SOURCE: lg monitor won't come on
Try connecting the LG monitor to the VGA port on the HP tablet instead on the docking station.
SOURCE: Setting a Radio Station for Wake Up
You can download the manual from the link below: http://157.254.235.130/public/RP3721%20EN.pdf Please update the question & let us know if the information given was useful to you - Good Luck!
SOURCE: Dell FP1905FP Stopped working
First try on another computer just to see if there is any other problem then the LCD. Also check power supply to the monitor. I believe this has one that's internal, but if external, swap with a similar specs one. If internal, check to see if any popped up capacitors. Video boards are most likely ok.
SOURCE: Can't set to optimal resolution
cheeck the device manager in your laptop right click my com pand go ro properties and then in device manager and there look for display adapter click on the plus sign over thereand there it will give you an otpion and right click there and then uninstall the driver and then restart the comp and then place the driver and utilities cd in the cd drive and then install display adapter and then again restart the comp hope so your issue will be resolved
