Question about JVC TH-S11 Theater System
We hv JVC TH-M508 HOME THEATER SYSTEM IS WORKING BUT THE DVD IS
OUR DVD WAS WORKING FINE TILL YESTERDAY AND ALL OF SUDDEN DVD IS NOT WORKING INSPITE OF CKING THE WHOLE SYTEM IT IS WORKING PROPERLY , ALL OTHER FUNTIONS AND SPEARKS ARE FINE EXCEPT THE DVD IS NOT PLAYING ANY DVD
KINDLY WHAT IS TO BE DONE , IS THERER ANY PART TO BE REPLACED OR SERVICE TO BE DONE.
TKS & RGDS
SHAM BHATIA
techman
  • 3130 Answers
SOURCE: System unresponsive when modes are switched
Sounds like there may be a glitch in the microprocesor. Make sure when you unplug it that you leave it along for a few days and is there any type of clock or standby batterys in it take them out as well. If that dosent correct the problem your gonna need a service manual to trace the switch pulse to see if the units Switch matrix lines are low or lost because of a faulty micro or a bad componet like a small caps they install on the matrix to keep noise off them. Hard one to call with out seeing unit and analizing unit Good Luck
Posted on Apr 12, 2006
techman
  • 3130 Answers
SOURCE: Home theater won't start playing DVD
If a disc will not spin, A- the laser may not be focusing on the disc, as it must do this before it will spin and read the TOC. ( table of contents) B- you could have a fault in the spindle motor circuit or the motor could be bad. You will need to find an authorized servicer if you do not understand solid state repairs. Good Luck PS please dont forget to rate this.
Posted on Oct 14, 2006
  • 29 Answers
SOURCE: NO SOUND From JVC TH-S5 Home cinema system
First, make sure it didn't get muted, or the remote's volume got turned way down. Next, it might be time to involve a technician who can check all the power supply voltages. Many of today's electronics have multiple voltage power supplys, 5 volts for logic, 12 volts for motors, and amplifiers usually have the biggest- maybe plus and minus 30 volts for a total of 60. There are hazardous voltages in there too, a switching power supply starts with over 300 volts. So don't lick it and see if your tongue tingles, that's only for 9 volt batteries.
Posted on Jan 29, 2008
welcomejee
  • 10594 Answers
SOURCE: jvc th-c50 home theater standby light blinks but won't turn on
you need to have service manual copy to check amplifier output section as it seems defective. There are few websites that offers service manuals download for small fee.
Posted on Jun 11, 2009
  • 5 Answers
SOURCE: not getting any power
Probably a blown fuse. If you have a warranty or can return it do that, if not unplug it, open it up and there should be a 250 volt glass type fuse. pull it out and make sure it is blown. If it is replace it at radio shack. If it isnt check for loose wires around the power cable and the transformer.
Posted on Feb 27, 2010
Does anyone have a JVC TH-G41 Home theater system
EEPROM for region 4 is F1 00 c9 cc 00 0d f4 20 cb 00 I am trying to find the code for region free or even region 1 if you know it, I have a post on fix ya , cheers Manuel
May 11, 2012 | JVC Th-g41 Theater System
I hv a JVC th-s3 dvd player who's dvd tray is locked. none of the solutions on this forum hv worked. pls help. thanks. chris
You have to remove the changer assy. See why it's jammed and retime it. I have seen a lot of these with jammed changers. If you remove the dvd assy from the bottom there are 2 gear sets to the side. 1 moves trays up and down and the other draws tray in and loads the disc. All I can say is if you are mechanically inclined you can figure it out. If not have it serviced.
Jan 01, 2010 | JVC TH-S3 System
Subwoofer powers on for about 4 seconds and then shutsdown
I don't know if you were able to get the problem fixed, but I had the same sort of problem where it worked and then all of a sudden it stopped working right in the middle of a movie.
I took it to a repair shop and he found that it was the power supply... a $4.00 part.
Jun 14, 2009 | JVC TH-C30 System
JVC TH-M505 changer displays NO DISC
There are two rails in the dvd player. I have found that cleaning the rails & applying new grease to them usually solves the problem. a spray with silcone will do. do not get any on the laser. best done by a pro & not many know of this little trick.
Miyagi2
Jun 10, 2008 | JVC TH-M505 System
Unlock code for jvc dvd
hi if you can help me i have a dvd jvc th-a35 and it wont play all the dvds what is the number or how i can unlock to play all dvds
Nov 25, 2007 | JVC TH-A35 System
JVC TH-S11 Theater System Logo
212 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
shaun taylor
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
