Sunbeam Slurples Machine won't work
The blades of the slurples machine keep freezing to the inner chamber and popping of the lid. - I have tried over & over again as per the instructions with no luck. I am so disappointed
  • 1 more comment
  • Anonymous Dec 26, 2008
    Yes, the same. It freezes up, pops the lid. The thing churns and churns but the drink just comes out cold, not even icy.
    Any tips?
  • mmcguire99 Dec 27, 2008
    Same problem. I have a disappointed 12 year-old. Why release a product, so poorly designed, that will not work?
  • squiggles_59 Dec 28, 2008
    We have the same problems, tried several different drinks, non freeze.
    The first made the lid pop, I think it is because we waited to long to turn on the mixer.
    My disappointed 14yo wants his money back!
I had the same problem, it happens with diet or reduced sugar drinks. The manual says don't use them and it is right. Try normal old teeth rotting full sugar cordial or soft drink and it works beautifully.
Posted on Jan 09, 2011
  • 700 Answers
Have you tried replacing the blades so that there is not any spacew between them and the barrel for the ice to acccumulate.
Posted on Mar 21, 2009
My washing machine keeps displaying error code F17 and won't go on. Does anyone know what this means and what I can do to fix it?
F17 indicates no water coming into the condensing chamber during drying.
Unplug the appliance.
Take the top off.
Check to see if the condensing chamber below the heating chamber is blocked.
Oct 15, 2012 | Siemens Washing Machines
HHH shows in the window. Won't start. What is the problem
The error code for HHH usually means it is too hot, if it is has been used recently. If it has, unplug the machine, and try to wait for it to cool down with the lid open for about 15-20 minutes. If that is not the case, I would suggest you to contact the manufacturer at:
https://secure.sunbeam.ca/ContactUs.aspx
Hope this helps!
Remember to give me 4 Thumbs Up
for all the hard work to the Community! :D
~~Dayminner
Jun 04, 2011 | Sunbeam 5891 Bread Maker
Error code E:02 on Sunbeam Bakehouse BM3500S
That is a temperature warning that is an automatic feature on bread machines. What the machine is telling you is that the oven chamber is still too hot from baking the last loaf. It does that to prevent you from starting another loaf and having that loaf fail due to the high heat killing the yeast. If you want to bake more than one loaf push the STOP button till it beeps, unplug the machine, raise the lid, and leave it open for no less than 20 minutes. It should work fine by then if not let cool off another 10 minutes. It will be cool enough by ½ an hour to start another one.
May 24, 2011 | Sunbeam Kitchen Appliances - Others
How do you keep the kneading blade from being baked into the bread?
Hi, You can take the kneading blade out of the machine after the last kneading cycle and before the final rise. Take the pan out of the machine to do this just to be on the safe side, Hank
Dec 06, 2010 | Sunbeam 5891 Bread Maker
Used 2 times in a row, but now get HHH when trying to restart
That just means that your the oven chamber is too hot from the last loaf you baked in it. It does that because the ingredients have to be at at the correct starting temperature or you won't get a good rise. It's designed to do that.
However, ifIf you have let your machine cool off (open the lid and leave it open after baking for about half an hour) and still shows the HHH then you have a more serious problem and should call or contact Sunbeam.
Nov 09, 2010 | Sunbeam 5891 Bread Maker
Enigma b autoclave
Oh no, you have bought a "Runyes" Chinese unit. "Run - Yes" is the best option. Sell it & buy something better.
But, E4 is to do with Temp or Pressure not right.
Code E4:constant temperature and constant pressure failed.
(the chamber pressure tolerance is greater than 0.25bar or temperature tolerance greater than 2.5?)
Solution:
A. please check if you can open the solenoid valve which the steam gets into.
B. please refer to E2 process
For E2 try:
Code E2:Chamber overpressure
(The chamber pressure is above 2.4 bar for longer than 2 seconds)
Solution:
A. Please check when the pressure rises, the chamber inner temperature will also rise up. If not or rise up very slowly, then you should check the inner temperature sensor, please refer to E1-C1 process.
B. The chamber keep vacuum pressure, the vacuum pressure will be -0.7 bar within 4 minutes under normally room temperature, and it will above 0.1 bar within 5 minutes if the pressure do not leak out, otherwise, you should check the chamber cover, solenoid valve, safety valve, vacuum pump, connector welded points, till you find the problems where and why the pressure leak out, then solve the problems if you find it.
C. During the machine normally working cycle, please observe if the machine vacuum could be lower than -0.6 bar, even lower than -0.7 bar if the machine is still cold.
D. Adjust the chamber cover and tighten a little if necessary.
E. When you run a cycle for the first time with a packed or non packed instruments and it comes up with E2, please don't worry. It will not come out with the E2 alarm again when you run it the second time.
Sep 12, 2010 | Health & Beauty
The Sensor Magnet for water tank does not float to the top
OK, first of all, I do not recommend my solution if you are forgetful or do not check your water level manually daily.
However, I found a super easy solution.
The way the unit works is to use a float in the water chamber with a magnet on the bottom. When their is enough water in the tank, the float rises and the magnet on the bottom floats to the top of the magnet chamber. When it floats up, it aligns with a sensor in the machine that allows the machine to operate. When the the water level lowers, so does the magnet and drops below the internal sensor disabling the machine with a "Fill Water Tank" error message.
To eliminate this error and allow the machine to operate, I simply popped off the lid to the magnet chamber with a butter knife and turned the water chamber up side down to let the magnet float fall out. Remember to empty the water first.
Here comes the highly technical part. Turn the magnet float upside down and slide it back into the float chamber. Since the actual magnet is on the bottom of the float it now is at the top allowing the internal sensor to turn off. No more error message!
The reason I do recommend this is because this completely defeats the purpose of the sensor and will most likely damage your machine if you run it without water. Keep you tank filled however and you will eliminate the frustration of a "float gone bad" keeping you from your morning caffeine.
Apr 08, 2009 | Saeco Incanto Classic Espresso Machine
Kneading Blade chattering
I had the same problems with another manufactures model. I found that the bread pan needs to slot in the machine only one way. The pan will fit in the machine with the handle both vertical and parallel to the front. However to stop the clacking noise I found that one way in the machine..it makes noise, the other way it doesn't. You'll have to try. If it makes noise, open the lid and turn the bread pan 45 degrees in either direction and secure it back in the breadmaker then close the lid. I hope this helps. If it does, remember how the pan is in the machine for next time to avoid the noise.
Jan 02, 2009 | Sunbeam 5891 Bread Maker
I have a Sunbeam Slurples machine and I just can't get it to work. It keeps freezing the blades to the inner cyclinder. I am really disappointed. Please help.
Hi, I also have a Sunbeam Surples machine, mine works fine if you use real Coke, Sprite etc... but also found that the blades are frezzing to the inner cyclinder if I use a syrup based soft drink such as Soda Stream.
Dec 17, 2008 | Heating & Cooling
Kneading blade keeps baking into the bread- help!
Watch/listen to the machine your machine. After the last knead cycle, remove the paddle from the bake pan before the dough rises, continue to bake as normal.
Dec 05, 2008 | Sunbeam 5891 Bread Maker
Heating & Cooling Logo
216 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Mack Baxter
Marvin
Marvin
