Question about Dishwashers
My Zanussi DW905 hasn't drained after washing fine. ANy quick tips before I totally dismantle it?
Our same mode dishwasher has just started doing the same thing. We have completely cleaned the filters and moveable parts around the spray arm with no luck. I am aware that with some model dishwashers (usually newer ones) they have an anti flood float that can be activated in if there is a minor pump blockage renderering the draining useless. I'm going to remove the d/w and lay it flat on its back to see if this helps. I think i'm a bit optimistic and the pump is stuffed though.
If you have any ideas i'd be greatful to hear them.
Cheers,
Chris
Posted on Apr 12, 2009
Zanussi washing machine wont stay on the setting for a quick wash.
perhaps the half load switch is faulty... or just grubby
na...
or more over the machine has detected you placed more than 4KG in the half load??? did you do this ?? fine
this is the issue
http://www.manualslib.com/manual/199558/Zanussi-Zwn-6120-L.html?page=10#manual
Mar 05, 2015 | Zanussi ZWN6120L Washing Machine - White
My Zanussi WJD 1257 washer/dryer's drying cycle has started finishing early. No error codes. The wash cycle works fine but the drying cycle is simply stopping prematurely. You can set it to dry for 45...
Good Day,
Your washing machine is fully automatic?
the washing cycle is normal?
if yes do the same maybe it will help you.
for the fully automatic washing machine mostly have drain pump, please check the filter of your drain pump, how? remove the cup of your drain pump like a ordinary cup, screw it clock wise or counter clock wise.
Remove drain pump filter and clean it, some hair pins, cotton buds or coins or any small item that coz of clog up.
if your washing machine dont have drain pump ,but fully automatic check the drain motor if running or not? how? open the back cover for top loader washing machine only, select spin cycle and press start to see the drain motor running? the drain motor is like a small box with small wire to pull the lever of the drain to remove water inside, if the motor running or pull the lever of the water pipe but water still inside the washing machine, remove the drain cup or cover and clean it or check if have coin or cloth inside that coz of clog or water stuck,
if the drain pump or drain motor is weak this is will cause and long time draining or totally not running the drain pump or drain motor and its cause of totally stop the cycle of washing machine in rinse time or spin time, because all fully automatic washing machine, after washing cycle the drain pump or drain motor must be on, to remove water before start the next cycle. rinse or spin cycle.
Nov 01, 2013 | Zanussi Washing Machines
My Zanussi Electrolux Essential 1200 washing machine ZWF12070W1
Most times unplugging a washer for 5 min or so will reset to factory. Some units just a quick unplug works too. But I'm not totally familiar with yours.
If it's going to be hard to unplug just turn off the breaker to it.
Hope this helps
Feb 27, 2018 | Zanussi ZWF12070 Front Load Washer
Have just bought a zANUSSI fjs 1225 W. Have run one cycle ( quick wash, 40 degrees, cotton) and the fabric conditioner was not drained away. Is this because it was a quick wash? V disappointed as I need a...
zANUSSI fjs 1225 W. Have run one cycle ( quick wash, 40 degrees, cotton) and the fabric conditioner was not drained away This video will show you how to keep your soap draw clear and how to service the parts Please remember to subscribe to our YouTube channel for all appliance tutorials a 4 THUMBS rating is appreciated for answering your FREE question. And don't forget to like us on facebook
Feb 15, 2011 | Zanussi FJS1225W Front Load Washer
The code E20 is showing on my w/machine,whats the problem?
e20 on AEG Elecrolux and zanussi is machine not draining efficently. blockages in the machine or drain can cause it. if your model has a filter or coin trap clean that out. or dismantle the pump to look for something jamming the impellor. may need a need pump.
Aug 06, 2010 | Washing Machines
Error E20
zanussi error E20 suggests a pump/draining problem. remove pump/filter and clean it all out. its located at the end of the drain hose at the bottom of machine. power off. it might need replacement.
Nov 01, 2009 | Zanussi ZWF1430W Front Load Washer
Zanussi washing machine, conditioner doesn't empty
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
May 14, 2009 | Zanussi ZWF1430W Front Load Washer
How do I access the drain hose to disconnect and replace with new? Zanussi F1245W washing machine.
Hi
you need to remove back panel and tip machine back 45 deg from there you can get to the drain hose and change it.
regards
Mar 21, 2009 | Zanussi ZWF1430W Front Load Washer
My washing machine will not spin( zanussi wda1055w)
heatman101
Jan 19, 2009 | Zanussi WDA1055W Front Load Washer / Dryer
ZDT5052 flashes quickwash light
Tarvi...I don't know what the problem is...hard to diagnose these things. If the unit is working correctly, I suggest that you simply cut the power for a few minutes and then restart it. That may clear our a trouble code.
Dec 06, 2007 | Zanussi 18 in. ZDT5052 Slim-Line Built-in...
Dishwashers Logo
102 people viewed this question
Top Dishwashers Experts
Oloyede Monsuru
Marvin
Marvin
