-code-p0763-on-lexus.html
OBD code P0301, P0430 and P0174?
http://schematicsdiagram.blogspot.in/2012/02/obd-code-p0301p0430-and-p0174.html
OBD code P0500?
http://schematicsdiagram.blogspot.in/2012/02/obd-code-p0500-on-lexus-rx-300.html
This will help.
Thanks.
Feb 28, 2012 | 2004 Dodge Ram 1500
Town Car 2004 wont start on first try
Car not starting or turning over indicates towards multiple possibilities. It can be issue with battery or weak battery. But if battery checks out ok, then it can be starter issue or faulty alternator or problem with low fuel pressure or no spark at spark plugs due to dirty spark plugs or faulty ignition coil or injectors getting cracked or dirty and needs to be cleaned.
To confirm the problem, the basic troubleshooting is required.
Click this link below and follow the troubleshooting:------
http://technoanswers.blogspot.in/2012/02/car-starting-issues.html
For OBD code problems check the list of help links below. Click the link below to go through its procedure.--------------Diagnostic Code P2195?http://schematicsdiagram.blogspot.in/2012/02/diagnostic-code-p2195-on-toyota-avalon.html--------------Diagnostic code P1330?http://technoanswers.blogspot.in/2012/02/diagnostic-code-p1330-on-kia-2wd.html------------Diagnostic code P0700, P1330, P1121?http://technoanswers.blogspot.in/2012/02/diagnostic-code-p0700-p1330-p1121-on.html-------------shows error code P1330?http://technoanswers.blogspot.in/2012/02/2003-kia-sorento-shows-error-code-p1330.html--------OBD code P1330?http://technoanswers.blogspot.in/2012/02/obd-code-p1330-on-2003-kia-sorento.html------------OBD code P01300?http://technoanswers.blogspot.in/2012/02/obd-code-p01300-on-toyota-rav4.html--------------OBD code P0768?http://repairhelpcenter.blogspot.com/2012/01/obd-code-p0768.html------------Evaporative Emissions System codes details?http://schematicsdiagram.blogspot.com/2011/11/evaporative-emissions-system-codes.html--------------- Engine Misfire codes?
Diagnostic code P0010?http://schematicsdiagram.blogspot.com/2011/12/diagnostic-code-p0010.html-------------Diagnostic Code P1396?
Code P0452?
DTC Code P0321?
Error Code P0471?
P0304 Error code?
Part 1.
Part 2.------
Code P0132?
P0031 code?
P0352 Obd code?
Error code p0402?
Obd Code P0763?
OBD code P0500?http://schematicsdiagram.blogspot.in/2012/02/obd-code-p0500-on-lexus-rx-300.html
-----------This will help.Thanks.
Feb 22, 2012 | 2004 Lincoln Town Car
Intrepid Issues
Code P0452?
DTC Code P0321?
Error Code P0471?
P0304 Error code?
Part 1.
Part 2.------
Code P0132?
P0031 code?
P0352 Obd code?
Error code p0402?
Obd Code P0763?
OBD code P0500?
This will help.
Thanks.
Feb 13, 2012 | 2004 Dodge Intrepid
#2 and #6 misfire- I replaced the plugs this summer and #8 coil pack also (because it was causing issued). It was fine until the past 2 weeks. I just replace the #2 and #6 coil packs and nothing has...
You got a PO302 &PO306 code
Welcome to ford diagnostics
The codes do not always coincide with the problem
I won't write a book here, let me know what started
the recent issue,what was done,and by whom
You I believe,the pros,not so much
Point I'm making,do you have a MIL Lamp on?
Do you have codes?
Has it gone into Fail-Safe
Have you made sure you have no vacuum leaks, if
someone other than yourself worked on it?
What is the problem,starting,driving,up hills,shift points,etc
give me all you got
Dec 02, 2010 | 2004 Ford F150
The Drum turns, but no heat, is it ok? Different machine, same problem. I've switched out the timer, thermostat/fuse assembly, and element. Though the feedback for this machine was great when I bought...
check your breaker, sometimes if one side of the 220v breaker trips and not the other then the dryer will run with no heat. if you have a voltage meter then check the outlet itself for a full 220v.
Jun 27, 2008 | Haier XQG50-11 Front Load Washer / Dryer
Whirlpool Duet GHW9150P Front Load Washer Logo
85 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
