Question about Procom MN300TBA Heater
Garage heater wont stay on
I have a RITETEMP RTN300TB vent free heater in my garage, approximately 800 sqft. I have had it for about 5 winters now, and last winter on occasion it would just shut off by itself. I would come home from work, pull in the garage, and the heater would kick on, then I would come out to the garage 8 or so hours later, and the heater would be off, including the pilot. I would relight the pilot, and it would be fine for a week or so. It is doing it a lot more this year. I took it apart, and cleaned the t-couple, and the pilot light burner orifice. After reassembly, I lit the pilot light, and the heater kicked right on, thought my problems were over. Well, when it got to temp. and shut off, the pilot shut off also. I tried relighting the pilot, and it seemed as though the gas was too high of a psi. and it kept blowing out the pilot. I was working in the garage, and did not have any symptoms of CO poisoning, although I have never found the "oxygen depletion sensor" so I dont know if that is my problem. Please help, as I use this heater to keep my garage "warm" during the winter to keep our trucks thawed out.
Thank you
Kirk
  • 41 Answers
SOURCE: pilot light wont stay lit once heater shuts off/ light goes off randomly
Hi Watertec00,
I am not familiar with this heater but it sounds like it could be a blockage in the main gas line into the heater or perhaps a blockage to the pilot gas line and maybe starving for gas. Best bet first is to check the main gas line from the heater. Easiest way to do this is to remove it from the heater and blow it through with compressed air. Then try the heater again. If that doesn't fix the problem then you can try blowing compressed air down through the pilot line. Could be a little dirt creating a blockage there. Then try the heater again. If it still does the same thing then try removing the panels to expose the heater's piping. If you can remove the main pipe into the heater from the gas and blow compressed air through it it should clear any obstruction from both the main line and the pilot. If this doesn't work then I would think you have a more severe problem and will need to take it to your local Heater Repairer. Hope this helps.
Regards
Bryan
Posted on Dec 22, 2007
SOURCE: Burner won't light
I left it off for a couple hours and it fired back up.
Posted on Nov 09, 2008
  • 80 Answers
SOURCE: heater won't relight or turn back on after the thermostat turns
Verify that your pilot is staying on if you have a pilot.
Some may have electronic ignition.
Posted on Oct 01, 2009
  • 75 Answers
SOURCE: pilot lites; but, as soon as I turn on gas flame
sounds like your thermacouplar is going out and needs replaced. Sometimes these will act like they are working fine , but when the pilot stays on for awhile and later goes out it is a sure sign that it is bad
Posted on Nov 08, 2009
  • 33 Answers
SOURCE: have 2 procom natural gas heaters. they worked
Sounds like thermal couple fault get unit seviced
Posted on Jan 17, 2010
I am looking at a Dayton model 3e226 heater for my garage. can it be vented out the wall?
If done properly to code with double wall venting & an appropriate collar. But wow! Hope you have a huge garage. That's a lot of heater.
Sep 15, 2015 | Dayton Heating & Cooling
Can a sterling garage heater be vented out a side wall of a garage
Yes, should have a chart in the installation book that shows distances to windows.
Sep 23, 2014 | Sterling RF30 Natural Gas Garage Heater
I PURCHASED A DESA RADIANT HEATER AT A GARAGE SALE, IT WORKS BUT IS IT VENTLESS AND IT IS A MODEL 0630545
I would really like to help you determine what you have. However, the model number you listed is not a DESA model number. I think you may have listed the Serial Number instead. DESA/Vanguard/Comfort Glow wall heater model numbers start with 2 to 3 letters then 4 to 5 numbers.
However, to visually tell if it's Vent-free (Vent-less) look for a round hole for a vent pipe connection and/or look at the manufacture's data plate on the side or rear of the heater. It will tell you whether it's Vented or Vent-free. If it doesn't have a 3' round hole for a vent pipe, it's Vent-free.
Hope this helped you and thanks for choosing FixYa.
Sep 08, 2011 | Heating & Cooling
I am getting ready to buy baseboard heat for a 800-900 squarefoor open area, old GArage, And I am looking at 3 8' 2500W sections of base board. is this enough. And How much better is the units you have...
First, those of us on FixYa don't sell any products or appliances. Just information.
But to answer your question about electric baseboard heating ... It's the most inefficient and costly heating source you could use. With that said, a lot depends on the cubic footage of the area, as well as how well that area is insulated. This applies for electric, gas or oil heating. You rae not just heating square footage, you're wanting to heat cubic footage (i.e. Width x Length x Height = Cubic Footage). Assuming you have an 8 ft ceiling, the Cubic Footage would be (assuming a 9 ft ceiling) 7200 Cubic Feet. Based on that and if it was my home, I'd be installing a 20,000 - 25,000 Btu Vent-free (Flue-Less) Gas Heater, with built-in thermostat control. It could either be as a Free Standing, Vent-free Gas Fireplace System or simply a Wall Mounted Heater. One is decorative, as well as efficient and the other is simple and efficient. Plus, gas heat is a warm, moist heat that you feel very quickly and it's more comfortable than electric or oil heat. As a matter of fact, Vent-free Gas Heating Appliances are 99.9% efficient. And will work without electricity. Which is great during a Winter power outage. If you currently don't have Natural Gas at your home, then LPG (Liquid Propane Gas) is readily available.
So, by now, you figured out that my preference is gas. I have three Vent-free gas heating appliances in my 3000 square foot home (2-Vent-free Remote Controlled Gas Log Sets in existing wood burning fireplaces & a Vent-free heater in my 2-car garage). Our primary heat source is an electric heat pump. Which doesn't work well, when the temperature reach 32 degrees F or lower. We use the gas heaters only as a supplement heat source or as primary source, if the power goes out.
I hope you'll take a little time to research this, because in the long run, it can save you $$$. Below, is a link to Empire Comfort Systems. They have excellent supplemental and primary heating products in all looks, shapes and sizes. This will give you an idea of what's out there.
http://www.empirecomfort.com/corporate/
I hope all of this helped you. Please let me know. Thanks.
Jun 13, 2011 | Fahrenheat F25426 Electric Baseboard...
Mr. Heater Natural Gas Garage Heater - 45,000 BTU. Power 120 volt and 24 volt good. Thermostat calling for heat, but nothing happening??
Check for a fuse either in-line or on the circuit board. There should be 24 volts going to the thermostat. If not, you have either a bad transformer or a bad thermostat wire. Jump out the terminals that the thermostat wires are connected to. This should force the unit to fire. If not, bad circuit board.
Dec 23, 2009 | Mr. Heater Natural Gas Garage Heater -...
Refrigerator/freezer in garage doesn't keep food frozen in winter
Yes there is a solution. You need to install a garage Thermostat Heater. This will trick the thermostat into thinking it is in a warm environment. This article will tell you why this is happening and the solution as I described. Sorry but for some reason I cannot post this as a link. Copy & Paste into your browser. http://applianceparts.wordpress.com/2009/01/12/why-won’t-the-freezer-in-my-garage-refrigerator-freeze/
Dec 07, 2009 | Kenmore Freezers
Is it normal to run a 16" vertical tie in to a horizontal exit
No, Exhaust vents on heaters should always maintain vertical orientation because heat rises and creates a natural drafting drawing the fumes out. You have a monoxide poisoning situation otherwise.
Oct 20, 2009 | Mr. Heater Natural Gas Garage Heater -...
Is a kerosene heater good for working in my garage during the cold winter? Is it safe to breath?
Is it safe? That depends on what you are working on. Having a fire/heat source on the floor is a possibly of an explosion if you have gasoline fuel vapors.
For the most part it is safe, you will smell when you leave the garage, but as long as it is not a real air-tight garage you would be ok.
I run a propane heater in my garage during the winter to get away for a bit. I also have a well ventilated area and don't work on gasoline related items during the winter with that on.
Aug 15, 2009 | Reddy Heater-30-55,000 BTU Variable
Carbon monoxide poisoning?
The problem is that it is burning up all the oxygen in the room. That is what makes the CO level high. He needs to either leave a door, or something open, and possible even a little fan to keep the Oxygen that is IN the room mixed. I figure he is working low, and there is not much air moving around him.
Get fresh air INto the room and the CO will not be a bother.
Dec 23, 2008 | Rinnai Desa Vent-Free Infrared Gas Heater:...
My deep freeze outside will not stay cold.
a freezer is just a heat pump . from inside the freezer to the garage . the first law of thermodynamics says heat travels from a hotter to a colder surface . it could just be the cold how much are we talking?
Dec 14, 2008 | Kenmore Freezers
Heating & Cooling Logo
195 people viewed this question
Top Procom Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Procom Heating and Cooling Expert? Answer questions, earn points and help others
