Question about Lexmark E232 Laser Printer
Printer will not operate.
When I turn on my Lexmark 232 printer all the yellow lights flash - I get a message to Please wait for something to download - and the computer freezes - My computer technician suggests it may be the "setting" of the ink cartridge ?
With this model, it is a Toner cartridge, you need to be more specific in what the error is.
Posted on May 14, 2007
E120n ALL LIGHTS FLASHING
switch off you printer. pull out power cord from source, wait for 5 minutes then plug in back the power cord to the source and switch back ON your printer
Sep 02, 2015 | Lexmark E120n Laser Printer
Light flashing 5 yellow then 1 green. said operator error. Occured after wife tried to change black ink cartridge but mistakenly replaced it with Cyan cartridge. IS this machine smart enought to know...
Hi there maximum time we found it is a the head problem. The print head is what the cartridges sit in inside of the printer. For resolve the problem please follow these.
Open the printer and wait for the carriage to slide over. Some how if its not come then Unplug the printer & Manually slide the carriage.
Now Remove the ink cartridges from the print head & Use wet warm cotton swab or use alcohol to thoroughly clean the print head.
Repeat this until there is no ink residue coming off on the cotton swab. After finished it make the head dry then fix it back. Now Try to print something now
If that does not work then follow the next step.
Remove the printer data cable & restart the PC & printer. Then fit back the data cable & turn on the printer. Hope that's start working , if no luck then Uninstall the printer driver & restart the PC & Printer both again. Now install the driver of the printer and connect it with PC ,Turn on printer & go for a test print from the printer preference. Thanks & waiting for your reply.
Aug 10, 2010 | Canon I960 InkJet Photo Printer
Lexmark C510 LCD shows underlined black boxes - not wrking
Hello you can try the following, try resetting the printer doing the following. Turn the printer off, then press and hold the arrow pointing left, the select button and the go (green) button. Hold down those three buttons at the same time and power the printer back on and wait if you see a message saying Restoring Factory Defaults. When that message appears you can let go the three buttons. If the same problem of the black boxes that flash appears then you might have a problem either with the Operator Panel or Engine Board. About the price that will run you to replace this parts I don't know.
Jan 28, 2010 | Lexmark C510 Laser Printer
Two lights are lit up on the operator panel of my Lexmark E232 printer: a steady blue ready light and a steady yellow toner cartridge light.
Jul 10, 2009 | Lexmark E232 Laser Printer
Two lights are lit up on the operator panel of my Lexmark E232 printer: a steady blue ready light and a yellow blinking toner cartridge light. Neither the continue or cancel lights are lit up. This...
Sounds like your photocoductor is at lifes end. You can reset it by doing the following
1. Turn the printer off.
2. open the front cover
3. hold down the cancel X button while turning on the power and keep holding down until all lights stop flashing. Then let go of the x button and all lights should start to flash, close the front cover...and it should reset. You may have to turn the printer off and then back on once to be sure it is reset.
Jul 07, 2009 | Lexmark E232 Laser Printer
HP Laserjet CP2025
If this is a new printer, chances are you may have left a piece of orange tape some where in the printer, otherwise you may have to remove the transfer belt, power the printer on and wait for it to say that it is missing, replace the belt and power on again, should fix it.
Mar 27, 2009 | HP Laserjet Cp2025n Printer
My lexmark x1240 will not print in color
After disconnecting the cables from the printer and restarting the computer I would suggest removing all printer related software from Add/Remove programs in the Control Panel. After that I would suggest downloading the latest drivers by following the directions below.
You should be able to get the drivers here. Just enter your exact printer model in the Search by printer model field and press Enter.
Click the Download Driver link and choose your operating system in the Select Windows field. Then on the next page, choose the Download Now link on the right.
On the next page you may see a yellow security banner at the top of the browser. If so, click it and choose Download File. After that, choose Save to start the download. After the download completes you can double click the file to start the installation.
Hope this helps. Please remember to rate this information.
Thanks
Jan 04, 2009 | Lexmark X1240 All-In-One InkJet Printer
My lexmark 232 shows the light "toner low/replace pc kit". how do i do that?
The Photoconductor Kit designed for use with Lexmark E230, E232, E232T, E238, E330, E332, E332N/TN, E240, E340 and E342. Yields 30,000 pages.
Have you printed 30,000 pages on this unit? If not perform the following reset:
Procedure for E-232 is:
1. press and hold Start
2. turn on the printer
- this is service mode -
- by pressing the Start you can print Printer Settings Configuration sheet -
3. press and release Cancel 4 time
4. Press and hold Start while all lights start cycle
5. press and hold Cancel untill all the light cycle
6. turn the printer off to exit the menus
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Dec 20, 2008 | Lexmark E232 Laser Printer
Printer won't print
What model of lexmark printer are you having a problem with? How is it connected? Have you change an ink cartridge? Has anything else change when you moved it? Like new computer , different electrical outlet etc.. What type of computer are you using and what operating system are you running? Please wait to rate me untill I get the infromation I need to help you, thanks. I will do my best to help you with your problem.
Jun 10, 2008 | Computers & Internet
Lexmark P4350
Solution:
I have a Lexmark and it says that there is "No Loaded Paper" some times and when you click ok it keeps saying it. If the power light is flashing on the printer - try this suggestion.
Suggestion:
  1. Press the power button (Which will turn off printer.)
  2. Wait till flashing stops and printer is completely off.
  3. Press the same button which will turn on the printer.
  4. The Printer should automatically go back to printing.
  5. If it does not - Manually try printing by your self.
Dec 04, 2007 | Lexmark P4350 All-In-One InkJet Printer
Lexmark E232 Laser Printer Logo
121 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
