Question about Epson AcuLaser C900 Printer
C90 epson printer "appears" Cannot be used error
How to fix my epson c90 printer? resting it appears "cannot be used ERROR"
    Problem Solver:
  • 10 Answers
c90 epson printer
1/ first of all please , don't forget change , date vacate , , date , please ( yes sir ) , ,
2/ begin , adjustment , will go up this window comes to , click already at , Accept ,
3/ , click already at , Perticular adjustment mode ,
4/ click at , Waste ink pad counter , to strip [c90 epson printer "appears" Cannot be used error - clip_image008.jpgen press , ok ,
5already will go up a window , Waste ink pad counter , click at , check ,
6/ press , ok ,
7 / click already at , lnitiailzation ,
8/ press , ok ,
9/ last step , press , ok , then close , then open again , only ( yes sir ) , ,
Posted on Jan 15, 2009
I want driver for epson printer stylus c90
You can download the Epson printer drivers from their support WEB site. Please click on this link and select your model printer to download :-
http://www.epson.com/cgi-bin/Store/jsp/index.do?BV_UseBVCookie=yes
Nov 26, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Printer epson c90 lampu merah kedip2
please your pc in old printer instoll is remove the printer driver.
and second time restart pc and instioo the reinstoll and you so this progreemis in prosses when comming the earrer
is problem ok
Sep 27, 2009 | Epson Stylus Photo R300 InkJet Printer
My printer have a problem of general error
Key in " epson reset software" in your web browser search bar. The uppermost link. There's tutorial in it read it before doing so.
Or you can also check my previous post regarding epson printer. Its in cluster 11. Check my suggested solution there.
Apr 29, 2009 | Epson Office Equipment & Supplies
Epson c90 paper feed problem
Is the message general error? The problem is tchip. When turn on chip is recognized by printer, but when start to print, printer "read" some information from the chip. Here is the error. Some pin at the chip for redaing the existence of chip, other pin for reading the information. Check connector between chip and carriage.
Apr 17, 2009 | Epson Stylus C86 InkJet Printer
Parts inside your printer are near the end of their service life.
if you put this in google ssc download it and this will reset your printer hope this helps
Feb 26, 2009 | Epson Office Equipment & Supplies
i have a problem with my printer epson stylus C90. may i know what to do when parts of my printer are near the end of their life service.? how can i fix it?
Dec 07, 2008 | Epson Stylus Photo R300 InkJet Printer
I dont know how...
Unraqr the c90.rar file and copy the extraction to any folder on your hard disk (for future frequent use).
The following only works after refilling the cartridges or using a continuous ink system.
Note: This is for the Epson C90; there are a lot more printer specific resetters. Mine is Indonesian.
Note: This does NOT work if the system date is NOT set at July 15, 2007 !!
1. Set the system date to July 15, 2007.
2. Go to MY COMPUTER, open local disk C: then delete the ADJUSTMENT PROGRAM FOLDER (if present)
3. Close local disk
4. Click START, RUN, type REGEDIT
4. Open HKEY LOCAL MACHINE
5. Open Software folder
6. Open Epson folder
7. Delete PTSG folder (right click, remove=yes)
8. Open Epson C90 Resetter folder and start adjprog
9. Click ACCEPT button
10. Click SELECT button to go to port menu. Selected designated port number (USB ...)
11. Click the "Particular Adjustment Mode" button
12. Double click the "Waste Ink pad Counter"
13. Click the "Check" button
14. Click the "Initialization" button.
15. Turn of the printer and press "OK"
16. Turn on the printer and wait until the maintenance procedure has finished
17. Close the panels of the Adjustment program
18. Reset the date to the current date.
Note: Print these steps for future use.
Note: With a continuous ink system, make sure that the ink filling cable is not to tight; the print head with the attached ink
cabling must be able to freely move all the way to the left inside the printer. Also make sure that none of the ink tubes is squeezed tight by the black plastic clamps that are used to attach the system to the outside (front) of your C90. Place them so that the transparent cover stays slightly open.
Note: With a continuous ink system, be sure to use the "lock roller" on the ink system to close the ink supply when the printer is not in use; otherwise your ink evaporates.
Note: The continuous ink system is quite erratic in its signalling: when one of the colors is about 1/3 full on the Epson monitor, the printer might stop suddenly and display the cartridge X signal. Sometimes, with 2 colors X-ed, you have to do the procedure twice!
I don't know where you got the C90.rar download. You must have the following files:
AdjProg.exe
Apdadrv.dll
EditText.dat
StrGene.dll
If you don't have them all or miss some, pls e-mail me (hanshufkens@yahoo.com) and I'll sent them to you (attachment is about 2 MB)
Last: The C90 is a **** printer. After 4 months of use the paper adjustment goes to hell, so with printing you never know if printing will start before the paper is properly loaded. Might as well buy a new printer (NOT Epson!).
Jul 23, 2008 | Epson AcuLaser C900 Printer
Printer reset
Solution :
1. Pwer on switch and the other switch at once, after start up the printer press 4 times the resume key and, restart the printer again, and the best solution for it by resetting the printer counters by using sss servicing utility, u can download it free.
Mar 09, 2008 | Epson AcuLaser C900 Printer
Epson AcuLaser C900 Printer Logo
296 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
