Question about Car Audio & Video
Hi, I am installing a new head unit into my dads 98' Buick LeSabre and the factory harness has been cut and I'm not sure of the color code and not sure how to run the extras thru the new head unit and how to run the interior dimmer so the new head unit will dim also. I did buy the aftermarket harness to install it properly but like I said the factory harness has been cut all but three wires and I'm not sure how to fix it right. Please help me. Thank you Dave
  • 15,935 Answers
Metra makes wire harnesses for your problem. If your wire harness is, 70-5555 the part that goes into the OEM radio will be 71-5555
Try www.metraonline.com and put in the car info. The harness will come with wire codes for splicing the new plug.
Posted on Dec 21, 2008
Trying to wire in a after market pioneer stereo into my 1995 f150 4wd have looked at color code schematics but from the speaker plug harness colors do not match have started pulling left door panel
They sell a installation kit so you dont have to cut any wires. You unplug the factory unit install the proper plug into the new unit and factory harness and your done.
Sep 09, 2017 | Cars & Trucks
88 vette aftermarket head unit stereo wireing diagram
Might be able to get an adaptor that plugs straight in painlessly.
Failing that it's the standard trace and identify method that eats time like crazy.
Apr 16, 2017 | Cars & Trucks
How to get the key code by vin for 1998 buick lesabre
Hi, Leslie do you mean like how to cut a key or how to eletronic key security properties? Look in the owners manual sometimes their is a blank key that comes with car that haste the cut # on it. The 98 was the last year that electronic key lock security wasn't mandatory. If active can bee shut off by shut off by radio button controls also should be in owners manual. Good luck, feel free to ask anything about the 98 LeSabre I,m restoring one and know more than I ever wanted to
Aug 24, 2014 | 1998 Buick LeSabre
Hi I am wondering how I can wire In an aftermarket radio in my 91 Buick regal without using the factory harness's because they're cut off
Need to look up the color codes specific to the make and model of your vehicle as well as the color codes for the stereo being installed You can usually find those on google with enough looking around
Apr 02, 2014 | Cars & Trucks
Wires got cut from factory harness to the factory stereo need to figure out wire color codes
http://www.the12volt.com/installbay/stereodetail/347.html
Should be it.
Sep 24, 2011 | 1998 Buick LeSabre
I have a 98 buick century someone put an after market head unit in and now i have no sound the harness is all tight any idea what else i should look for?
Was this just installed or did it just quit. If it was just installed make sure the remote turn on wire powers up the factory amp. Some decks will stop all sound if there is a short on a speaker. disconnect each speaker cycling the key each time and see if you get sound
Jan 18, 2011 | 1998 Buick Century
Need wiring color codes to install a new radio
the easiest way to install a new radio is to get the wiring harness adapter for your vehicle it runs about $25 and then you do not have to cut the factory harness. the wiring codes will come with the new harness and is just matching up there color code to the new stereos color code.
May 21, 2009 | 1994 Lincoln Town Car
1998 BUICK LESABRE CUTS OFF WHILE DRIVING
The problem is the crankshaft sensor for sure. It is mounted behind the crankshaft pulley which is pretty difficult to get off as you need a special puller. A shop should charge about 1.5 hours for this job. It is a very common problem.
Apr 05, 2009 | 1998 Buick LeSabre
Installation of new cd player in 2002 VR-X Lancer
There are aftermarket wireharnesses available. I suggest the $15-25 purchase. The wires usually match color for color to the aftermarket stereo saving a major head ache if attempting to figure out the factory harness. These adaptors are available at many audo part stores and local installation shops. To check the harness you need, Metra, on of the main aftermarket wire harness manufacturers has an application chart on line, see metraonline.com or a search for American International or Scosche.
Nov 14, 2008 | 2002 Mitsubishi Lancer
I need to install a max385vd in a 2002 pord f-350, do i need an install kit?
Regardless of whether this is an amp or a head unit, an install kit is either very helpful or necessary. If it's an amp, you'll need it for sure - you can't power an amp with 18 gauge factory power wiring like a head unit can use. You need to get at least 10 gauge power and ground wire, 18 gauge remote turn-on wire, and RCA patch cables to conduct the sound. If you have a factory head unit, you'll also need a line-level adapter to give you a source for the RCA patch cables.
If this is a head unit, you'll need the adapter harness to plug your existing stereo harnesses into the new head unit. It makes it simple - the wires on the new head unit are color-coded for what they do, and the adapter harness is identically coded. Match the colors, then plug it in. You may also need an antenna wire adapter (some cars require this).
Aug 10, 2008 | Clarion Car Audio & Video
Car Audio & Video Logo
165 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
