Question about Samsung WF337AA Front Load Washer
Door won't open. the washing cicle dose not finnish its cicle
I have are front louder model j1455av. it high lights SE as my problem not sure what that means
  • 3 Answers
Clean the debris filter.
Make sure the drainage hose is installed correctly.
http://downloadcenter.samsung.com/content/EM/200701/20070109165927703/EN/J1043-01986D_sub4_eng_050708.htm
Posted on Jan 02, 2009
Light flashing won start
Common error with front loaders is the door interlock. Make sure the door is positively closed. A gentle open hand push at the erea of the door lock often gets a machine started.
Regards
John
Jan 30, 2014 | Kenmore Elite 45986 Front Load Washer
Tricity aw 1000 front loader washing stuck in will not open
Does the y splitter have little valves on it? Make sure both are open.
Nov 28, 2013 | Tricity Bendix AW1000W Front Load Washer
GLTF1240ASO Front Door Won't Lock/Close
Most probably your door lock is damaged. You are not supposed to force it open, you have to wait for at least 2 minutes (or till the lock sign is off) after the wash is over to open the door, never force it.
You can just google your model number and search for parts to obtain it. It is quite possible you can change it yourself. See that the line is disconnected from the mains.
Jun 04, 2013 | Washing Machines
Door won't open and is jammed.
We have an electronic Sears front load model with which that happened. . If this is a Sears machine contact the service number located in your manual and they should be able to talk you through it. For us it ended up being a door switch that had become misaligned. Make sure the machine spins the water out of the tub before you try to open the door if it is a front loader.
Apr 02, 2012 | Amana Washing Machines
Door will not open
Remove the top cover, and release the door catch from inside the washer, you will probably need a screwdriver or similar to do do this.You will need to replace the door catch and spring, and possibly the door lock, as it may break when you force the door open.
Thank you !!
Jul 01, 2010 | Hotpoint Ultima WF860 Front Load Washer
The machine do not complet the cicle.in the regular cicle, the machine finnish washing but do nt let out the water and the cicle stop at this point
have a look and see if outlet pipe is kinked not allowing water to drain, failing this you may have a blockage in the pump system
Dec 17, 2009 | Washing Machines
Samsung J1455AV: Washing cycle does not complete and then stops
go back to where you bought it and have the engineer look at it might have been faulty when bought.
Jul 07, 2009 | Samsung WF337AA Front Load Washer
SMELL PROBLEM
have you tried a wash with chlorine bleach? if not aloow washer to fill with hot water open door pour in 1-2 cups clorine bleach aloow to wash a few min open door and with rag wet in bleach/water and wash inside front door boot rolling it toward you to get into inner portion alow to finish wash and rinse ..in future leave door open a little to allow to air out ..moisture remaing in door boot tends to cause mold/mildew problems ..you are not alone ALL front loads have same issue not just yours
Jul 16, 2008 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint wf 250 aquaries
try changing your water valve this should sort problem
Jun 11, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Whirlpol duet
sounds like your door lock switch may not engage.try opening and closeing the door. unplug the unit wait a few minutes plug back in and see if you can open the door. check to see if the door lock lights up.. hope this helps..
Aug 25, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Samsung WF337AA Front Load Washer Logo
500 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
